Capacitor replacement
    109A_5 Posts: 4,759
    13500 Farad. Only 4 volts. @CLamb how many Volts do you think the 5 Farad units were ?
  • bburd
    bburd Posts: 1,338
    This pic shows an old Collins broadcast transmitter at the California Historic Radio Society Museum in Alameda. Note the separate power switches for filaments on the left, and plate supply on the right.
    Bburd
    109A_5 Posts: 4,759
    edited July 30
    At 1150 pounds it is a bit bigger than consumer electronics.
    Recommend delay is 30 Seconds.
    bburd
  • ChrisJ
    ChrisJ Posts: 17,763
    500/1000 watt.
    Kinda tiny for a transmitter, no?
    WLW used to have something with a little more kick……..
    those were/are used a lot for campus and local town stations.
    PC7060
  • ChrisJ
    I always thought small radio stations were in the 50kw area?
    edited July 30
    2 of the local clearchannel stations, wjr and wwj are 50kw. wcbn-fm is about 1.5kw. wtka , one of the local ann arbor am stations (maybe the last surviving one) is 10 kw day/500w night. it is hard to find am examples because most converted to fm in the 80's or so when fm radios in cars started becoming common.
    ChrisJ
    109A_5 Posts: 4,759
    All depends on the service.
    Some of the modern AM information transmitters are only 10 Watts and are 1U high rack space.
    ChrisJ
  • bburd
    bburd Posts: 1,338
    50 kW is the US maximum for AM broadcast radio stations and has been for long time. I believe they have to be licensed as "clear channel" stations because the signal can propagate so far at night.
    Bburd
    ChrisJ
    You children are too young to remember, but back in the day there was one I remember well. WWVA in Wheeling, West Virginia. 50 kW clear channel, and at night it could be heard, pretty clearly, from Denver to Boston and on down to Houston or Miami. Truckers and trucker families used it to send messages to each other — a few country songs, then a bunch of messages ("Sue Ellen, I'll be home around 5 this morning, Big Dog" — that sort of thing). Long before cell phones. Long before CB radios (although it supplemented them — they were short range). Those were the days… as Kathy Mattea sang, 18 wheels and a dozen roses"… or Alabama — Roll on!
    PC7060
  • JUGHNE
    JUGHNE Posts: 11,653
    KOMA at 1520 in Oklahoma was 50 KW clear channel and beamed north after sunset.
    It was the go to station for the "Top Forty" and such in the 60's & 70's. Everyone had it tuned in. Then it went to "Back to the Bible" for some years and lost popularity with the crowd. Now is sports talk, just as disappointing.
    Other clear channel is KFAB, 1110 talk radio…..today to me is interesting.
    Also KSTP, 1500 was good talk but succumbed to sports talk.
    Does anyone recall Del Rio Texas? It might have been 100 KW as their transmitter was across the border in Mexico.
  • CLamb
    CLamb Posts: 352
    I don't recall but my guess is 10s of thousands of volts. The weren't electrolytic. They could discharge very rapidly.
    Being a Massachusetts kid, I hated the Red Sox, and the Yankees were my team. Early 60s I was about 10 I had my little AM transistor radio, and everyone thought I was asleep, but I was listening to the game on the NY station as clear as a bell. AM goes nowhere now.
    the clear channel stations are frequency coordinated to not interfere with each other when you get long distance propagation on the low bands. there are many stations in far away cities on the same frequencies as the clear channel stations that have to reduce their power or go off the air and possibly change their antenna pattern at night as part of the clear channel plan.
    bburd
    109A_5 Posts: 4,759
    PC7060
  • MaxMercy
    MaxMercy Posts: 632
    I'm in central CT, and I can pick up WFAN NY pretty clear (they carry the Yankee games), but it depends on where - there is SO much AM interference these days I'm convinced the federales are ignoring Part 15 when it comes to AM interference. Some streets in my small town are awash in noise, and the next street over I can pick up NY just fine. Odd.
    109A_5 Posts: 4,759
    Check the streetlights if the noise is when they are on.
    @MaxMercy
    That was my point I forgot to post about above. I am in Chicopee 10 min north of Springfield. I can't get the Yanks at all. They are supposed to be on a Hartford station 97.9 FM but no dice here no matter what radio I use.
    109A_5 Posts: 4,759
    Looking a the coverage map I would think you could receive that station, however if you are in a low spot maybe not. And their ERP is a bit pitiful.
    109A_5 Posts: 4,759
    @EBEBRATT-Ed I am probably hundreds of miles from your area and I can hear WUCS 97.9 just fine (on my computer). May work on a phone too.
    https://mytuner-radio.com/radio/wucs-97-9-espn-427934/
  • MaxMercy
    MaxMercy Posts: 632
    The noise is there on those streets all the time, but I get your point.
    My house was an AM noise pollution plant by itself (and we have underground utes and no streetlights). After having not used my 1929 RCA Radiola 62 that sits in our front parlor for a few years, I was going to listen to a ballgame one Sunday afternoon. I found out I could only get the two local stations and the rest of the dial was just loud buzzing and static. OK, it's completely unrestored so I just figured I'd get it apart in the future and restore it, so I reached for my vintage transistor radio - same problem.
