Natural Gas Home Stove CO2 output?
I would guess that it would depend on the quality of the combustion. I would think around 6%-8% CO2"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Do you really mean Carbon Dioxide? Which is basically harmless (well, maybe except for the climate... cue argument)? If it really is Carbon Dioxide you're after, it will be somewhere around 1 cubic foot per 1,000 BTU. But that depends too on how well the burners are adjusted; a more accurate statement would be about 1 cubic foot of Carbon Dioxide and Carbon Monoxide, combined, for each 1,000 BTU put out. If the thing is adjusted well, and the burners are good, the Carbon monoxide output should be relatively reasonable.Br. Jamie, osb
Co...carbon monoxide is the potential problem. During normal operation it isn't an issue. A Cold pan of water on the stove the cold pan will chill the flame and make some Co just until the water warms up0
Hi, Here's a bit more information and links to some more technical discussion. https://www.greenmoxie.com/your-natural-gas-stove-may-be-toxic/ I put an induction cooker in my place. Lawrence Berkeley National Labs has done a lot of research on this.
Yours, Larry0 -
@Jamie Hall said
Do you really mean Carbon Dioxide? Which is basically harmless (well, maybe except for the climate... cue argument)? LOL
He also got it right with the amount!
Natural Gas is a hydrocarbon with 4 hydrogen atoms and 1 carbon atom per molecule. HC4 (where 4 is a smaller number at the bottom of the C). If you burn 1 million BTUs of natural gas you will create 117 pounds of Carbon Dioxide, assuming complete combustion. Depending on the amount of oxygen available for the combustion process (excess air), the percentage of CO2 will range from over 10% by volume to as low as 3% per volume compared to the total volume of gasses (including the nitrogen that goes along for a free ride and steels heat from the process.)
Since the combustion on a cooking stove, happens in the open at atmospheric pressure, the amount of oxygen available for combustion depends upon how well ventilated the room is, where the stove is located
Assuming there is adequate air for combustion and that the excess air is relatively high, the percentage is probably lower than 6%, more likely down near 4% by volume of total available air for combustion.
The constant will always be 117 lbs of CO2 for every 1 million BTUs of natural gas burned. The variable is the total amount of air in the sample. That is where your percentage is formulated from.
Incomplete Combustion is a different story.
If there is not enough oxygen in the combustion air, then some of the carbon atoms will only get 1 oxygen atom and form Carbon Monoxide (CO) or just carbon alone (C). We call that soot.
CO is measured in PPM (parts per million). One PPM is 0.00001% in comparison the CO2 measured in numbers greater than 1%
I hope this info was helpful. Look at this site for confirmation.
https://www.americangeosciences.org/critical-issues/faq/how-much-carbon-dioxide-produced-when-different-fuels-are-burned
and this is a chart for natural gas combustion efficiency
https://www.gwberkheimer.com/gwb/tg.nsf/0/00aec6c526b3aa0187257a5c00641463!OpenDocument&file=1&Click=Edward Young Retired
I've seen several such "studies". Did anyone actually test the stoves in question with a digital combustion analyzer? If not, they are suspect.Larry Weingarten said:Hi, Here's a bit more information and links to some more technical discussion. https://www.greenmoxie.com/your-natural-gas-stove-may-be-toxic/ I put an induction cooker in my place. Lawrence Berkeley National Labs has done a lot of research on this.
Yours, LarryAll Steamed Up, Inc.
Consulting1 -
it says:
"Another study of preschool children in Helsinki found that those who lived in homes with gas stoves had carbon monoxide exposures that were double those of children who lived in homes with electric stoves."
but offers no evidence that exposure to those minuscule levels of co have caused any harm. as always, chemistry is about concentration. That article is a bunch of random facts without any evidence whatsoever linking any of those facts to any sort of harm.0 -
Hello, @Steamhead , I think we've had this discussion before but I wanted to follow up now with more detail. Here's an article from LBNL: https://newscenter.lbl.gov/2013/07/23/kitchens-can-produce-hazardous-levels-of-indoor-pollutants/ Brett Singer is the lead researcher studying what stoves do in homes. I met him years ago at the lab. I know they measure things with good tools, but have no idea if they tune stoves. I found his contact info: Brett C Singer, BCSinger@lbl.gov 510-486-4779 if you want to ask him directly.
My take on this is since very few heating techs carry proper testing equipment and likely even fewer stove installers do, it's going to be very hard to make testing happen. While we discuss this, children who live in homes with gas stoves are 42% more likely to develop asthma than kids who live with electric stoves. So, what's the best way (or ways) to solve the problem quickly? Just looking for solutions.
