Recip / Sawzalls
Wondering what everyone's favorite saw is these days?
Are you still using plugin saws or battery?
Both. All Milwaukee. Depends how much control I need.ChrisJ said:I just broke the spindle on my 13a Milwaukee.
Are you still using plugin saws or battery?1 -
delcrossv said:Plug in Milwaukee. I also have a Porter Cable Tiger Saw as a backup- also plug in.STEAM DOCTOR said:
I have a lot of 4" cast iron I'm cutting out.
I won't be in a rush and won't be getting it all done even in a weekend but I'm concerned a battery saw is going to annoy me the entire time.
But I can't help but wonder considering how strong the drills are now.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
I would go with battery unless you're really using it for heavy duty work. I really like my other makita battery stuff. I have miwaukee battery stuff at work and it is probably fine for homeowner use but makita stuff is heavier duty. the difference between just picking it up and using it vs having to get out an extension cord then put it away for just a little thing is night and day.0
Everyone uses battery now extension cords are obsolete LLO
8 years ago, when the big Casino build was going on here in Springfield there were hundreds of tradesmen on the job. You never saw so many battery tools in your life. Mostly Milwaukee. Extension cords may not be a problem in your home but with hundreds of people on a job and OSHA lurking..............
That being said I hate it when batteries run down. If your cutting 4" CI I would use a cord, but I am old I like cords.
One very handy tool is the Milwaukee "hackzall" nice and light and great for cutting a pipe out of a fitting but you wouldn't want to cut 4" CI with it1 -
Do you have a battery system now? If you have 18V Milwaukee the 2720 is a beast of a cordless. Heavy and heavy duty. Have at least one spare battery ready to go, if you are doing continuous cutting.
I'd guess Dewalt or Makita have similar power if that is the system you have.
Sharp blades make a huge difference in cordless saws battery life. Of any type.Bob "hot rod" Rohr
Living the hydronic dream4 -
I have a few DeWalt 20v batteries.hot_rod said:Do you have a battery system now? If you have 18V Milwaukee the 2720 is a beast of a cordless. Heavy and heavy duty. Have at least one spare battery ready to go, if you are doing continuous cutting. I'd guess Dewalt or Makita have similar power if that is the system you have. Sharp blades make a huge difference in cordless saws battery life. Of any type.
I was considering this
Definitely corded. Unless you have tight spots. I use Milwaukee and am very satisfied. Get Diablo heavy metal blades. Will cut like butter. Worth every penny. You can probably get away with one blade for entire job.ChrisJ said:delcrossv said:Plug in Milwaukee. I also have a Porter Cable Tiger Saw as a backup- also plug in.STEAM DOCTOR said:
But I can't help but wonder considering how strong the drills are now.4 -
I never mind investing in tools. I suppose my main question is does it just end up heavier and bigger for no reason 90% of the time.
Im a Milwaukee guy (but was impressed once with a Makita cordless with a reasonably worn blade on quite a few tree branches , that thing just kept cutting).
So definitely get a Milwaukee.
I hate dragging around cords, stepping on them etc
Currently in building maintenance.0 -
Can't really compare. I have been using the 15a for quite a while. Don't feel the weight at all. Wouldn't even consider that I factor. If you are strong enough to work on 4" cast iron, than I doubt you will notice that you are even holding the sawzall. And for what it's worth, I am not a big guy at all. Quite the contrary.ChrisJ said:
I never mind investing in tools. I suppose my main question is does it just end up heavier and bigger for no reason 90% of the time.0 -
6538-21 is the only active SKU for a corded "Super Sawzall"
15a, 1-1/4" stroke, orbital action, variable speed trigger, and speed dial.
The only other active corded sawzall from Milwaukee is the
6509-31
12a, 3/4" stroke. thats it
Discontinued models are still available all over the internet, but officially- those are the only two corded sawzalls left. Many did like the 13a's
What you will want depends on what you're cutting.
Heavy demo definitely the super sawzall, when speed is the focus. orbital action is tremendous in wood cutting.
it can do it all as you can dial it in to whatever the situation needs.
Fine cutting and smaller diameter pipe the regular 12a is good enough. it can do everything the 15a can, just slower.
Plumbers tend to grab the cordless Hackzall way more often. Lighter, more control, and fits in tight spaces.
The purpose of the Diablo Amp'd blades is to get better value (last longer than the carbide). But most burn it out just the same and isn't worth the extra cost. If you are the type to use blades with care (lubricate when needed, control speed), then go for it.
From what I see, no matter what blade it is, it's turn it up full blast, full speed, no lubrication, cut back to back nonstop, notice subsequent cuts are taking a bit longer (heat), then toss the blade.
When the bosses tell me to stop giving his guys the Amp'd version, I completely understand.0 -
The Diablo blade I think played a part in my mistake tonight. 100% my fault, but.STEAM DOCTOR said:And if you are using the proper blades,.you will barely be holding the sawzall anyway. Those Diabolo blades are unbelievable. Heavy metal carbide. They are available on supply house or Amazon. They also have the amped which I think are a bit better
I'm trying to cut the pipe out of a very tight spot in a wall and trying not to poke thru the other side of a plaster wall. The issue is I think the pipe is next to a stud, which I didn't notice at first because it's behind lath and I think the blunt end of the Diablo blade was hitting the inside back of the pipe. Either that or that and the stud.
Trying to get the pipe cut out fast as I had a friend on the roof ready to pull the pipe out and it started pouring out (bad planning on my part) .
