The Things I See Out There
that isn't even the brand that home depot carries
what's the flo check for? i don't see any evidence that they are making dhw with that boiler.
A tank for each one of the little people to the left, to watch over?
I did see a bunch of #30 on their side on a unistrut cradle once.
Old gravity system? Probably lots of expansion/water volume. As strange as it looks, easier to source #30's, then 60's or larger, when replace time comes. Lots of supply place, don't carry anything larger than #30.
" If the relief valve blows add another tank"
I do like the 1/2" copper supply to return bypass
The ball valve handles removed to prevent balance tampering.
0-30 psi ASME tanks are not required. Maybe that is why they used multiples of the cheaper tanks
Only 1 circulator so no need for a flow check. "We put those on every job but I don't know why"
That's the staged-admittance configuration. Charge each one a few lbs higher than the next & when one is full the next one takes over.
4- # 30 Extrol= 10 gallon acceptance $252
1- EX 90= 11.3 gallon acceptance $224.
The # 30 are easy to find, not so much with the larger sizes
Also the #30 and # 60 are the same 2.5 acceptance. You get a larger air space with the # 60
I've hung double tanks in a pinch, but 4??? Looks like a Bunch of bananas 🍌 😆 . Mad Dog
All that work and no valve w/drain to isolate the tanks. I don't think they do much service work.
Also, no support for the tanks. Those are two of my pet peeves: isolation and support.
Insulation would have been a good idea.
Two btu per sq ft for degree difference for a slab0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
