suction for deformed pipe?
what? is it out of round copper? there are various punches you can drive in the end to make it round again. maybe heat it with a torch to anneal it and let it cool first.0
Or you could swedge it in to a socket. or you could use a thicker solder and control the heat so it flows in to a larger gap.0
Copper is pretty tough stuff. I have seen plenty of good joints put on stuff that most would say couldn't be saved. It is easier to fill a bad joint with brazing rod. Takes more heat though.
Suction!? No.jumper said:Pipe coming out of concrete must be out of round because solder repair leaks. Somebody suggested that I apply suction to pipe and try brazing. Is it worth a try? Any other suggestions?
But what you can do if the pipe is a bit ovaled and not round is make it round again.
Take a adjustable wrench and close the jaws around a pipe of the same size that is not damaged. Then pull the adjustable wrench off of the pipe without moving the jaws.
Now place the adjustable wrench jaws on the pipe that is oval and move the wrench at 360 deg. around the deformed pipe making it round again and ready for a better fit solder joint.
If this doesn't work you might be working with a oddball pipe diameter.1 -
- 120 Geothermal
