Steam Boiler Replacement / Qualified Northern NJ Contractors
So, I figured that this is the summer to replace my aging natural gas Dunkirk CSB-6D steam boiler, rather than chance emergency boiler replacement in the midst of winter. I read Dan Holahan's We Got Steam Heat! book years ago, when we bought our now decomposing romantic ruin of a farmhouse - which I still recommend to people as a good read.
So I've had four highly-reviewed plumbers with steam heating experience come out to quote the work (along with a LOT of other plumbing issues). My problem? While a couple of them asked how the existing system was working, comfort-wise, not one of them did the things that Dan suggests in seeking a contractor - checked the radiators, chimney, etc... They all just checked the existing model as a basis for sizing a replacement - and there have been one or two radiators removed over the years. One did note in their quote that new chimney lining, if required upon inspection, wasn't included (fair enough, I suppose). I should note that I have a small hot water loop presently taken off of the boiler to feed some baseboards in the back of the house - not a great set-up, I know. The two quotes I've received so far propose replacement the Dunkirk with a Utica Heating UH16 series boiler, which I think is similar if not identical to the Dunkirk. I read that Dan H is not a fan of that design (https://forum.heatinghelp.com/discussion/166852/utica-heating-brand-boiler). There were no questions about targeted efficiency from anyone.
Unfortunately, there are no contractors listed on this site that are located all that close to where I live in Randolph (Morris County), NJ. I know that doesn't mean there aren't qualified folks around, but are there any other suggestions (or referrals) to help me locate a qualified installer, beyond Angie's List / Home Adviser, etc? And any suggestions as to what units, if any, I should consider as alternatives to the Utica. For what it's worth, I'd lean toward quality/efficiency over bottom-line cost.
    Jamie Hall Posts: 27,738
    My first choice in your area would be @EzzyT . Creative Solutions Plumbing & Heating, 201-429-0223. I've worked with him, and he does great work. You could also try Gateway Plumbing and Heating -- David and John Cataneo. 973-672-1000. Another top outfit.
    SuperTech
  • EzzyT
    EzzyT Posts: 1,380
    @WJK59 give me a call tomorrow morning and we set up appointment for me to take a look at your system.
    E-Travis Mechanical LLC
    Etravismechanical@gmail.com
    201-887-8856
    SuperTech
  • Ironman
    Ironman Posts: 7,942
    edited July 2020
    You won't find any better than EzzyT.
    John Cataneo and Gateway are also first class.
    Bob Boan
    ethicalpaul Posts: 8,993
    You should have found this entry in the "find a contractor" section. Highly recommended. @Dave0176 here on the forum:
    DL Mechanical LLC
    732-266-5386
    312 Hillside Ave, Nutley, NJ 07110
    Dave0176
    EBEBRATT-Ed Posts: 20,947
    Any of the above will do the right job
  • JohnNY
    JohnNY Posts: 3,412
    We all ought to know what we're doing. This is steam country after all.
    Thanks for the mentions, guys.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
  • WJK59
    WJK59 Posts: 21
    Yep - that's why I came to this site. I had Ezzy out to the house this morning. Thanks for the referrals, guys.
    ratioJohnNY
