Just to stir the pot...
  • SlamDunk
    SlamDunk Member Posts: 1,757
    @Jamie Hall , Henry Fordlobbied heavily for government to build roads for his automobile. Goodyear lobbied hard to get rid of mass transit "trollies". Government is always involved.
    ethicalpaulMad Dog_2
  • Hot_water_fan
    Hot_water_fan Member Posts: 2,197
    Insulation of the building only affects the size of the unit installed and does not determine if an air-air heat pump will heat the building to 70 degrees in a cold climate.
    I doubt we’ll come to an agreement on what a cold climate is, but my heat pump can do this into the single digits. I haven’t experienced anything colder than that though.
    Even if an air to air heat pump cannot meet the load at some temperature, the technology works! Using a fossil backup is a great pairing. It is not a binary.
    SlamDunk
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,267
    No doubt it's very good technology and that it works in alot of situations.  What I don't care for is the DAMNING of fossil fuels and traditional heating methods and systems that some zealots want to rip all out. Not saying you.  The Orwellian Big Brother Tactics are alarming.  They're ready to throw put the proverbial baby 👶 with the bath water..Let's take this slow 🐌...Mad Dog
    SlamDunkWMno57SuperTech
  • Hot_water_fan
    @Mad Dog_2 maybe you’re seeing something different than I am, but I’m seeing people advocating for replacing ACs with heat pumps when they break. No big brother, no mandates, just a multi decade process. Similar to how manual transmissions have vanished - it happened over decades.
    SlamDunkGGross
    Jamie Hall Member Posts: 26,168
    So long as this statement is true, I'd agree with you. Unhappily, at least in some countries, it isn't true (the UK, for example), where it is replace (not keep the backup -- even fireplaces are bow prohiibited in some locations). How long it will remain true in the US is unknown...
    Mad Dog_2
  • WMno57
    WMno57 Member Posts: 1,408
    "So who is to blame for the death of the manual transmission pickup truck? The truth is that increased engine torque, government regulations, and the capabilities of the average driver are all partially responsible. "
    https://www.motorbiscuit.com/who-killed-manual-transmission-full-size-pickup-truck/
    "Back in 1997, the vice president of engineering technologies at Dodge Ram and Jeep, Bernard Robertson, offered some prophetic words to the LA Times: “Emissions standards are going to tend to make manuals a challenge…We may not offer a manual in California because of the more stringent emissions standards out there.”
    The 2018 Cummins-powered Ram truck did have to meet some pretty stringent emissions requirements. For FCA’s combustion engineers, meeting emissions with an automatic truck wasn’t as tricky. They simply adjusted the truck’s shift points to make sure the engine idled below any highly-polluting RPMs. No coal-rolling allowed.
    But obviously a manual transmission truck was a bit more of an issue. This is because the driver could simply downshift, floor it, and rev the engine.
    In addition, vehicles need to meet “pass-by noise requirements.” Meeting these requirements in manual vehicles with loud V8 or diesel engines often requires retuning those engines’ torque curves.
    An easy shortcut for Ram to meet these government requirements was to simply detune the Cummins engine in its manual transmission trucks. Could Ram and the government have agreed upon a full-powered diesel Ram with a stick shift? Probably. At most it would have needed a different exhaust system or control unit.
    But meeting emissions regulations and noise requirements costs a ton of money. So from Ram’s point of view, pouring money into a manual transmission truck that can meet emissions requirements despite lackluster sales would have been a poor investment."
    Solid_Fuel_Manreggi
    hot_rod Member Posts: 25,327
    Its no secret that the hydronic and radiant industry in the US has been declining. For years now. Mini splits have had a lot to do with that trend.
    Heat pumps, air to water and water to water have the potential to save or possibly grow the hydronics industry.
    With hydronics in the heat pump picture you can glue, solder, weld, press, groove, thread to your hearts content :) So the trade stays in the game.
    In new construction HP are certainly possible with the key being low loads and low water temperature distribution. As demonstrated in this upstate NY home recently built.
