To solder copper tubing
I need to disconnect the water heater. To make it easier to reconnect, I want to replace the vertical h and c tubings with flexible ones. What is a good point to cut the tubing and adapt to npt? These are 3/4 copper tubing.
Some sections are painted with white or silver coatings. What is the purpose of this coating?
either they jus painted everything to make it brighter or there was a fire and the shellacked everything to seal in the odor.
so the coating has no mystery. The available flexible s.s. tubing is 18 or 24 inch. What is an optimal point to cut?
use some coarse sand paper to clean the painted section and confirm it is copper
Flex connector are available in a few different types and lengths. I prefer the copper
In seismic areas inspectors want to see flex in water and gas
Hi, I used to prefer copper, but now I get corrugated stainless connectors. They are easier to work with and don't work harden like copper. I'm hoping you'll replace that valve with a ball valve at the same time. I like to use longer lines (like 24") and form a heat trap with the excess length. In this case I'd cur both lines low and make a 360 loop with the flex.
Yours, Larry
3 -
stainless does work harden. that is wat makes it hard to drill or cut, if you don't take enough of a cut the first pass it work hardens the surface and makes it hard to cut.
A DIYer might go this solder less route. Sand the copper smooth, no nicks or deep scretches to get the best push connection.
Maybe add a thermal expansion tanks also. Plumbing codes ad tank warranties are stsrting to demand them.
Heat trapper nipples have been going int water heater tanks for probably 25 years or more.
i hate those heat trap balls. my old water heater had them. every time the pressure in the municipal system would change or a fixture would shut off you'd hear this repeated clicking in the heat traps from the basement as the water sloshed in and out. i still imagine it every time i shut off a faucet or the toilet finishes filling even though i replaced that water heater 7 years ago.
Sometimes called
a thermal trap. Intended to keep the hotter, lighter water from rising into the system. A few ways to accomplish that fuction.
The special nipples of one of these options with a long flex tube.
Living the hydronic dream2 -
that concerns me about stainless gas connectors especially ones to things that vibrate like dryers or some furnaces. i suppose brass is worse. maybe heavier wall copper?
Why does it concern you? What I got out of this was that it doesn't seem to happen with stainless.
If a furnace or dryer is vibrating / shaking enough to fatigue a stainless appliance connector, there's some major issues going on there.
No, my plot is the city water. The location is the rear of the house, about 18' downstream of the water meter. The pipe from the meter goes under the slab all the way to the rear of the house, turns its way up and out of the slab, sending water to all floors. It's always cold water with no thermal to trap, why the detour?
you're taking like 10# of clothes, picking it up, and dropping it, there is going to be some vibration. since the gas connector is usually in a loop to allow the appliance to be pulled out, there isn't much support to that loop so it is very easy for it to resonate with the vibration from the dryer. the connector is pretty thin and the work hardeing makes it more brittle.
i know brass hardens with age, try using a compression ferrule that has been sitting around for a decade without annealing it first, i wonder if stainless and copper do the same.(i realize stainless encompasses a wide variety of different alloys)
Hi, A thermal or heat trap would only be used above the water heater to prevent heat loss into the piping. I was responding to the photos of your water heater and it's piping. 😉
Yours, Larry
Besides my opinion that's it's not a problem, I'll add in how many gas leaks and explosions you hear about from work hardening appliance connectors……
It's not an issue my friend.
- 87.7K THE MAIN WALL
- 127 Chimneys & Flues
- 121 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
