? actual difference between hot water heaters from supplyhouses and big box stores
mikedo
mikedo Member Posts: 301
does anyone know what the difference between a rheem or aosmith water heater is if bought at a big box store
    hot_rod Member Posts: 27,094
    The label!
    On ocassion I have found a handful of different labels in the bottom of the box. Assembly must have been confused as to which brand they were supposed to be packaging that day.
    The tanks with longer warranties are the same as the 5 or 7 year. They are just playing the insurance game with the extra $$.
    Some brands and models still use brass drain valves, upsell models may have two anode rods, nicer nipples for connection.
    ethicalpaulEdTheHeaterManPC7060
  • Intplm.
    Intplm. Member Posts: 2,917
    Some gas fired water heaters may have different accessories. Gas valve/burners might be different from one to the other. Some thermostats on electric water heaters have been found to be different as well.
    The tanks, for the most part seem to be the same on residential water heaters.
    The Bradford White water heaters seem to have an advantage in there quality so far as I can tell.
    mattmia2 Member Posts: 16,058
    edited March 2025
    Sometimes they will remove or cheapen some features to meet a specification and use a unique model number for the batches sold to large distributors/retailers.
    the different labels are probably so when different marketing operations sell different "brands" whoever they hire to do the actual work can slap the label that matches the "brand" that they sold on it.
    you should put them all on or leave them in the envelope with the instructions.
    i looked at a home depot commercial catalog that had like key cards and soaps and things like that with all the different brandings of some motel chain.
    Having been to a number of WH tank manufacturers over the years, I have never seen different tanks being made for residential sized DHW tanks. I agree features, insulation, etc, and the warranty is where you may see differences.
    I think tanks have been engineered down to a 5-7 year life expectancy.
    We had a nice solar indirect built years ago. Heavier gauge tank and heads, thicker glass coating, 2'' injected foam, 1-1/2" coils, even a thicker metal outer jacket with powder coating. But the market just didn't see the extra $$ value.
    If i'm going to spend more on the tank itself i'm going to go with stainless or plastic.
    Greening
    All tanks fail from one thing or another. Not all places in the country can meet the low chloride numbers that stainless tanks are listing. But, how many actually check or know that? Do you know your chloride levels?
    Chloride levels spike during winter months with all the deicers being used thees days, so you need to check levels throughout the year,
    Screenshot 2025-03-02 at 1.34.01 PM.png Screenshot 2025-03-02 at 1.34.27 PM.png
    LRCCBJ
    i know what the utility tells me they are and they are slightly above what the manufacturer specifies. different manufacturers have different specs, not sure if it is different alloys or different interpretations of the risk or maybe a little of both.
    I think legally they have to make the water quality report available. Our city does it in a yearly mailer, and it is online. However it is a once a year example.
    I know turbidity changes, I see it in a white bathtub that my wife uses 🙄
    If I were still in the install business I would invest in a chloride specific test kit. If you are not testing you are guessing. I think a titration test kit would work, but I would check with Hanna. If so 60 bucks for 110 tests is a bargin.
    Chloride levels apply to stainless boilers also.
  • jumper
    jumper Member Posts: 2,513
    I've seen guys returning hotwater heaters at HomeDepot. States NonReturnable in big letters. So who ends up with that returned item?
    I doubt eating returns hurts HD much. My local HD trashes good lumber every week. My HD guy tells me that have a $5000 a month scrap budget.
  • ratio
    ratio Member Posts: 4,203
    I've gotten more than one used-then-returned item from the local big box store, as well as obviously-broken and missing-pieces—but the packaging looked ok. It's to the point that I write on the box with a big marker "DAMAGED" or "MISSING PIECES" if I take anything back.
    I gave up trying to figure the ratio of shady to incompetent once I realized that I don't care what it is.
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,810
    Generally, the consumer stores specify a cheaper price from the manufacturer. The manufacturer often cuts back here and there to grant that price. You'll see an exclusive "HD" model number and maybe a plastic drain valve, a single anode, perhaps a less costly control.
    Most obvious of this were Delta faucets. The Home Depot line was Chinese junk: Plastic spigots, plastic handles. The supply houses carried a higher line that was US-made plated brass at three times the price. Now it seems they are all pot-metal or plastic Chinese junk.
    We agree with Intplm that Bradford White is our go-to for water heaters. They're also pretty costly. The gas ones we install usually see 12-15 years, but that's with very good water quality. We only buy from local supply houses. We call and the tank is usually delivered in an hour.
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,036
    Hi, One other thing that happens with the warranty, is some places give a pro-rated warranty rather than a full warranty, like tires. So if they tell you it's warranted for 12 years and it leaks at eleven, you get only one year, or 1/12th of the cost of the tank back. It's VERY important to read the fine print.
    Yours, Larry
    edited March 2025
    that was why i didn't succeed the first time i tried to install a faucet when i was like 12 with the peerless install your own faucet. the box had been opened and was missing the instructions and some parts but i didn't know that. i think it was worse with chain stores like meijer in the 80's when that happened. there used to always be that one box that was beat up and taped back together on the shelf. now they usually either send it back and sell it as refurbished or throw it out.
    note that peerless used to be the branding of the cheaper delta/masco stuff, plastic body, plastic ball
    EBEBRATT-Ed Member Posts: 19,914
    A co worker told me years ago he was talking to a DeWalt rep who told him the HD stuff had plastic gears and was not the same as you could by elsewhere.
