Circulator pump smoking
1928steam
1928steam Member Posts: 40
I may have used detergent oil to oil the motor on the Taco Circulator pump.  The pump had stopped spinning so I oiled the motor.  In any event it starts, continues spinning for about 10 minutes, starts to buzz, then stops spinning and then starts to smoke.  Any ideas?
  • PC7060
    PC7060 Member Posts: 1,160
    Bad bearing. Time to replace
    mattmia2MikeAmann
    HVACNUT Member Posts: 5,841
    Any ideas? Is that a trick question?
    At the bare minimum, replace the motor. Make sure the bearing assembly and impeller move freely. Or IMO, the better option is to replace it with a wet rotor circulator.
    unclejohn
    mattmia2 Member Posts: 9,672
    The bearing is already trashed when it is danged to the point it won't turn. oil prevents that wear, it doesn't fix it after it has happened.
    MikeAmann
  • pedmec
    pedmec Member Posts: 977
    And now the motor windings are smoked so its time to upgrade.
    MikeAmannSuperTech
  • 1928steam
    It works fine for about ten minutes, turns freely.  The transfer tube gets hot, but the pipes don’t.  Could it be something other than the motor or the pump itself, which seems fine?
  • 1928steam
    The issue is finding anyone around here that understands the system.  Princeton, NJ.
    Are you sure it is stopping because the bearings are seizing vs it is overloaded trying to turn the bad bearings and the overload trips out on the motor?
    Regardless it is time to send it to the museum. A wet rotor circulator will cost less than any part of that 3 piece circulator and will use significantly less power.
    MikeAmann
  • pedmec
    Is it an oil burner with a tankless coil?
    Once you smoke the motor you pretty much done as far as the motor is concerned.
    What is a transfer tube? never heard of that on a boiler.
  • 1928steam
    Added hot water zone off steam heat.  Big transfer tube that is heated up (looks like a bazooka) and then circulated through baseboards.  Getting the steam heat side serviced is okay, but nobody seems to understand the added zone, so it hasn’t received the attention it should.
    That is probably a shell and tube heat exchanger. Is the circulator in the hot water loop water or the boiler water? Pictures would be good.
    PC7060
  • pedmec
    You mean a heat exchanger? Pics would help. Not for the motor as that is junk but what you system looks like. Sounds like nothing fancy.
  • 1928steam
    edited November 2022
    Lots of pictures under the discussion “Taco no 105 - 1 circulator”
    —- I don’t think it’s particularly fancy, just hard to find anyone local who understands it.  It is a shell and tube heat exchanger.  Please forgive my ignorance — I knew nothing about steam heat before I bought this house.
    hot_rod Member Posts: 22,158
    How old is it? Old enough to smoke🤓
    How much oil did you put in the motor? Several drops is all, or else you saturate the inside of the motor
    Ghe bearing assembly has a cotton wick and can take more oil
    It may have gone from no oil to excessive oil?
    kcoppEdTheHeaterMan
  • pedmec
    Don't see any pic's but no big deal. Just want to make sure i understand what you have so not to give you any bad advice. it's not ignorance. Its just not your field. That's why your on here.
    is it steam to water or water to water hx. Is the circulator for the heating loop?
  • 1928steam
    No oil to excessive, yes.
    steam to water, circulator I believe is for heating loop … one side of house is all steam … other is baseboards with shell and tube.  It doesn’t make sense to me that the pump spins freely and then stops, while the copper tubes don’t get warm, so water isn’t flowing.  If I turned it on now, the circulator would be spinning away without buzzing but would then buzz slow stop and smoke.  I can send pics but there are tons of them if you search the wall for “Taco no 105 - 1 circulator"
    Jamie Hall Member Posts: 23,330
    Almost certainly a bad bearing -- and those bearings, once they go, are gone. No fix to them.
    Replace the whole thing with a nice new more efficient pump.
