The Holy Grail of boiler install pics…for your viewing pleasure
Timco
Member Posts: 3,040
Where's my Sawzall?All Steamed Up, Inc.
Consulting4 -
Impressive.Br. Jamie, osb
But how well does it heat?...or not?0
Who did this? O.O0
Is there an emoji for “ I’m feeling sick to my stomach “? 🤮0
Look where the relief valve dumps. They musta run out of pipe and called it a day. Where does one buy that nice green pipe by the Honeywell?0
You’d get really burned trying to hit that shut off!0
I was just thinking to myself about the photo above and some of the others photos posted on HH lately. I bet many of them work relatively well, despite the less than optimal piping or reluctance to considering reading the installation manual.0
How did this come to be?
This is the result of agreeing to put a boiler in a small closet and/or not demanding that a proper utility room be maintained when the basement was finished and the two story addition with 3 or more zones was put on. It needs to be explained to homeowners and architects and builders that mechanical systems shouldn't be pushed out of sight, but given the space needed to perform and be MAINTAINED properly.0 -
Quite a good point made here, but one must look at this installation IN CONTEXT: It is easily a 30-35 year old installation. A modern day install would hopefully give another several feet to the sides around the boiler.bruce_21 said:How did this come to be?
And while many are talking shtuff about this, I actually think it is very well done. Keep in mind damned near every piece is original. True there are a couple sweat solder joints failing, and the relief valve has been replaced and re piped, but by and large EVERY OTHER PART looks to be original and functioning. And it was done to a high standard: iron pipe returns which give very strong support to the circulators; a BYPASS circulator; balancing valves with temperature gauges at every return. Isolation ball valves at very many places to allow repair without draining or shutting down the system.
True, just off field to the left is a 4x4 electrical box with the cover off.
Just how would you critical guys make this better in 2022? And will you warranty your work and materials for 35 years?0 -
Holy sheep s**t Batman!gwgillplumbingandheating.com
In the real world, we Plumbers see lots of this stuff. This mess is going to get corrected as soon as the weather is warm enough to shut it down. 0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 113 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
