Inhaled a good amount of acetylene
So what should I be on the lookout for when I got a big breath of acetylene? Was enough to taste it and cough.
    EBEBRATT-Ed Member Posts: 20,141
    I don't know. I guess if your still on your feet, didn't pass out your probably ok. That stuff smells pretty bad so you automatically get away from it.
    Hope ur ok
  • Ironman
    Ironman Member Posts: 7,903
    Shouldn't you really be asking a doctor?
    Bob Boan
    SuperTech
    Jamie Hall Member Posts: 27,312
    The stuff is, oddly, pretty harmless to living things -- unless it blows up. If, however, you find yourself very short of breath, or nausea or vertigo, you should seek medical assistance.
    bucksnort
  • bucksnort
    bucksnort Member Posts: 167
    If your erection lasts longer than 4 hours, I'd see a doctor.
    SuperTech
    pecmsg Member Posts: 7,039
    Im not hiring a Dr!
  • BillyO
    BillyO Member Posts: 277
    If your erection lasts more than 4 hours , let me know. I will head down to welco in morning for a tank
    SuperTechMotorapido
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 744
    I'm going with no smoking for a while. Since you are posting and not flat out or in the hospital, I suspect that you are all good. Here is a link for the SDS for acetylene.
    https://www.airgas.com/msds/001001.pdf
    Larry
    BillyO
  • Gordo
    Gordo Member Posts: 857
    Awhile back, doctors were considering and experimenting with using oxygen/acetylene gas mixtures as anesthesia gas during surgery.
    The articles note c2h2 is effective for that and had no ill effects, but there were a few, just a few, other minor downsides....
    Boom.
  • Intplm.
    Intplm. Member Posts: 3,002
    You should be fine. Many have had the same experience you have had. You'll be fine. Especially if you are not having any symptoms as described above.
    pecmsg said:
    Im not hiring a Dr!
    But with this off-topic symptom. I would closely monitor the situation. Especially if you are in good company.
