Circulator pump smoking
1928steam
Member Posts: 40
in Oil Heating
I may have used detergent oil to oil the motor on the Taco Circulator pump. The pump had stopped spinning so I oiled the motor. In any event it starts, continues spinning for about 10 minutes, starts to buzz, then stops spinning and then starts to smoke. Any ideas?
It works fine for about ten minutes, turns freely. The transfer tube gets hot, but the pipes don’t. Could it be something other than the motor or the pump itself, which seems fine?0
The issue is finding anyone around here that understands the system. Princeton, NJ.0
Are you sure it is stopping because the bearings are seizing vs it is overloaded trying to turn the bad bearings and the overload trips out on the motor?0
Is it an oil burner with a tankless coil?
Once you smoke the motor you pretty much done as far as the motor is concerned.
What is a transfer tube? never heard of that on a boiler.0 -
Added hot water zone off steam heat. Big transfer tube that is heated up (looks like a bazooka) and then circulated through baseboards. Getting the steam heat side serviced is okay, but nobody seems to understand the added zone, so it hasn’t received the attention it should.0
You mean a heat exchanger? Pics would help. Not for the motor as that is junk but what you system looks like. Sounds like nothing fancy.0
Lots of pictures under the discussion “Taco no 105 - 1 circulator”—- I don’t think it’s particularly fancy, just hard to find anyone local who understands it. It is a shell and tube heat exchanger. Please forgive my ignorance — I knew nothing about steam heat before I bought this house.0
How old is it? Old enough to smoke🤓
How much oil did you put in the motor? Several drops is all, or else you saturate the inside of the motor
Ghe bearing assembly has a cotton wick and can take more oil
It may have gone from no oil to excessive oil?Bob "hot rod" Rohr
Living the hydronic dream2 -
Don't see any pic's but no big deal. Just want to make sure i understand what you have so not to give you any bad advice. it's not ignorance. Its just not your field. That's why your on here.
is it steam to water or water to water hx. Is the circulator for the heating loop?0 -
No oil to excessive, yes.
steam to water, circulator I believe is for heating loop … one side of house is all steam … other is baseboards with shell and tube. It doesn’t make sense to me that the pump spins freely and then stops, while the copper tubes don’t get warm, so water isn’t flowing. If I turned it on now, the circulator would be spinning away without buzzing but would then buzz slow stop and smoke. I can send pics but there are tons of them if you search the wall for “Taco no 105 - 1 circulator"0 -
Almost certainly a bad bearing -- and those bearings, once they go, are gone. No fix to them.
Replace the whole thing with a nice new more efficient pump.Br. Jamie, osb
Does it have a spring coupler? Sometimes those jam when a spring breaksBob "hot rod" Rohr
Smoking circulator? Make it stop. That’s bad for its health.
Seriously though, you’re gonna have to replace the whole thing and a wet rotor circulator won’t last in that application. You should replace it with a B&G series 100 BRONZE circulator. It’s the only one the will hold up to that application.
Not gonna be cheap.
Try contacting @EzzyT
(347) 436-6593
Bob Boan
Taco 007 F was recommended. Or Taco Ss 007 … when you say the whole thing, I’m assuming just the circulator pump, correct?0
so here is their other thread:
https://forum.heatinghelp.com/discussion/185531/taco-no-105-1-circulator#latest
but it doesn't show which circulator is the boiler and which is the hot water loop. a wet rotor circulator isn't necessarily the best idea on the boiler side because of all the rust in the boiler water.0 -
HW side is Taco 105.
Steam side is Taco 006 B.0 -
The pump you have has endured over 50 years of use. I would suggest following the advice of the Taco folks on the other thread and replace it with a 007. If you buy the one with reversed flanges and you are able to slide the copper pipe 3/8" toward the wall, it should be a simple bolt-on installation.
https://www.supplyhouse.com/Taco-007-F5-8IFC-007-Cast-Iron-Circulator-with-Integral-Flow-Check-1-25-HP"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
Perhaps adding this sign near the pump will solve the problem. That pump should be old enough to read.
Looks like in the other thread someone from taco offered to give them an 007 if they sent the old circulator to them for their museum.0
Is the Taco SF5 or the Taco F5 better to replace? Or the B&G series 100 BRONZE? Can someone tell me what the difference is in terms of their appropriateness? Thanks0
Is the hot water loop coming directly from the bottom of the boiler? If so, no wet rotor circulator will last due to the condition of the water.
This is why a bronze three piece circulator should be used.
Dan recommends this in one of his books.Bob Boan
Look at the other post. There is an ancient shell and tube hx that looks like a water main. Someone above extracted from the other post we think this is on the emitter side of the hx.Ironman said:Is the hot water loop coming directly from the bottom of the boiler? If so, no wet rotor circulator will last due to the condition of the water.
Dan recommends this in one of his books.1 -
Do you have access to Taco tag?Trying to understand which product you have before diagnosis.
if it’s a three piece pump oiling motor through oil fill hole is necessary snd recommended following instruction sheet recommended interval.
is the pump moving water now?Joe Mattiello
Taco Comfort Solutions0 -
https://forum.heatinghelp.com/discussion/185531/taco-no-105-1-circulator#latestJoe Mattiello said:Do you have access to Taco tag?
is the pump moving water now?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1 -
Thanks. The smaller bronze taco seems to be for the water coming out of the boiler before it goes into the hx and the 105 after it goes out of the hx. Is bronze series 100 still needed or what is the difference between the SS and the iron 007 in terms of application?
Cast iron wet rotor is fine and much less expensive on the heating loop which is sealed.
The boiler water gets fresh oxygen from the air so it will create some rust which wouldn't play nicely with a cast iron or wet rotor circulator.0 -
No tag, just the label I showed in the photo posted.0
Sorry, meant to be “agree”. Hard to hit the opinion buttons on a phonehot_rod said:
If you hit the button again it goes away"If you can't explain it simply, you don't understand it well enough"
Albert Einstein1
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
