Steam Boiler Replacement / Qualified Northern NJ Contractors
WJK59
Member Posts: 21
So, I figured that this is the summer to replace my aging natural gas Dunkirk CSB-6D steam boiler, rather than chance emergency boiler replacement in the midst of winter. I read Dan Holahan's We Got Steam Heat! book years ago, when we bought our now decomposing romantic ruin of a farmhouse - which I still recommend to people as a good read.
So I've had four highly-reviewed plumbers with steam heating experience come out to quote the work (along with a LOT of other plumbing issues). My problem? While a couple of them asked how the existing system was working, comfort-wise, not one of them did the things that Dan suggests in seeking a contractor - checked the radiators, chimney, etc... They all just checked the existing model as a basis for sizing a replacement - and there have been one or two radiators removed over the years. One did note in their quote that new chimney lining, if required upon inspection, wasn't included (fair enough, I suppose). I should note that I have a small hot water loop presently taken off of the boiler to feed some baseboards in the back of the house - not a great set-up, I know. The two quotes I've received so far propose replacement the Dunkirk with a Utica Heating UH16 series boiler, which I think is similar if not identical to the Dunkirk. I read that Dan H is not a fan of that design (https://forum.heatinghelp.com/discussion/166852/utica-heating-brand-boiler). There were no questions about targeted efficiency from anyone.
Unfortunately, there are no contractors listed on this site that are located all that close to where I live in Randolph (Morris County), NJ. I know that doesn't mean there aren't qualified folks around, but are there any other suggestions (or referrals) to help me locate a qualified installer, beyond Angie's List / Home Adviser, etc? And any suggestions as to what units, if any, I should consider as alternatives to the Utica. For what it's worth, I'd lean toward quality/efficiency over bottom-line cost.
Thanks
Thanks
My first choice in your area would be @EzzyT . Creative Solutions Plumbing & Heating, 201-429-0223. I've worked with him, and he does great work. You could also try Gateway Plumbing and Heating -- David and John Cataneo. 973-672-1000. Another top outfit.Br. Jamie, osb
@WJK59 give me a call tomorrow morning and we set up appointment for me to take a look at your system.1
You won't find any better than EzzyT.
John Cataneo and Gateway are also first class.Bob Boan
You should have found this entry in the "find a contractor" section. Highly recommended. @Dave0176 here on the forum:
DL Mechanical LLC
732-266-5386
312 Hillside Ave, Nutley, NJ 07110NJ Steam Homeowner.
Any of the above will do the right job0
We all ought to know what we're doing. This is steam country after all.
Thanks for the mentions, guys.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0
- 120 Geothermal
