Inhaled a good amount of acetylene
Irish1124
Member Posts: 1
So what should I be on the lookout for when I got a big breath of acetylene? Was enough to taste it and cough.
I don't know. I guess if your still on your feet, didn't pass out your probably ok. That stuff smells pretty bad so you automatically get away from it.
Hope ur ok0 -
The stuff is, oddly, pretty harmless to living things -- unless it blows up. If, however, you find yourself very short of breath, or nausea or vertigo, you should seek medical assistance.Br. Jamie, osb
I'm going with no smoking for a while. Since you are posting and not flat out or in the hospital, I suspect that you are all good. Here is a link for the SDS for acetylene.
https://www.airgas.com/msds/001001.pdf
Larry1 -
Awhile back, doctors were considering and experimenting with using oxygen/acetylene gas mixtures as anesthesia gas during surgery.
The articles note c2h2 is effective for that and had no ill effects, but there were a few, just a few, other minor downsides....
Boom.All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
You should be fine. Many have had the same experience you have had. You'll be fine. Especially if you are not having any symptoms as described above.Irish1124 said:So what should I be on the lookout for when I got a big breath of acetylene? Was enough to taste it and cough.
But with this off-topic symptom. I would closely monitor the situation. Especially if you are in good company.pecmsg said:
Im not hiring a Dr!bucksnort said:If your erection lasts longer than 4 hours, I'd see a doctor.
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