Either way i failed the task at hand. Now I wish I had just used the 9" instead of 6" blade and just fixed the plaster.
Battery powered Saws have come a long way but still mostly stay in their boxes. Cordless, hand drills, yes, Sawzall can't keep up when you're rocking & rolling. Diabloes are insanely good..Mad Dog 🐕3
For me it comes down to dealing with cords, plugs, trip hazards, or battery change outs throughout the day
I would say the power is about equal now a days.
I built my entire shop with cordless tools a couple years back. Drills, saws, nailers, laser level. Its nice to be cord free on ladders, and scaffolds. Roof framing and sheathing is nice without hoses and cords.
if I had to cut a steel I beam with a saw, a corded tool would be a better choice
Its good to own both types. Corded tools are dirt cheap at pawn shops 🤫Bob "hot rod" Rohr
Living the hydronic dream2 -
I like using both corded and cordless. Depends on the task.
As Hotrod said, used corded tools are a bargain. I've picked up a couple dozen made in USA Milwaukee, Porter Cable, and Skill at estate sales. Including a Milwaukee 75th anniversary sawzall , drill, and toy truck.
Believe me, I don't need a cord to trip over either, but when you have to drill dozens of Shields in to concrete of a lot of Sawzall cuts, I dont have to cone down off the ladder or lift every 6 times. Mad Dog 🐕1
I have been using Milwaukee brand Sawzall's almost exclusively for the last forty years. About ten years ago we switched from corded to cordless. Admittedly, we are not easy on these saws. We have had four different models in the last few years, not one of them has worked as designed for more than one year. We typically use them on boiler demo jobs, so there is regularly some standing water in the pipes.
We switched to using band saws whenever possible to reduce the vibrations and we get a lot more cuts per blade. I agree with others regarding sawzall blades, I would rather spend the extra money on good blades as compared to switching blades after two or three cuts.2 -
I agree with @ScottSecor about band says being superior to cut with and when you know what you are doing and don't twist the blade you can keep the same blade for a long time. But you have to have enough room to maneuver it around the pipe and you get a smoother cut and less vibration on your arms.
But a sawzall will do anything a band saw can do just not as well.
In the case above the sawzall is the best choice for 4" CI in a tight spot.
The best way to cut CI is with a grinder and a cutting disk...like cutting butter.2 -
After all of the comments etc...
I think I'm going to stop and pickup a 15A super sawzall.....
Just seems like the right move.
It's going to make things even worse in this tight spot, but it'll make the rest of the work easier.
Harbor Freight rotating head sawzall with quick change blade. Well worth the 20 dollars when on sale. Throw it away if you break it, but I found it surprisingly tough cutting tree roots in the dirt . Cheaper than replacing chain saw blades.0
Why not a cheap soil pipe cutter from harbor freight or Amazon. A lot quieter and cleaner. My local home depot rents them...Otherwise, corded and battery DeWalt works well for me.0
Unless it is completely trashed you could just get the part that broke in your old sawzall and fix it and save your money for the cordless version for everything else.0
I haven't used my Ridgid snap cutter on the past 3 jobs. Just easier to use the Sawzall with Diablo blades.SlamDunk said:Why not a cheap soil pipe cutter from harbor freight or Amazon. A lot quieter and cleaner. My local home depot rents them...Otherwise, corded and battery DeWalt works well for me.
If I had to do a whole house, then maybe. But for a couple of cuts, Sawzall all the time.Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1 -
I've had my Supersawzall 20 yrs. Diablo blades. That's all I'll buy now. Mad Dog 🐕1
For what it's worth the 15A SuperSawzall I bought yesterday says right on it "Professionally made in China by Milwaukee"Mad Dog_2 said:I've had my Supersawzall 20 yrs. Diablo blades. That's all I'll buy now. Mad Dog 🐕
I guess that's supposed to sound better than "China" or "Made in China".
My dad still has a "Heavy Duty Sawzall" he got back in the late 80's that apparently is 4 amps and all the power he's ever needed. It has a metal case.
2 -
Remember in the 1990s when China Renamed a manufacturing town "USA" so they could say Made In USA 🇺🇸? Mad Dog1
That was Japan and the city was named Usa long before WWII.Mad Dog_2 said:Remember in the 1990s when China Renamed a manufacturing town "USA" so they could say Made In USA 🇺🇸? Mad Dog
2 -
Most of the Milwaukee stuff is good but not as good as it used to be. My old boss had a Millwaukee "hole Shooter" 3/8 corded drill with a metal case that he bought in 1946. When he died in 1988 it still worked just as good. I bought one in 1977 3/8 corded 1200 rpm. Mine is reversable his was not It will break your wrist if you're not careful. Had it apart for new grease and a new cord and maybe a new chuck I forget. Of course with the battery tools it doesn't get much use now. Has a metal case and plastic handle. Cost me $75 new I thought that was outrageous.1
BTW, you can press the chuck apart and clean and re-lubricate it. Usually they aren't worn, they are just dirty.0
I guess that's supposed to sound better than "China" or "Made in China".1 -
I guess that's supposed to sound better than "China" or "Made in China".Trying to squeeze the best out of a Weil-McLain JB-5 running a 1912 1 pipe system.1 -
For cutting pipe You need one that is straight and not orbital (for wood) or just buy a cordless band saw….so much superior.0
Anyone still .own Milwaukee Hole Hog? Aka The Widow maker, Jaw Breaker, The Pig 🐖? Up on an 8 foot ladder drilling floor joists with a 4.5" Wood bit....mad Dog2
- 50 Industry Classes
