HVAC errors in books, TV, and movies
Another novel, this one by Lee Child, had Jack Reacher syphoning gasoline out of a tank that was several hundred feet below his vacuum pump. Grrrr.
Got any other examples of HVAC stumbling that you've spotted in books, TV, or films? Love to hear them.
The steam boiler in "The Preachers Wife" looks like it was installed with PVC pipe.To learn more about this professional, click here to visit their ad in Find A Contractor.0
My favorite movie... A Christmas Story... The furnace billows soot out of the register in the kitchen... I thought he should have a smoke test for the heat exchanger. All those byproducts of burning coal right in the house.
But back then they used mercury and asbestos, so what's a little CO added into the mix anyway!
And it bangs like a steam boiler??? Coal does not go boom and furnaces don't have steam hammering noises.
There is a better chance of putting your eye out with a BB Gun, then there is of getting that heater working that way.
It is interesting though... every dumb thing that happened over my entire life happened to that kid in less than a month.
In an NCIS episode a few yews back, some guys break into their building by posing as HVAC tech's. One of them knocks the power out while working on a RTU and electrocutes himself. When they discover him, they point to the open disconnect switch on the unit and call it a transformer - repeatedly.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.3 -
I've been re-watching 'Hill Street Blues'. The basement roll call room has some sort of heating device on the wall behind and to the side of the blackboard. It appears to be fed from a main coming from above, zig-zags pipe back and forth, then tees back into the same feeder. Found an image.
I have NO experience with this stuff, but enjoy reading this forum. The family is somewhat concerned that I now point out problems like this.
In ALL spy movies, HVAC ductwork is always big enough to crawl through, easily supports a person, doesn’t make noise crawling through it, and return grills are always big enough for a person and are easily removed in seconds with a pocket knife.
Even better, all underground facilities have big ventilation fans that are 5’ or larger diameter propeller fans. This actually could be partly true in some tunnels of very large parking structures.4 -
We have to include the furnace-monster in Home Alone!
It's part boiler, part gravity octopus furnace, and I think there's actually a radiator lying on its side in it when the grill opens! I looked for a video of that sequence and found something hilarious: a Google commercial with that scene in it:
https://www.youtube.com/watch?v=JONGt32mfRY 1 -
I was watching a movie and the henchmen wanted to send poisonous gas into the house so they piped it at the outdoor condensing unit. I jumped up and yelled, Hey That won't work,"Ray Wohlfarth
Boiler Lessons2 -
My wife gets annoyed when I do that. Like when the nightly news shows restaurants in NYC building tents over their sidewalks for outdoor seating for covid protection. That won't work. One place showed they had intakes and exhaust vents to refresh the air. That's great unless you're sitting next to the exhaust vent.RayWohlfarth said:I was watching a movie and the henchmen wanted to send poisonous gas into the house so they piped it at the outdoor condensing unit. I jumped up and yelled, Hey That won't work,"
I get the eye roll.0 -
@SlamDunk I get that all the time. I wish they would spend some money and hire an expert. I watched the first episode of Man from Uncle on TV and the hero was handcuffed to a steam pipe. He kicked the pipe until it broke loose. I turned it off LolRay Wohlfarth
Boiler Lessons1 -
Has anyone seen Ted Cook's (aka "Anti DIY HVAC") Cowboys of HVAC show on YouTube?
he has released 3 episodes at the moment and has quite a few more on the way. I would recommend you all check it out, its just too funny.
here is the pilot episode.
https://www.youtube.com/watch?v=iO0XbyPfO0Q&t=21s Located in durham NC.
Don't forget that the ductwork is always, Spotless! And most of the grills have hinges on them. Makes me cringe.motoguy128 said:In ALL spy movies, HVAC ductwork is always big enough to crawl through, easily supports a person, doesn’t make noise crawling through it, and return grills are always big enough for a person and are easily removed in seconds with a pocket knife.
Rick1 -
KEVIN!DanHolohan said:How about the boiler (furnace?) in Home Alone?Serving Northern Maine HVAC & Controls. I burn wood, it smells good!2 -
Apropos for a show about nothing!DanHolohan said:The radiator in Jerry Seinfeld’s apartment is a Clow Gasteam, connected to nothing.
4 -
I especially like the Carrier equipment advertising , IIIRC, that show the furnace PVC exhaust that would blow right at the outdoor condenser.To learn more about this professional, click here to visit their ad in Find A Contractor.0
I always enjoy NYC based movies or tv shows where the nosy neighbors are snooping by listening at the gravity heating ducts in massive pre-war apartment buildings - with the register in the middle of the living floors. As we all know.... they got steam heat, sszzzziiiisss0
We can't forget The Burbs Dr. Colpek's giant Boiler ( furnace) lol0
It's even worse for computer stuff
I can't believe no one has mentioned the mother of all mechanical room brawls, the final fight scene of Commando!
https://www.youtube.com/watch?v=B9aiYqSRfCM
First of all the mechanical room of the evil villain's lair (a house on an island) is the size of the Titanic's engine room, black pipe is effortlessly ripped from walls and used as weapons, giant boilers doors are opened willy-nilly in an attempt to force the other guy inside Hansel and Gretel style, the bad guy is briefly electrocuted by what looks like a small high voltage substation (with no lasting effects) and finally, what looks like 4" or so black pipe is pulled off of the wall (nothing comes out of it) and is then hurled through the air, impales the bad guy, and pierces some sort of steam vessel which harmlessly vents off instead of rupturing catastrophically
Retired and loving it.0 -
I thought I had posted the entire fight scene and not just the final seconds. Here it is in all of it's far fetched absurd glory:
https://youtu.be/80q2fG_icUk
2 -
Nice touch in Cowboys of HVAC where one of the installers has sunglasses on during the attic install.0
My favorite is the swarm of killer bees flying into a Texas nuke's air intake followed by the nuke exploding.0
How about EVERY mech room that has steam leaking, even if its obviously a hot water system?0
Is this how people get into the HVAC industry now?
Clip from "the community"
https://youtu.be/KrcY6PXkGuE
3 -
Wait—that isn't how you were inducted?0
Impress your fellow movie goers. Tell them "oh look, that's a Deluge System".kcopp said:Not HVAC related but when someone in a movie/ tv show sets of 1 sprinkler head.... ALL the heads start raining water.
https://en.wikipedia.org/wiki/Fire_sprinkler_system#Deluge_systems
I once worked at a place where one morning after a very cold night it was raining in the enclosed loading docks. The building had a wet system. Someone should have either spec'd a dry system, or turned up the stat in the loading dock. Very expensive lesson.0 -
Not a HVAC item, but do you ever watch someone "hot wiring" a car?
Once inside they reach up under the dash and pull out the "extra" 2 feet of wire (only the switch and start circuit have that extra length of wire BTW)....cut them apart....strip ends...maybe tie 2 together, ( could be one of the wires they just cut in two)....then flash a couple more together and the car starts. They put in in gear and drive away.
But cars have had steering wheel/shift lever locks since maybe the 70's.....all these cars are newer. Some even look new enough for fob keys....how did the wheel get unlocked?
2 -
I was watching Bobs Burgers, the meat man episode with my daughter the other day and was surprised to see a very accurate boiler and water heater at the beginning of that episode.
