What am I doing wrong
1679111218
  • maybemark
    maybemark Member Posts: 1,131
    hi Carl
    Have any thoughts?
  • Paul48
    Paul48 Member Posts: 4,469
    Keep track of actual temp ( kitchen thermometer?) vs target temp and what is going on in the house.
  • maybemark
    actual temp outside?
    or inside temps?
  • Paul48
    outside
  • maybemark
    system 104/104
    sensor 30 actual 25 outside
    inside 73
    flame 27%
  • Paul48
    now ya wait
  • maybemark
    ok, I'll wait
  • ced48
    ced48 Member Posts: 469
    maybemark said:
    it's still under warranty, I don't know if i told you, when i called up lochinvar to register it. They told me, no warranty, cause i am not a certified contractor
    Lochinvar will honor the warranty. They were very fair with me, going beyond what they could have done. I cannot say enough good things about their customer, and tech support.
    SWEI
  • maybemark
    ced
    the person i talked with said no
  • ced48
    Talk to someone else, that is not the company policy. Triangle Tube has this policy, not Lochinvar. You may have to go to a level above the guys you will get if you just go to tech support.
  • SWEI
    SWEI Member Posts: 7,348
    You're going to need to prove it's defective in order to get a warranty replacement. Have you run the tests yet?
  • ced48
    edited November 2015
    Yes, in fact, you will probably have to buy the part, have your supplier send the old one back, and get a credit from your parts supplier, if the part was bad.
  • Steve Minnich
    Steve Minnich Member Posts: 2,868
    I didn't read the entire thread but I'm surprised that there's an outdoor sensor failure this soon. Any chance the batteries in the ohmmeter used to test the sensor are weak?
    Steve Minnich
  • Gordy
    Gordy Member Posts: 9,546
    Stephen Just seemed odd the sensor was pretty much reading low 30s when temps dropped sat might
  • Steve Minnich
    I agree. Is that why the sensor was moved? The thinking being that the original spot was a poor choice?
    Steve Minnich
  • Gordy
    Yeah it was above the exhaust for the boiler.
  • Steve Minnich
    Makes sense. Sorry. There were too many posts to read through. Porter Pipe in Addison probably has them on their shelves as we speak.
    Steve Minnich
    Gordy
  • SWEI
    I'm still not convinced it's bad. I'm not convinced it's good either. Need to test.
    Steve MinnichGordy
  • Steve Minnich
    I always disliked the "parts changer's mentality" in our industry.
    Steve Minnich
  • maybemark
    now the temp is reading 36 and my kitchen oudoor thermometer is 32
    Gordy, I'm not a boiler guy, but, I would never and didn't have the sensor above the flue. but, is was about 3 1/2 feet away on a north wall.
    I now have it on the same wall, about 10 feet away, and the sensor is sitting next to a downspout
  • maybemark
    I have the set point for this temp set at 99, and it's very comfortable in the house. I turned up the speed of the circs, now the basement radiator is working
    my flame is 41%
  • maybemark
    i meant to call up the dealer i bought it from, and I just forgot. see if i can get a sensor from them
  • Gordy
    Okay......does the down spout leak?
  • Gordy
    my flame is 41%
    Remember when you wondered why it did not work what I said?
  • Paul48
    You're going to have to sort out the sensor issue then get back to getting the curve right.
  • maybemark
    gordy
    I don't understand what you are saying after my quotes
    the downspouts don't leak
    and what did you say? and why are you quoting me?
    I was making a joke, did you take it seriously?
  • maybemark
    Paul
    a few people said, they don't feel the sensor is bad.
    Does age play a factor on them, if it's just sitting in a box not being used,
    I don't know if you know
    my boiler was new old stock, i think from 2011.
    would age play a factor ?
  • Paul48
    You have to do as those people said, and test the sensor. If it's bad, it's not from age. It might be bad, right from the manufacturer ( China?)
  • maybemark
    I did an ohms test on it
  • maybemark
    the sensor reads 33, the internet reads 32, and the kitchen outdoor thermometer reads 31
  • Paul48
    Another couple days and it will be perfect...lol
  • Gordy
    Just so you understand if the sensor is off a couple of degrees it's one thing. If it gets quirky, and starts giving wild erroneous, and in consistent readings then it will effect your curve. Example it goes down to 10* and the sensor reads 28, and then another time same senecio the sensor reads 20. Keep an eye on that.
  • maybemark
    I'll be watchin it for the next few days
  • Gordy
    I'm most curious of design day conditions supply water temps, and % modulation you have a lot of mass with the house and system.
  • Gordy
    Mark where are you at with your outdoor high and outdoor low set points? And shift.
  • Paul48
    Page 22 of the service manual is the most important thing at this point. Four settings.....Out low, and outdoor high define the curve. Set point at outdoor low and high define the temperature range within the curve.
  • maybemark
    Ill go check now and post it
  • maybemark
    out low -10
    out high 63
  • maybemark
    set pt low 140
    set point high 80
    out doorshtd 95
    chdon diff 10
    shift reset -1
    system 95/95
    outside sensor 41 kitchen 41
    flame 33
  • Paul48
    Any shift?