    We will cover this more with some actual examples in next months Coffee with Caleffi it is such a hot topic.
    ethicalpaulHot_water_fan
  • WMno57
    edited August 2023
    provision to run during 10 day grid failure to be included
    https://www.youtube.com/watch?v=7q32cTB-8pw
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    edited August 2023
    Yeah....now I can't even get a manual in pretty much anything. Lame..... I can get better mileage and have more fun in a manual. Always. But they ain't as clean due to not having control of shift points and engine load at certain RPM.
    Is this still the case compared to 10 speed automatics with 3 top gears as overdrive? The engines are always in the best operating condition with such a wide spread of gears.
  • ChrisJ
    ChrisJ Member Posts: 16,841
    clammy said:
    I ve been trying not to comment on any thing which may have any political over tones and the whole save the planet going green air to water heat pump garbage and end of fossil fuels and all grid all I can really think and say is control and who gonna have it ,it certainly will not be the people on the end of the transmission lines . It does not take much adjustment of hertz on a grand scale to get people in line w lowering their thermostats just lower the hertz .
    Peace and good luck clammy
    I don't understand Clammy?
    Just lower the Hertz? What does that mean?
    Glad to hear from @clammy . I always enjoy what he has to say...
    And yes he has a point on the hertz. If you lower the frequency -- hertz -- on the grid you will reduce the speed of almost all the motors on the grid by the same amount, reducing the power consumption. If you really get going and reduce the voltage at the same time, you will also reduce the power consumption. It's a bit tricky, as the grid is so interconnected, but it can be done -- and without getting into details, the more renewable energy connected, the easier it is to do.
    Now lowering the frequency would raise havoc with synchronous motor drive things like some older clocks and high fidelity sound equipment -- but that's trivial. Right?
  • Hot_water_fan
    How many of us would honestly trade our automatic transmission for the exact same model with a manual?
    Solid_Fuel_Man
  • ChrisJ
    Ok,
    It slows motors down.
    What about everything else?
    Jamie, what "High fidelity sound equipment" do you feel this would cause problems with other than some really old turntables? Even my 1978 Technics was quartz controlled.
  • ChrisJ
    I've owned almost all manual transmissions.
    And from my perspective, laziness is the reason they are almost gone, not emissions.
    Yes, emissions played a roll, but since GM sold almost none starting in the 70s, it's certainly not the primary cause in the USA.
    Mad Dog_2Hot_water_fanSolid_Fuel_Man
  • GGross
    GGross Member Posts: 1,559
    Oddly enough, the one thing that is least likely to be affected by lowering the Hz, is an inverter heat pump. Their whole schtick is lowering the Hz. That's why you generally don't see and can't find their real efficiencies as they have to be tested and listed while locked at 60 Hz as that is the standard in the US. It's like rating a gas fired boiler's efficiency under the least efficient circumstances possible. And even then the inverters are putting out far more than you put in despite the claim "You can’t put in less and get more than was put in impossible unless just on paper "
    Mad Dog_2Solid_Fuel_Man
  • Mad Dog_2
    I loved my Manual Sticks..Much better control and your fully engaged...Great in the snow, too. Mad Dog 🐕
    GGrossSuperTechSolid_Fuel_Man
  • ChrisJ
    edited August 2023
    It's not just that.
    Lowing frequency will cause issues with industrial equipment, issues which will be fixed very quickly one way or another. I guess air conditioning equipment etc will have less output, but that'll just make most of it run longer instead. So, you've solved nothing.
    I also think transformers etc are less efficient at lower frequencies? So as you go lower than 60, you're loosing transmission efficiency on top of it.
    GGross
  • Hot_water_fan
    Let’s call that customer preferences  :smile:
    I agree, it wasn’t due to emissions. Americans don’t want them.
  • ChrisJ
    Customer preferences, laziness,
    I guess either works, one is more kind. ;)
    I drive 90 miles a day, a lot of which is in traffic and yet my left leg isn't broke.
  • Mad Dog_2
    I'm with you, Chris!  Easy is NOT always the better way....I prefer "The Strenuous Life" Of Teddy 🧸 Roosevelt.   Mad Dog 🐕
  • Mad Dog_2
    Me too..was driving stick on the Horse  Farm at age 9...Once you learn, its like riding  bike.  Mad Dog 🐕
    But how would millions of people that txt and are on cell phones be able to drive manual transmissions.?
