The Things I See Out There
what's the flo check for? i don't see any evidence that they are making dhw with that boiler.
Old gravity system? Probably lots of expansion/water volume. As strange as it looks, easier to source #30's, then 60's or larger, when replace time comes. Lots of supply place, don't carry anything larger than #30.
" If the relief valve blows add another tank"
I do like the 1/2" copper supply to return bypass
The ball valve handles removed to prevent balance tampering.
0-30 psi ASME tanks are not required. Maybe that is why they used multiples of the cheaper tanks
Only 1 circulator so no need for a flow check. "We put those on every job but I don't know why"
That's the staged-admittance configuration. Charge each one a few lbs higher than the next & when one is full the next one takes over.
I've hung double tanks in a pinch, but 4??? Looks like a Bunch of bananas 🍌 😆 . Mad Dog
4 -
All that work and no valve w/drain to isolate the tanks. I don't think they do much service work.
Also, no support for the tanks. Those are two of my pet peeves: isolation and support.
Insulation would have been a good idea.
Two btu per sq ft for degree difference for a slab8 -
The flo check could’ve been there because they used to have a coil. Or the boiler maintains temperature.
i think i see some hanger iron in there
In my best David Attenborough:
"Here we see thermal expansion tanks in their natural habitat. While tanks are usually solitary creatures, here we see the rare exception of a strong family pack, signifying that the individuals determined their survival would be better as a pack, rather than on their own"
11 -
The local RE Michel stocks a floor #30 and can get up to a 90 in a day or two. That’s where I get them. But I also doubt that they would have had four these #30’s on the shelf.
I wonder if they started with one and then kept adding them until the relief valve stopped releasing.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.4 -
out of curiosity when you mention a floor mounted number 30 tank are you talking about a floor mounted tank similar to an ex30 or an SX-30V? I only ask because I have seen contractors in my shop ask for a floor mounted number 30, looking for a 4.4 gallon-ish tank and they get the SX-30V which is 14 gallons (similar to EX90) and end up paying more than they should.
I am surprised the local supply house doesn't have 4 on the shelf! even with Amtrol prioritizing shipments to big box stores we still have around 50 or so in each branch here.
An SX30.
RE Michel branches get a supply truck from their distribution center twice a week, so the bean counters don’t want to leave a lot of things on the shelves of the branches that doesn’t move quickly.
There’s a fair amount of hydronic work around here, but this is definitely not boiler country like the North East.
Bob Boan
You can choose to do what you want, but you cannot choose the consequences.2 -
@Ironman dang, even with trucks coming in every few days it still seems like 4 gallon tanks would be a pretty common item. But then again I very seldom visit a local supply house so maybe mine have slim pickings as well, which would resonate because I regularly have local plumbing/HVAC guys coming to me for tanks, pumps, valves, flanges, etc. It's been many years since I had less than 5 of anything on the shelf; ironically enough I just took delivery of a pallet of expansion tanks yesterday with 40 #15 and 15 #30.
With that said, this 4 pack seems to have done its job since those tanks are upward of 20 years old
When the bladder psi is 4#, you need a lot of #30s.
you guys that commented should do stand up comedy.
Seeing that Rube Goldberg mess certainly makes me happy that I have a single 15 gallon Bell & Gossett steel compression tank hanging in the ceiling of my laundry room and assures me again I was sane in following Mr. Holohans advice in his wonderful books; Classic Hydronics, Pumping Away and How Come using a pump module for my coal stoker boilers "air management" system.
It’s neat to see so much threaded pipe. Usually see a lot of copper on an installation like this that isn’t too old. The flow control valve might be needed to stop gravity flow from higher points in the building. There are three returns so maybe one or two come from higher up in the building. The lack of isolation valves for service is unfortunate and that 1/2” bypass probably does very little.
Saw this yesterday on a job we installed in 2000. Another contractor added it onto the return piping from a radiator system.
Two btu per sq ft for degree difference for a slab2 -
Cue the "Twilight Zone" theme………………
Consulting0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