    Does it have a spring coupler? Sometimes those jam when a spring breaks
  • Ironman
    Ironman Member Posts: 7,376
    Smoking circulator? Make it stop. That’s bad for its health.
    Seriously though, you’re gonna have to replace the whole thing  and a wet rotor circulator won’t last in that application. You should replace it with a B&G series 100 BRONZE circulator. It’s the only one the will hold up to that application.
    Not gonna be cheap.
    Try contacting @EzzyT
    (347) 436-6593
    Bob Boan
  • 1928steam
    Taco 007 F was recommended.  Or Taco Ss 007 … when you say the whole thing, I’m assuming just the circulator pump, correct?
    so here is their other thread:
    https://forum.heatinghelp.com/discussion/185531/taco-no-105-1-circulator#latest
    but it doesn't show which circulator is the boiler and which is the hot water loop. a wet rotor circulator isn't necessarily the best idea on the boiler side because of all the rust in the boiler water.
  • WMno57
    WMno57 Member Posts: 1,292
    HW side is Taco 105.
    Steam side is Taco 006 B.
    I DIY.
  • Zman
    Zman Member Posts: 7,569
    The pump you have has endured over 50 years of use. I would suggest following the advice of the Taco folks on the other thread and replace it with a 007. If you buy the one with reversed flanges and you are able to slide the copper pipe 3/8" toward the wall, it should be a simple bolt-on installation.
    https://www.supplyhouse.com/Taco-007-F5-8IFC-007-Cast-Iron-Circulator-with-Integral-Flow-Check-1-25-HP
    Albert Einstein
    EdTheHeaterMan Member Posts: 7,859
    Perhaps adding this sign near the pump will solve the problem. That pump should be old enough to read.
    Looks like in the other thread someone from taco offered to give them an 007 if they sent the old circulator to them for their museum.
  • 1928steam
    Is the Taco SF5 or the Taco F5 better to replace?  Or the B&G series 100 BRONZE?  Can someone tell me what the difference is in terms of their appropriateness?  Thanks
  • Ironman
    Is the hot water loop coming directly from the bottom of the boiler? If so, no wet rotor circulator will last due to the condition of the water.
    This is why a bronze three piece circulator should be used.
    Dan recommends this in one of his books.
    Bob Boan
    Look at the other post. There is an ancient shell and tube hx that looks like a water main. Someone above extracted from the other post we think this is on the emitter side of the hx.
    Zman
  • KC_Jones
    KC_Jones Member Posts: 5,739
    @EzzyT @JohnNY @clammy all work in NJ, not sure if any of them go to Princeton or not.
    2014 Weil Mclain EG-40
  • Joe Mattiello
    Joe Mattiello Member Posts: 707
    Do you have access to Taco tag?
    Trying to understand which product you have before diagnosis.
    if it’s a three piece pump oiling motor through oil fill hole is necessary snd recommended following instruction sheet recommended interval.
    is the pump moving water now?
    Joe Mattiello
    Taco Comfort Solutions
  • Zman
    Albert Einstein
  • 1928steam
    Thanks.  The smaller bronze taco seems to be for the water coming out of the boiler before it goes into the hx and the 105 after it goes out of the hx.  Is bronze series 100 still needed or what is the difference between the SS and the iron 007 in terms of application?
    Cast iron wet rotor is fine and much less expensive on the heating loop which is sealed.
    The boiler water gets fresh oxygen from the air so it will create some rust which wouldn't play nicely with a cast iron or wet rotor circulator.
  • 1928steam
    No tag, just the label I showed in the photo posted.
  • 1928steam
    yeah, that is the closed side of the heat exchanger. A modern wet rotor cast iron circulator will be fine there. It wouldn't be a terrible idea to put a dirtmag in there to remove any iron particles that are in that loop.
    hot_rod
    What do you disagree with @hot_rod? Do you think there is too much iron debris in the closed side?
    Sorry, meant to be “agree”. Hard to hit the opinion buttons on a phone
  • Zman
    If you hit the button again it goes away :)
    Albert Einstein