Yours, Larry0 -
Yes, I meant Carbon Dioxide. I'm trying to estimate how much cooking it would take for Carbon Dioxide to build up to a hazardous level. For long term exposure OSHA defines a hazardous level as 5,000ppm, the EU as 1,500ppm, and NIOSH as 1,000ppm. The number 1 cubic foot per thousand BTUs is good for my estimates. Thanks all.0
@Larry Weingarten , I would venture to say that, at the very least, most or all of the regulars on here have and use digital analyzers. For myself, I don't run a call without one. We even have a spare so we're properly equipped when one of the front-line units is in for maintenance. Any proper heating or appliance tech would know, or should know, analyzers and the know-how to use them are not optional when working on combustion appliances.
I'm not going to call Brett Singer. Any proper researcher knows, or should know, that in order to produce meaningful results one must eliminate all variables. In this instance, the question of whether or not a stove is in proper tune has a direct bearing on the results. If you're interested in his reaction, go ahead and direct his attention to this thread. Better yet, have him create a user account and post his response himself.All Steamed Up, Inc.
Consulting0 -
Since stoves come preassembled with a regulator I'm not sure why anyone needs an analyzer. They could just be required to be tuned properly before leaving the factory.
Unfortunately, natural gas is not a uniform product in all areas of the USA. The BTU content per cubic foot and specific gravity can vary widely.ChrisJ said:Since stoves come preassembled with a regulator I'm not sure why anyone needs an analyzer. They could just be required to be tuned properly before leaving the factory.
Back in the day, gas utilities that sold appliances could order them pre-tuned to the gas used in their areas. Obviously, that doesn't happen anymore (How do I know this? I've taken some of @Tim McElwain 's courses, where he tells how it was when he was coming up in the business- some of the best history lessons ever).
But even if a unit was properly tuned at the factory, stuff can happen between that moment and the time it's placed in service. I've seen, for example, burner tubes in packaged boilers that had been knocked slightly out of line, allowing the flame to impinge on something and cause high CO. And how did I find the high CO?
George "Firedragon" Lanthier, another educator I respect highly, writes that even if a problem shows up that was caused by something that originated at the factory, he would still fault the installer. Why? Because they didn't check it!
There is NO substitute for testing. None. Zero. Zilch. Nada. If you don't test, you're guessing. And that's just not good enough.All Steamed Up, Inc.
Consulting1 -
Hi @Steamhead , I've invited Brett Singer to come participate. Hopefully, something good will come of it.
Yours, Larry0 -
> @Steamhead said:
> (Quote)
Right now I'd settle for proper outdoor vented exhaust hoods. That even seems to be asking for too much and yet even I feel it's necessary. You're not going to get all stoves to be setup using an avalyzer, you can't even get that with most boilers even oil fired.
The amount of recirculating exhaust fans in use is insane.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Remember were not talking about something that's running for extended periods like a furnace. (The holidays may be different but I know my Kitchen windows are cracked at those times)
An Hour 2 at best!0 -
4 -
> @pecmsg said:
> (Quote)
> (Image)
Of course not, but going forward..
Water heaters usually only run intermittently as well and yet people flip out if they're not vented properly. Yet a kitchen stove / oven which can run all day long doesn't require a vent.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
But in 2020, it should be!pecmsg said:All Steamed Up, Inc.
Consulting3 -
The other side of that is, water heaters turn on and off by themselves. Most times, stoves need humans to turn them on. Not saying venting them is a bad idea though.ChrisJ said:> @pecmsg said:
> (Quote)
> (Image)
Water heaters usually only run intermittently as well and yet people flip out if they're not vented properly. Yet a kitchen stove / oven which can run all day long doesn't require a vent.All Steamed Up, Inc.
Consulting0 -
Didn't some early gas ranges have vents? At least they are running on methane or propane now instead of town gas. I'm surprised they were still manufacturing ranges in 1942.0
Most older domestic gas ranges I have seen that vented into chimneys had an integral gas fired space heater in one side, and that is the portion that was vented.
In homes originally built with coal fired kitchen ranges and central heating, the kitchen typically did not have a radiator or hot air register because the fire in the range kept the room warm.
The gas range-with-space-heater was developed for these homes. I believe they are no longer manufactured.
Many “triple decker” three-flat apartment buildings in New England, built around the turn of the 20th century with coal fired appliances, now have modern gas or electric ranges—and no heat in their kitchens.—
Bburd1 -
Wow, it seems like everyone has gone slightly off topic with the discussion changing to CO and combustion testing. The OP is obviously talking about CO2, although I think its being confused with CO....I've never heard about dangerous exposure to CO2.2 -
I'd think it's in the same boat as if you are trapped in a space and run out of air to breath.SuperTech said:> @CLamb said:
The other side of that is stoves also need humans to turn them off--something I am reminded of every time my wife forgets to!Steamhead said:The other side of that is, water heaters turn on and off by themselves. Most times, stoves need humans to turn them on. Not saying venting them is a bad idea though.
