Weil-McLain decided to change their mind.....!!!
NJ Master HVACR Lic# 4630
Specializing in Steam Heating, Serving the residents of New Jersey
https://heatinghelp.com/find-a-contractor/detail/dl-mechanical-llc
https://m.facebook.com/DL-Mechanical-LLC-315309995326627/?ref=content_filter
I cannot force people to spend money, I can only suggest how to spend it wisely.......
Way to go @Dave0176 ! Hopefully they learned a lesson with this maneuver and will consider their customers before making these kinds of changes. I'm sure, as with all (or most) Corporate environments, they will now have a boondogle workshop or seminar on "Lessons Learned". That's Ok if the lesson was learned!1
Any word on the Williamsons0
Same.....STEAM DOCTOR said:Any word on the Williamsons
I did tell the rep to suggest leaving the plug out of the tapping and letting us decide to use it or not, would save them some dough. I said Peerless does it like that.DL Mechanical LLC Heating, Cooling and Plumbing 732-266-5386
I cannot force people to spend money, I can only suggest how to spend it wisely.......2 -
Thanks. They should also leave plug out of right side return tapping.0
When I bought my EG back in 2011 none of the plugs were installed. Was this because it was a knockdown it did they start doing it later?
Chris you purchased the knockdown boiler, that comes with nothing installed.ChrisJ said:When I bought my EG back in 2011 none of the plugs were installed. Was this because it was a knockdown it did they start doing it later?
I cannot force people to spend money, I can only suggest how to spend it wisely.......-1 -
Thats great news Dave! Interesting how we were discussing this the other day and then the good news comes out!0
Alrighty then!!! What do we need to get changed next?
Social media pressure works!?1There was an error rendering this rich post.
I asked the rep about that too, I said wouldn’t it save the money only having to cast one right side end section. The EGH right end section is is tapped for controls. I said that kinda makes the boiler universal fit, he said not a bad idea. We shall see. I doubt it.STEAM DOCTOR said:Would also be great if they offered option of controls on right or left side. Might be a bit to much to ask for
I cannot force people to spend money, I can only suggest how to spend it wisely.......0 -
Rep told me their finishing up running the current run, then they will switch, so yes there is going to probably be a 3-6 month supply of one tapped boilers sitting in our plumbing supply’s. This is the current series 5 which will be obsoleted and probably a series 6 introduced.STEAM DOCTOR said:One big question still remaining. How many of the one riser boilers are out there? If I go tomorrow to pick up a boiler, will I be getting one with one riser tapping or two?
Ok. So that means Peerless for many of the jobs for next 6 months.0 -
That's great to hear!!!0
If anyone hears of any single supply WM-EG-30s or Williamson 075s on discount, drop me a line
Maybe that's our next move- MegaSteam with gas gun!BobC said:That they listened to the blowback is good, it's a shame Burnham doesn't do likewise.
BobAll Steamed Up, Inc.
Consulting1 -
- 120 Geothermal