    Not to forget the gals on the phone, applying makeup and driving simultaneously?
    Steering with their knees, phone in one hand, lipstick in the other, gazing into the rear view mirror..
    Mad Dog_2
  • ChrisJ
    hot_rod said:
    But how would millions of people that txt and are on cell phones be able to drive manual transmissions.? Not to forget the gals on the phone, applying makeup and driving simultaneously? Steering with their knees, phone in one hand, lipstick in the other, gazing into the rear view mirror..
    You don't think you can do all of those things while driving a manual?
    Post a video of you driving and shifting with lipstick (or chap stick) in one hand cell phone in the other.
    Make it a pre 60's truck, a tranny with no syncros, long travel stick to make it more interesting.
    A Yeti coffee mug between your legs also, with a scalding Starbucks latte if that is not too much to ask. I'll buy the latte
    Mad Dog_2
  • ChrisJ
    hot_rod said:
    Post a video of you driving and shifting with lipstick (or chap stick) in one hand cell phone in the other. Make it a pre 60's truck, a tranny with no syncros, long travel stick to make it more interesting. A Yeti coffee mug between your legs also, with a scalding Starbucks latte if that is not too much to ask. I'll buy the latte
    I've driven a model A which has no synchros and you manually control the ignition timing and I'd bet I could do lipstick in one hand and a cell phone in the other
    Wait.
    What?
    Mad Dog_2reggiSolid_Fuel_Man
    Be careful with the lipstick comment around here, you may be branded "gender fluid" o:)
    ethicalpaul Member Posts: 7,762
    A Yeti coffee mug is vacuum insulated and has a splash guard, no problem there
    Solid_Fuel_Man
    “splash resistant”
    They work perfectly when the slider is closed
    You didn't say it had to be open, although you could open it with your thumb while holding it--but who can drink scalding coffee anyway? :shrug:
    Solid_Fuel_Man
    Holding it in your crotch while you make the shift is where the scald hazard lies😉
    I have  several of those cups, great cups but they don’t fit into the cup holders in my truck or 🚗 So you end up juggling it somewhere in the vehicle
    Mad Dog_2ethicalpaul
  • Mad Dog_2
    I used to read the NY Post  in bumper to bumper traffic on the world's longest parking lot, The Long Island 🏝 Expressway , sip coffee ☕ and shift...and change radio stations when the music 🎶 got silly.  Never an accident!!  Lots of spilled coffee though!  Mad Dog 🐕 🤣
  • ChrisJ
    Some will be familiar with this, and others won't be...
    https://youtu.be/7elLpAKEFew?si=iGNWqn18eLZv0b0p&t=6
    random12345Mad Dog_2Solid_Fuel_Man
  • Mad Dog_2
    What movie is that?  Corey Haim...that poor kid.  Mad Dog 🐕
  • ChrisJ
    License to drive.
    https://www.imdb.com/title/tt0095519/
    Solid_Fuel_Man
  • seized123
    seized123 Member Posts: 432
    Largest Italian combo hero sandwich in the Bronx, with the works, driving a five-speed with crazy rush-hour drivers.
    ChrisJ
  • Mad Dog_2
    Ha ha...yeah I heard of it...that "Corey Haim" Lucas Era was for the kids 5 yrs younger.  Where in Da Bronx?  Arthur Av...? What was it called...doubt its still there, right?  Mad Dog 🐕
  • seized123
    It was decades ago, I don’t even remember where it was, not Arthur Ave., though. Pretty sure it was called Mamas, and when you walked in there she was your Mama, heros as big as an aircraft carrier and so stuffed you couldn’t fold them in half. For some reason I’m recalling lots of Yankee memorabilia on the walls.
    Then there was some old timer somewhere else in the Bx, in a storefront that looked abandoned, steamy windows, a wreck inside, you’d never know what it was from the outside. But every lunchtime he’d set up steam tables and made some of the best heros  I’ve ever had - brisket with boiled potatoes and peppers, yeesh. I think he was an old Marine vet, had some old photos on the walls.
    Mad Dog_2