Humans give off methane after drinking Beerpecmsg said:Beer Fermenters give off CO2. Stove top's, What are you cooking?
College students then ignite that methane and end up with a sore end
Sorry ... that is off topic
Sorry ... that is off topicAll Steamed Up, Inc.
Consulting1 -
> @EdTheHeaterMan said:
> (Quote)
Off topic but I like where we are going with this. 😁1 -
> @pecmsg said:
> (Quote)
> (Image)
Is that the kitchen display at Disney World’s Carousel of progress ?
If not... somebody needs a go fund me page for a new kitchen. What kind of car do you drive?Edward Young Retired
The car you posted is certainly different than a modern one.EdTheHeaterMan said:> @pecmsg said:
> (Quote)
> (Image)
But in what way is the stove pecmsg different from a modern gas range?
Yeah........until the stove is 5-10 years old, then they often don't work right.mattmia2 said:Burners are usually more powerful and the oven is better insulated and regulated, at least on a good modern range. Oh, and the burners light themselves.
In my case, $1200 Kitchenaid which is really a Whirlpool.mattmia2 said:Just don't buy brands that are using bargain basement switches on the gas valves.
Good luck my friend. Whirlpool makes most of them and I bet it's the same switch.
> > @pecmsg said:
> > (Quote)
> > (Image)
That’s our kitchen on the East End of Long Island. Paid $1000 for that stove. It will outlast anything you buy today. Yes you need a match to light the oven and the broiler but the pilots still lights to three burners in the warmer2 -
Back to the OP's question: how much CO2 does a home stove give off? My answer: 10 cubic feet (283 liters) per hour.
My calculations: Most US gas stoves are 4 burners and an oven. The four burners are often something like 8,000, 12,000, another 12,000 and a 20,000-BTU/hour burner. The oven burner cycles on and off once the set temperature is reached. I'll do calculations for 10,000 BTU/hour burner - that's a small to medium burner near full or a larger burner turned down.
If you run it for an hour, you release 10,000 BTU. That, near enough, is the gross heat of combustion of 10 cubic feet of natural gas. Modeling NG as methane (it's not all methane, but is mostly methane), each cubic foot of methane produces one cubic foot of CO2 - the one carbon atom in methane ends up as the one carbon atom in CO2.
Ta, dah! The answer: 10 cubic feet of CO2 are produced each hour you run a typical stove-top burner. Twice that if you run two burners.
Is that bad? Worst case might be someone trying to heat their home with their stove top. If so, they might be running all 4 burners. So 40 cubic feet of CO2 per hour. And if their kitchen was small (8 x 15 x 8' high? = 960 cubic feet) and closed off from the rest of the house? Closed off like plastic sheeting taped over all the door frames? Then 40 / 960 = 4% CO2 in the air. That's not good. That's about what you exhale out with each breath. You'd feel a strong need to breath more. Your body would be retaining bicarb in the kidneys to balance out the carbonic acid.
If you were soundly asleep or so drunk/stoned as to be incapacitated, I guess it would just get worse from there. If had your wits about you, though, you'd claw your way out of there.
I'd be more worried about CO exposure than CO2 exposure because running those burners in 4% CO2 and 15% O2 would give very poor combustion of the methane and have abnormally high levels of CO generated.
In practice, someone heating their house with (any) unvented combustion device is going to reach a balance between CO2 released and air changes in the house. A tight house will reach a higher level of CO2 than a leaky house will.
Also, from long observation, grandma can have 3 or 4 burners plus the oven going for several hours when preparing Thanksgiving dinner and people aren't dying from that. Yeah, it's either an old leaky house or if not, someone will surely have cracked a window because of the heat and humidity. Or be running the range exhaust hood fan.3 -
@pecmsg "That’s our kitchen on the East End of Long Island. Paid $1000 for that stove. It will outlast anything you buy today. Yes you need a match to light the oven and the broiler but the pilots still lights to three burners in the warmer"
Sorry, not meaning to insult. Just a light-hearted dig. BTW, I really like the look. I'm kinda into the old stuff myself.Edward Young Retired
I like the old stoves, but really old refrigerators is where it's at.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
4
- 87K THE MAIN WALL
- 113 Chimneys & Flues
- 106 Geothermal
- 981 Plumbing
- 388 Solar
