Shark Bites and pex on boiler
Ironman
Member Posts: 7,865
We looked at this job yesterday to bid on replacing this boiler and 535k btu steam boiler and converting to gas. I’ve never seen someone use 1.25” pex and Shark Bites to connect a boiler.
This was done on a multi million dollar house. The guy that did is known for being a real hack, but this is especially egregious.
This boiler will get moved to the greenhouse to replace an ancient one there.
Bob Boan
The "Hack" I am sure is proud of that one.0
Any oxygen barrier in that type of Pex?0
Yes, it is.Jamie Hall said:Please tell me that that isn't PEX and sharkbites in the riser. Please.Bob Boan
I'm much more concerned about the romex dangling from the ceiling.0
Exposed Romex.Ironman said:We looked at this job yesterday to bid on replacing this boiler and 535k btu steam boiler and converting to gas. I’ve never seen someone use 1.25” pex and Shark Bites to connect a boiler.
Uncovered Electrical.
Antique circulators.
Any State licensing board?0 -
Yeah, but I doubt that there was an inspection.pecmsg said:We looked at this job yesterday to bid on replacing this boiler and 535k btu steam boiler and converting to gas. I’ve never seen someone use 1.25” pex and Shark Bites to connect a boiler.
Exposed Romex. Uncovered Electrical. Antique circulators. Any State licensing board?
Bob Boan
You don’t know just how true that is. He took a $25k deposit on another job and never returned. He told the HO that he’d spent it and couldn’t do anything about it. IDK how he got away with that.pecmsg said:That contractor values the all-mighty dollar over workmanship and integrity!Bob Boan
I wish I could "Un-see" that one
Albert Einstein0 -
Now I would never advocate for violence or anything of the sort...Ironman said:You don’t know just how true that is. He took a $25k deposit on another job and never returned. He told the HO that he’d spent it and couldn’t do anything about it. IDK how he got away with that.0 -
Worse than those things is the fact that it’s vented into an unlined chimney on an outside wall.pecmsg said:We looked at this job yesterday to bid on replacing this boiler and 535k btu steam boiler and converting to gas. I’ve never seen someone use 1.25” pex and Shark Bites to connect a boiler.
Bob Boan
Did they do anything right?Br. Jamie, osb
Did they install a relief valve?0
- 167 Indoor-Air Quality
