The Things I See Out There
Ironman
Ironman Member Posts: 7,918
Anyone ever see an arrangement like this?
Bob Boan
PC7060kcoppmattmia2Alan (California Radiant) ForbesSteve MinnichHydronicMikeIntplm.
    mattmia2 Member Posts: 17,177
    that isn't even the brand that home depot carries
    IronmanIntplm.
    what's the flo check for? i don't see any evidence that they are making dhw with that boiler.
    hot_rod Member Posts: 27,695
    A tank for each one of the little people to the left, to watch over?
    I did see a bunch of #30 on their side on a unistrut cradle once.
    GGrossIronmanJoannie
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,616
    Old gravity system? Probably lots of expansion/water volume. As strange as it looks, easier to source #30's, then 60's or larger, when replace time comes. Lots of supply place, don't carry anything larger than #30.
    EBEBRATT-Ed Member Posts: 20,371
    " If the relief valve blows add another tank"
    I do like the 1/2" copper supply to return bypass
    The ball valve handles removed to prevent balance tampering.
    0-30 psi ASME tanks are not required. Maybe that is why they used multiples of the cheaper tanks
    Only 1 circulator so no need for a flow check. "We put those on every job but I don't know why"
  • ratio
    ratio Member Posts: 4,256
    That's the staged-admittance configuration. Charge each one a few lbs higher than the next & when one is full the next one takes over.
    4- # 30 Extrol= 10 gallon acceptance $252
    1- EX 90= 11.3 gallon acceptance $224.
    The # 30 are easy to find, not so much with the larger sizes
    Also the #30 and # 60 are the same 2.5 acceptance. You get a larger air space with the # 60
    Mad Dog_2GGrossIronman
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,630
    I've hung double tanks in a pinch, but 4??? Looks like a Bunch of bananas 🍌 😆 . Mad Dog
    PC7060GGrossIronmanIntplm.
  • HydronicMike
    HydronicMike Member Posts: 361
    The flo check could’ve been there because they used to have a coil. Or the boiler maintains temperature.
  • GGross
    GGross Member Posts: 1,935
    edited May 20
    This seems like as good a place as any to share amtrols sizing tools! It's not rocket science, and if it is you made a big mistake!
    https://www.amtrol.com/resources-rewards/selection-tools/
    IronmanAlan (California Radiant) Forbes
  • Ironman
    The local RE Michel stocks a floor #30 and can get up to a 90 in a day or two. That’s where I get them. But I also doubt that they would have had four these #30’s on the shelf.
    I wonder if they started with one and then kept adding them until the relief valve stopped releasing.
    Bob Boan
    Intplm.mattmia2EBEBRATT-Ed
  • Ironman
    The only problem is if it’s an old gravity system, then you have to calculate the water volume in the system. You can’t use the quick sizing chart. Most technicians don’t know how to do that.
    Bob Boan
  • GGross
    edited May 20
    out of curiosity when you mention a floor mounted number 30 tank are you talking about a floor mounted tank similar to an ex30 or an SX-30V? I only ask because I have seen contractors in my shop ask for a floor mounted number 30, looking for a 4.4 gallon-ish tank and they get the SX-30V which is 14 gallons (similar to EX90) and end up paying more than they should.
    I am surprised the local supply house doesn't have 4 on the shelf! even with Amtrol prioritizing shipments to big box stores we still have around 50 or so in each branch here.
  • Ironman
    edited May 20
    An SX30.
    RE Michel branches get a supply truck from their distribution center twice a week, so the bean counters don’t want to leave a lot of things on the shelves of the branches that doesn’t move quickly.
    There’s a fair amount of hydronic work around here, but this is definitely not boiler country like the North East.
    Bob Boan
    GGross
    The only one I remember is that 6" pipe holds about 1.5 gallons /foot.
    i was never one for the 'quick pick charts". I always wanted to calculate my own stuff. I don't like figuring pipe and fitting resistance by multiplying x 1.5 for fittings either.
    Mad Dog_2
  • PC7060
    PC7060 Member Posts: 1,823
    I cheat, drain down the system and read the before and after on the water meter! Normally have to because there’s typically no isolation valves on those old system.
    Ironman
    you can probably be off by about 30% and still pick the right tank, especially if you don't cut it too close to 30 psig in your calculation. You would have to be closer if your structure is 4+ stories.
    Ironman