    Don't know it it is true.
    I suspect some MFG dial it down cheaper to sell to HD
    and I think others sell there standard products to HD if the price is right.
    hot_rodLong Beach Ed
  • ratio
    I can tell you for a fact that the Lowe's version of the Honeywell TH8110 thermostat has (or at least had, I haven't checked since I originally noticed) a different casting of the case, made with different plastic, than the supply house version. Who knows what other changes have been made.
    Long Beach Ed
  • Tom_133
    Tom_133 Member Posts: 969
    this is what we experienced with a superhawg many years ago. It blew up drilling big self feeders, and since we didnt pay for it (boss did) we tore it apart and found nylon gears, very hard nylon, but not steel. We returned and went to the local tool shop and paid the extra… it's still chugging.
    Tom
    Montpelier Vt
    Long Beach Ed
  • Intplm.
    I have found that in some cases they do dial it down. Heck, they have even created a line of cordless power tools. Remember the first Ridgid cordless power tools? I went through that orange tool set within a year. The things fell apart. They were not and or are not the Ridgid quality product that many of us have come to know.
    When sears (and all of the huge department stores) they at least branded it with their name so you didn't expect it to be exactly the same.
  • jumper
    Anybody here ever had a customer who goes through your invoice comparing your parts' prices with HomeDepot or CanadianTire?
    pecmsg Member Posts: 6,898
    I’ve had customers do that. There told call someone else. You can’t afford me!
    ratioIntplm.Ironman
  • GGross
    GGross Member Posts: 1,782
    "You can go pick up the parts from home depot and I will bill you for my time while I am here waiting for parts, when I run out of parts you can go get more and I can bill you my hourly rate while I wait here. yes I have the parts on my truck but they are too expensive for you so you will have to go buy them all from home depot as I need them. Oh that fitting is malformed? I didn't supply that you will have to take a trip back to home depot and pay my hourly rate while I sit at your house waiting. The water heater is defective? I didn't supply that you will have to work that out with home depot, no I will not take it back for you because I don't own it and cannot take the liability of it being in my vehicle, my water heater was too expensive for you remember?"
    I had a customer who worked for a guy like that. Customer got his own toilet and forgot to buy a supply tube, charged the customer a whole hour labor while he sat at the job and waited, he had the parts on his van but they were about $2 more than home depot and the customer wasn't going to get ripped off!
    Ironmanmattmia2PeteA
  • jumper
    Shrewd customer waits for job to be finished then quibbles over parts' prices. I don't mind installing customer's appliance but I dislike being phoned back when customer is unhappy with the appliance. What am I supposed to say?
  • GGross
    Make sure you have a written contract and have clearly explained to the customer before installing that any warranty that you offer is only for your workmanship such as failed solder connections, leaky threaded connections, and only connections you make. Any issue with the appliance itself is not covered under your warranty and will be billed at your normal labor rate. Or if that feels a bit too rude just charge enough upfront to cover a certain number of return visits on each job and use the easier jobs to supplement your labor on the problematic jobs
  • jumper
    School Board is generous. Pays semi-diem for attending meetings. Boiler was chosen by professional. At least officially. Nobody faults installation. I want repeat business but it's not my job to figure out how to satisfy complaints. Looking back it was good fortune that I was uninvolved in acquiring boiler.
  • GGross
    For commercial, as long as you installed it correctly, per manufacturers instructions, and the issue lies with the product itself and not the install, I would politely direct those calls to the engineer or the individual who specified the equipment. Most jobs like that have all kinds of stipulations stating what the installer is responsible for and equipment selection is generally not one of them. They would call that "design build" or something similar. You may need to have a sit down with them to explain what your responsibilities are in the matter, and that if a service call falls out of line with that they may need to pay your hourly rate. If you signed something stating a 1 year warranty for your workmanship, politely point out to them that equipment selection does not fall in as part of your "workmanship" you did not specify the unit. The Specifying engineer has generally worked into their price some buffer for dealing with this kind of call, the same way you work in some extra to cover your mistakes (if made) there is no reason you should have to provide free labor for a problem that someone else should be dealing with.
    CLamb
  • jumper
    One can be as polite as Jesus; the guy who states that the obvious solution is for custodian to fire boiler sooner and hotter for cold mornings will never get another job at that school board. May be black listed at others. I was willing to detach and pack up; suppliers were willing to replace. SpecifyingEngineer cannot agree. Neither can the School Board engineer. So everybody periodically sends a representative to discuss issue. Eventually whoever is complaining becomes accustomed or forgets or moves on to work elsewhere. The policy was to replace boiler every seven years.
    Long Beach Ed
    Why does bringing the system out of setback require a person…
  • Long Beach Ed
    edited March 2025
    As engineers who specify this stuff, we make it very clear to the customer exactly who is responsible for what.
    All too common, we get called back into BIG jobs where the fitter decides to completely deviate from our specifications and supply different better equipment that does not work.
    Our contracts spell out this detail clearly and specifically, and we read this part to the customer explicitly.
    I can't count the number of times I've opened the boiler room door for a final inspection and said "what the … is this?".
    the sales person doesn't understand your specification then they throw it out and put what they think it should be in their system and the installer never sees the actual specification.