    I went into my basement and turned off the main breaker and the little radio suddenly sprang to life with the dial full of clear stations, even NY. I started turning on breakers one by one and discovered some real noise makers using the handheld transistor radio as a "sniffer" - there were some motion sensing lights around my yard and driveway, and they were making a lot of noise, but the worse offender was my cable modem. Even though it belonged to the cable company, I took it apart and found the B+ filter puffed a bit, so I replaced it. Big improvement but not perfect. As I said, I don't think the feds really care much about the .5 to 1.6mhz band anymore.
    bburd109A_5
  • ChrisJ
    I just assume the SMPS used in all modern stuff including LED lights is just noisy.
    MaxMercy
    I listen to a local AM station #560am Talk radio.
    They have been advertising that the car makers?? or someone is talking about doing away with AM radios in cars.
    They want everyone to contact their congressmen.
    Wonder if anyone else has heard these advertisements??
    It would be a mistake IMHO
    MaxMercy
  • MaxMercy
    MaxMercy Posts: 632
    Correct, "modern" is the key, but it doesn't have to be that way. Careful design, component layout, and shielding will eliminate this.
    1920s-30s "farm" radios used three batteries, and batteries in those voltages are hard/cobble together to find, and of course, don't last all that long. Back in the 1980s I built a SMPS based on an RCA CTC140 TV circuit (I used the transformer from a scrapped board) to make a battery eliminator for a Zenith tombstone farm radio that was in my buddy's family for 60 years. It worked perfectly and generated very little noise. These days, you can buy a smps based eliminator for use with antique AM radios already built.
    HVACNUT Posts: 7,784
    SXM comes in Crystal clear for Yankees games. Unless I'm in a tunnel.
    the fcc doesn't have the funding to care about anything unless it affects the cops.
    a huge part of the problem is that lots of stuff is sold through channels where it is almost impossoble to stop stuff that hasn'r been tested from being sold.
    also, try finding a part b ballast for an 8ft florescent.
    MaxMercy
  • jumper
    jumper Posts: 2,625
    I was told in the nineties that inverters will replace starters and capacitors.
    109A_5 Posts: 4,759
    Inverters have been used to power Fluorescent lighting in the public transit industry since at least the 1970s. One big inverter powered all the Fluorescent lighting in a Bus. Later they went to individual inverters per tube that had the same basic size as the common AC powered ballast. They also had capacitors that failed.
    Think we need to open an electronics section on this forum
    MaxMercy
  • ChrisJ
    ratioGGross
  • ratio
    ratio Posts: 4,344
    Ok, let's rename it to "Valve and Condenser Replacement" That'll get rid of the confusion!
  • HydronicMike
    HydronicMike Posts: 471
    There's something I haven't seen in over 50 years. A guy in the back of the TV holding a mirror over the front of the TV so he could see the screen to adjust the color.
  • ChrisJ
    Ok so.
    Who knows the reason why beam power tetrodes exist vs pentodes without looking it up?
  • JUGHNE
    Can't answer that one.
    But as far as AM goes, I only had AM receivers in the early 60's. Even in the basement they worked good. No FM radio within 100 miles.
    Seldom any interference from outside sources. But today with the saturation of WIFI and even shielded computer cable signal, AM is pretty well blocked in rural areas.
    Automotive electronics will probably jam AM signals without extra design (cost).
    This has the effect of promoting streaming such as Alexa, Sirius/XM etc, not free of course.
    And AM is where the talk shows are, but let's not start any conspiracies... OK?😉
    109A_5 Posts: 4,759
    edited August 3
    It has been too long, I did know that decades ago. When I looked it up, I said, Oh yeah I remember that now.
    Its funny, but sad, when they gave up printing the books and just went with the PDF datasheets of just the device you lost a bunch of information. A scan of the whole book is better IMO.
    109A_5 Posts: 4,759
    As @MaxMercy mentioned its the power supply filtering or lack of interfering with AM. WIFI is at 2.4 GHz, probably does not bother AM much.
    MaxMercy
    automotive stuff usually isn't too bad. they have an interest in keeping interference out because they don't want their car stopping or freaking out if you drive through an rf field. that design to reject interference does a pretty good job of containing most interference too. they also don't want one part of the car interfering with another part of the car.
    when i tuned my flex 5000 to the am broadcast band on whatever random antenna it was connected to at night I saw many am broadcast stations on the panadapter. they seemed to be 100% ads for products that could only be described as scams, but the stations are there. If you are outputting 50kw you are using at least 2x-3x in power although I think the cheat the carrier in modern am broadcast to reduce the power consumption some.
    most radios included in things in the past 20-30 years have not been good receivers but just an afterthought added on. car radios tend to be better but they may have gotten worse recently as they expect you will just connect the amp to some external device.
  • JUGHNE
    I have the RC-26, It does mention beam power tubes. But I would have to read the answer and that would be cheating…….
    This book cost $1.75 in 1968. It might have been opened maybe 6 times in trade school.
    PC7060
  • JUGHNE
    My 1977 Dodge, AM only, radio was excellent for reception. Actually kept it when the van was sold.
    My 1984 Ford van radio is almost as good with the AM.
    Yes, that is a retired ambulance van I use for work…..when the mood strikes.
    Extended height I can stand up in.
    PC7060
