Water Tanks on Roofs?
13»
    ethicalpaul Member Posts: 8,926
    they didn’t plant it. It was already there. They just harvested it
  • ChrisJ
    ChrisJ Member Posts: 17,500
    My comment is about those who complain that the modern stuff isn't as strong.
    But you can get much stronger in the same amount of time the "old way" got you yellow pine.
    That was my point which I believe Jamie understood judging by his response.
    Jamie Hall Member Posts: 27,539
    I you're ever in doubt about whether that piece is new or old growth — look at the growth rings. Old growth is much finer — maybe an eighth of an inch, often less. Plantation wood may be a quarter of inch or more.
  • AlaskaDick
    AlaskaDick Member Posts: 43
    Wood isn't what it used to be. The structural lumber supplied in these days in the box stores in Anchorage, Alaska is "hem/fir." They have some pine, but it is for trim and comes at a premium price. The 60 to 80 year-old wood that I've removed when remodeling my house was probably pine. It was more dense, had straighter grain and fewer knots and wide 1x boards were common. It smelled like pine when cut.
    From what I've read, redwood was a wood of choice used in underground water mains 100 years ago.
    mattmia2 Member Posts: 17,281
    redwood was used as decay resistant wood before pressure treated existed in areas where it was available. cedar was used in areas that didn't have redwood but cedar is much less rot resistant than redwood.
    Mad Dog_2
    And black locust is better than either in terms of rot — if you can get it. Not a common tree.
    pecmsg Member Posts: 7,218
    edited May 27
    The Locust posts in my basement were installed in 1922 and still rock hard.
    PC7060
  • jumper
    jumper Member Posts: 2,579
    In the fifties pine was used for window frames because it was hard although coniferous was called soft. At least that's what I remember. White pine was considered junk not worth logging. How stuff changes during one lifetime?
    hot_rod Member Posts: 27,759
    The HD I shop at has only “prime lumber” And they cull out any twisted , bowed, cupped, split pieces, spray the end purple and it is on the 50% off cart every morning. After two days it goes into the dumpster. This is a very high volume location with a big budget to right off culls.
    I befriended one of the lumber managers and he gave me a whole cart of lumber that was dumpster bound. It’s fine for bracing and cutting into blocking. Or firewood starter.
    I asked the local mom and pop lumberyard and they said it has to do with box stores enormous buying power.
    So it must be a store buy store lumber quality problem
    I buy the engineered lumber from the locals, LVL, I Joist, GlueLam, Rimboard, etc
    the closest lumber yards are regional now. when the university will pay $6 million for the property the local lumber yard is on, it is hard for anyone to take it over when the owners want to retire. there is a regional chain that seems to have bought up most of the local lumber yards in the region that has a small warehouse and a storefront here that supplies stuff locally from the other yards but you can't just drive over and buy anything that a lumber yard carries and come home with it the same day from them.
    In boomtown Utah we have a Boise Cascade distributor close by. I still buy through the small local guy as they deliver the long stuff to my yard.
    My last summer's project, wrestled these 22' I joist into place by myself.
    i ordered some hardietrim boards and they carried some of them like it was wood or azek and broke a couple which they had to replace.
    what was this thread about?
    PC7060
  • ChrisJ
    edited June 3
    What really bothers me is a 2x4 (or pick any dimensional lumber) is now 1.5 x 3.5 and plenty of excuses of why.
    There's some in my downstairs bathroom that I believe are 1.75 x 3.75 and then there's a few that are 1.625 x 3.625. 95% of the house is full dimension red cedar 2x4, 2x6 and 2x8, many of which are actually a hair over. I think I measured my rafters as being 2.125 to 2.25 x 6".
    But yeah, it's material needed for planing etc. Sure. Somehow a 1/4" was plenty originally for that excuse, but then it happened two more times, for the same reason.
    I can just imagine if I made a customer's parts undersized with the excuse of I needed material for finishing…… If only we could build gang saws with different dimensions to take all of this into consideration, eh? I guess we can, but only in smaller dimensions.
    /rant.
    it has been that way for like 55 years. the 5/8 stuff was from sometime around wwii to the late 60's. the 3/4 stuff i think is the first time it was standardized, i think all the random dimensions before that were whatever the local mill felt like cutting. the 3/4 stuff is usually not planed as smooth as the 5/8 or 1/2
  • ChrisJ
    We all know how important smoothness is for framing lumber and concrete forms.
    My son-in-law runs our own saw mill — and planer. What size did you say you wanted? What species wood? Up to 16 feet… and not more than 24" square!
    PC7060mattmia2JUGHNE
