What am I doing wrong
paul
shift reset -10 -
paul, what do you think of the numbers?0
I'd zero it....-1 is doing nothing anyway.What are the setpoints at out door low and high?0
....0
it did bring it down a little
also, I have the circs at medium speed
I'll go 0 it now
what about the rest of the numbers?0 -
Is the house comfortable now?. If so, whats the target number?0
I put shift to 0 and it made my set pt to 970
very comfortable
target was 94, but when i put the reset to 0, went up to 970 -
Gordy, did you notice, the temps are the same on the kitchen and the sensor0
Paul, help me, when you say target is that the set pt?0
I imagine, changing the shift to 0, the house will get a bit warmer0
Yes.....2nd number it's shooting for0
ok, thanks
since you tell me to go to 0, should i change something else to bring the set point down?0 -
What do you have the set point at?0
on the menu
set pt l 140
set pt h 800 -
Don't touch it.0
There is a set point 1, 2, or 3. Your is setpoint 1. those are the reset curve set points.0
yes, I'm in 10
it's going to get warm again, changing the set point to -1 which starts off at 95, then jumps to 970
you feel it was a wise move to set the circs to medium. I had them on low before0
when i changed the speed, the basement radiator got warm.
do you think i should go to high?0 -
out low -10
out high 63
set pt low 140
set pt high 80
out d shut dn 95
shdn dif 10
shift 00 -
What's the SH 1 setting?0
system 97/97
sensor 41
kitchen 41
flame 42
Paul, I thought i gave all the numbers, what did I miss?0 -
Move the set point low to 135 and see where your target temp goes.0
ok, I'll be back0
set pt low 135
95/95
flame 23 but might rise0 -
Isn't that where you wanted to be?0
sounds good to me
what about the speed of the circs?0 -
Leave everything alone now.....Read the service manual, as many times as it takes to understand every parameter.0
system 95/95
flame 29%
sensor 41
kichen 400 -
thanks Paul, and gordy0
Mark if it's in your budget a strap on thermometer on the return pipe to the boiler. Wondering what the delta t is your running..0
Difference between supply temp and return temp.0
There will be several things in the up coming season when the weather gets colder you could track and document. One example is when you get down to design temp -5 what your SWT is, modulation rate, and how long it is at that modulation..
Another is of course more interest to you fuel usage compared to the old boiler.0 -
there is not a doubt in my mind that my fuel will be less this season than any other winter i've lived here.
I don't know if you remember, but the boiler i had before this one, was 35 years old, and i think it was 220,000btu, now, I have new technology with a boiler only 8500 btu. It's got to be better
you mentioned a strap on thermometer, what dop they go for, and where would i get one?
and that's what they are called? strap on?0 -
I just went downstairs.
I felt the copper in and the copper out, they seem to be close to the same, and i have heard, this system works best, if the in is colder that the out. Is that correct what I am saying? putting a radiator in line, rather than in and out, 2 different pipes.
When i say inline, I mean run it thru the in, of the boiler0 -
Mark.......You're only sending 95* water out to the system. Is the boiler condensing?0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
