What's Wrong With This Picture?
New England SteamWorks
Member Posts: 1,505
For your Friday, pre-hurricane, amusement...
newenglandsteamworks.com
2
let me guess, they wanted you to service it and become responsible for it...no thank yougwgillplumbingandheating.com
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.1 -
i feel like someone was not paying the water bill and they were pouring water in to keep the boiler runningJamie Hall said:I like the funnel on the safety valve...
2 -
I think they should have raised the Hartford loop0
30-something year old Columbia or Utica.
Looks like it may have dry-fired.
And what's with the barometric on the smoke pipe when there's a draft hood?All Steamed Up, Inc.
Consulting0 -
I don’t see a draft hoodsteve0
It's mounted at the rear of the boiler. The breech connection is actually the top of the draft hood.All Steamed Up, Inc.
Consulting0 -
And all boiler manual's have pretty picture in them that show you exactly how to pipe them,
but then, you have to wan't to install it right
and be able to read.......so no.0 -
And what's with the barometric on the smoke pipe when there's a draft hood?1
Did some one bring it in from the rain?
JakeSteam: The Perfect Fluid for Heating and Some of the Problems
by Jacob (Jake) Myron1 -
I don’t see where the Hartford loop is high. The Hartford loop height is defined where the return pipe comes down and rises back up to the larger equalizer pipe on the right of the picture. If anything, assuming the lowest operating point is somewhere in the sight glass range, the Hartford loop looks a little low.EBEBRATT-Ed said:The funnel is how they fill the boiler when it can't get water through the high Hartford loop.
Poor thing killed itself trying to run. Never had a chance0 -
ha ha ha0
Everything!0
Nice rebuild project!0
It looks like it was made in Afghanistan by the Taliban! Sad facts is I have encounter alot of these in NYC and the owner dont have the money for proper service.0
WOW!!!0
why didn’t they use PEX for the HEADER?
the draft regulator is to vent out the Steam from the cracked boiler to heat the basement.
And clear off the top of the boiler for the frying pan! Fercryinoutloud 😆🤣0 -
Gas was shut off... Based on the burner/regulator/flue condition, I would argue you would die from high ambient CO before the boiler would blow up....Sadly, most if not all techs do not wear/carry a personal ambient CO meter. I have inspected many similar gas appliances in worse condition... Think disconnected/blocked/rusted flue exhaust and after a few steps down to the basement, my alarm set at CO 15ppm I quickly called the gas company for a shut off and red tag... I cannot stress enough that a personal CO meter should be required for all techs..0
Nothing wrong here folks, just move along. Oh, don't forget your flashlight and tongs.
This kind of stuff is believable.
I see horrible installations like this and worse in my working area and it will continue to go on to eternity, unfortunately.0
- 85.2K THE MAIN WALL
- 55 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 3.3K Oil Heating
- 61 Pipe Deterioration
- 884 Plumbing
- 5.9K Radiant Heating
- 376 Solar
- 14.7K Strictly Steam
- 59 Water Quality
- 49 Industry Classes
- 89 Job Opportunities
- 28 Recall Announcements
