What am I doing wrong
1…34689…18
  • Paul48
    Paul48 Posts: 4,469
    Is it possible that radiator is air-bound?
  • maybemark
    maybemark Posts: 1,131
    Paul, I did bleed it a while ago, but that is a good possiblity
  • Gordy
    Gordy Posts: 9,546
    Right
  • Gordy
    Gordy Posts: 9,546
    edited November 2015
    You,have,to know the outdoor air temperature to read the table in the manual to know if it's okay.
  • maybemark
    just checked, no air
    when you said right, right for the radiator, or right for the sensor?
  • maybemark
    well, i have a thermometer in the kitchen that reads temp outside it reads 24
  • maybemark
    it is on the same wall as the flue, but i seperated them by about 10 feet or so
  • Gordy
    Gordy Posts: 9,546
    Sensor.
  • Gordy
    Gordy Posts: 9,546
    Whatcha got?
  • maybemark
    i did not check yet, i was looking in the manual for the numbers, Ill go check now
  • maybemark
    I got 32k on the outdoor sensor
  • maybemark
    in the manual, where is the chart?
  • maybemark
    well?
  • maybemark
    it got up to 70 in the kitchen and still 72 in my bedroom where the stat is
  • Gordy
    Gordy Posts: 9,546
    Page,35 install manual
  • maybemark
    i found the chart, it's off, but not by alot
  • maybemark
    actually, I think it's right on
  • maybemark
    30* is 34 k
    32* is around 32k
  • maybemark
    my kitchen thermometer must be wrong
  • Paul48
    Paul48 Posts: 4,469
    Have you adjusted the valves on the radiators, at all?
  • Gordy
    Gordy Posts: 9,546
    So is the kitchen thermometer wrong can't go by the sensor. Need an accurate separate thermometer.
  • maybemark
    i don't know what is accurate or bad
    but, if you follow the chart, the sensor is right as far as the ohm reading is
  • maybemark
    Paul, I only adjusted the valve of my bedroom, this is where i have the stat, and it did increase the temp in the kitchen and it did not lower the temp in the bedroom
    even the living room is warmer, the fan kicked in behind the radiator, and the temp is 69
  • maybemark
    well, it's getting late, I need to walk the dog again,
    thanks to all that helped me
  • maybemark
    It's way to hot in my house.
    should I turn down the out door reset?
    also, I have to move the outside sensor, it's only 3 or 4 feet from the flue
  • maybemark
    the kitchen is almost 72
    the living room is 70
    the bedroom where the stat is, and i have the valve almost closed is 74
  • maybemark
    I am going to bring the shift reset down, i hope this is the proper way to bring the temp down in my house
  • delta T
    delta T Posts: 884
    Check the Offset and Differential settings under temperature settings for SH1 (assuming you are using SH1 for your call for heat). if these are too narrow (specifically offset) it can cause a high limit shut down before the boiler has a chance to modulate.
    can't remember what the defaults are but it is worth checking, Offset cannot be 0 unless it is a very very slow to respond system.
  • delta T
    delta T Posts: 884
    oh wow, probably disregard my last, didn't realize how many more posts there were. Not sure if mine will be any help until I read of this.
  • Gordy
    Gordy Posts: 9,546
    What temp is the outdoor sensor reading? This is important before you tweak anything.
  • maybemark
    28, it is too close to the flue, I am moving it now
  • maybemark
    I moved the reset down, before I saw your post, and before i moved the sensor.
    I have my coat on, and will be going through 12" of brick
  • Gordy
    Gordy Posts: 9,546
    Technically if it's colder outside than what is picked up by the sensor your supply temps would be to low, and house would be cooler if the curve is close. So you could shift more.
  • maybemark
    I just drilled the hole about 10 ft from the flue, are you saying don't use it?
  • maybemark
    The window is open upstairs, I guess it way too hot up there, I hope they turned off the valve, he has his g/f there, they sleep late, i don't want to call now
    is opening the window bad for all that I am putting into this fine tune?
  • Gordy
    Gordy Posts: 9,546
    What I was saying last night is the outdoor sensor can not be influenced by solar, and or other heat sources. It needs to be able to give an accurate reading of what the outside temperature really is. Otherwise the reset will be falsely dictating a water temp required to the system.
    I'm not there so if flue exhaust is blowing on the sensor it should be moved. I'm sure depending on wind etc. it's not always an issue effecting the sensor IDK.
    As for the tenant you may have done him a favor.
  • maybemark
    it's all moved far away from the flue
  • maybemark
    I left it alone for 15 or 20 min.
    system 109/109
    flame 86%
    outside 30
    inside 74
  • maybemark
    Where I moved the sensor, not only is it about 10 feet away from flue, but it is hiding behind a downspout
  • maybemark
    my place is so hot now
    any suggestions on what I should do?
