Window Condensation
Sometime extended use of bath and kitchen exhaust fans by use of timers will clear it up. It has worked for me.0
Did you do other remodel work that added a bunch of moisture to the house? Thinset and sheetrock compound contain a lot of water. If you did a remodel and just closed up the house and turned the heat on, the condensation may clear up in a few days. A dehumidifier may also help get things to a steady state.0
All windows, RH 50% +, outdoor temp 35 degrees and below.0
I have found that crawlspaces with exposed dirt or basements with inadequate moisture/vapor barriers are often the culprit."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
50% is probably too high in the winter. I've always heard 35% is safer. I agree you need better exhaust fans and perhaps need to bring in some air in general.
But I'm not sure I would expect good windows to condensate with it 35 degrees out either even at 50%? That seems surprising.
Getting the humidity level down seems to be one of the issues, but when the humidity outside is even higher than inside, seems like a HRV system would be counter productive.0
Depends on the outdoor temperature.ced48 said:Getting the humidity level down seems to be one of the issues, but when the humidity outside is even higher than inside, seems like a HRV system would be counter productive.
80% RH at 30 degrees F is only 18% at 70F.
100% RH at 0F is 6% at 70F.
That's why it's relative humidity. This is also why the windows are condensing humidity. The air cannot hold as much humidity when it hits the cold glass so the water literally falls out of it.
Here's an online calculator you can use to see the relation.
http://www.dpcalc.org/Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
So, bringing in outside air with a temperature of 35 degrees and a relative humidity of 65% will actually decrease the the humidity level inside which is at 68 degrees and 50% humidity?0
Yep.ced48 said:So, bringing in outside air with a temperature of 35 degrees and a relative humidity of 65% will actually decrease the the humidity level inside which is at 68 degrees and 50% humidity?
This is why drafty houses like mine are dry in the winter. It has nothing to do with the type of heat (forced air vs steam vs hot water) etc. But forced air, especially if installed improperly can make infiltration worse.
2 -
Perhaps a big factor in the OP's house is that he got rid of a chimney vented boiler and went ModCon, probably 2 pipes.
The constant flow of basement air up the chimney caused dry outside air to be pulled inside from various places.
Tightening up the house and losing that air flow would add to retaining inside humidity.
Our house is "superinsulated" with vapor barrier everywhere, minimal exterior wall penetrations. We had to run bath fans maybe 30 minutes per use to prevent condensation on windows.
We have a 6" cold air pipe hanging into the basement for fresh air. Now only with a full house on holidays, will we see moisture.
But all the kids live with heat pumps and feel overheated with our 72-74 rooms, so windows are snuck open when they think I am not looking. So plenty of cold dry air coming in.0 -
There's a bit of elementary physics involved here. If we suppose an interior air temperature of 70 F and an interior relative humidity of 50%, then you will get condensation on any surface cooler than 50 F. Which a window is very likely to be if it's 30 outside.
This has nothing to do with the source of the heat which is maintaining the interior temperature (assuming it's not open water, of course -- nothing like a hot tub!).
What happens is that if the house is made tight, the natural moisture from human occupancy and activity will often raise the relative humidity into the critical range -- or even higher. Older, draughtier, houses had much better indoor air quality and much lower humidity -- and didn't have the problem.
An HRV (sensible, not latent) will help by bringing in more outside air and lowering the relative humidity -- but if you want high relative humidity, you will have to cope with the condensation.Br. Jamie, osb
@op I don’t want to worry you unnecessarily, but one of the signs that the combustion fumes from a gas fired appliance are not properly vented to the outdoors is high humidity indoors.
Are you absolutely sure the exhaust from that modcon boiler is venting out of the house as it should? Carbon monoxide from an incorrectly vented gas fire can kill you, and you’ll never smell it.
If you have working carbon monoxide (CO) detectors and they are not alarming, you are probably OK.—
Bburd0 -
CO Alarms that are UL 2034 listed are virtually worthless. They will only alarm when 70PPM is achieved or exceeded for between 60 & 240 minuets.bburd said:@op
Every home Should Have a Low Level Detector!
https://www.myhomecomfort.org/carbon-monoxide-levels-risks/0 -
pecmsg said:
@op
CO Alarms that are UL 2034 listed are virtually worthless. They will only alarm when 70PPM is achieved or exceeded for between 60 & 240 minuets. Every home Should Have a Low Level Detector! https://www.myhomecomfort.org/carbon-monoxide-levels-risks/
I've seen people in here say this repeatedly.
If they are "virtually worthless" why is that the standard that was developed and agreed on?
If that is worthless why do we feel other codes and laws are so important?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
That level was accepted to cut down on 911 calls!
CODES and Laws are Minimum Standards
I thought it was a time weighted average and lower levels around 10ppm over 8 hours will still trip the alarm. Where more toxic high level will trip it almost immediately. It’s to prevent nuisance trips form ovens and stoves, and keep the price reasonable to there’s widespread adoption of the devices.
That’s my take.0 -
motoguy128 said:I thought it was a time weighted average and lower levels around 10ppm over 8 hours will still trip the alarm. Where more toxic high level will trip it almost immediately. It’s to prevent nuisance trips form ovens and stoves, and keep the price reasonable to there’s widespread adoption of the devices. That’s my take.
69PPM NO zero alarms
70PPM OR above 60 to 240 minutes before alarming.0 -
pecmsg said:motoguy128 said:I thought it was a time weighted average and lower levels around 10ppm over 8 hours will still trip the alarm. Where more toxic high level will trip it almost immediately. It’s to prevent nuisance trips form ovens and stoves, and keep the price reasonable to there’s widespread adoption of the devices. That’s my take.
It would have been much better @Marcus_Rull , to start a new thread on this.
However… a skylight is a window. It just happens to be in a roof. Whether or not you will get condensation on the inside of it depends on two things: the dewpoint of the air in the house and the temperature of the inner surface of the glass. The latter depends on how good the skylight is and the interior and exterior air temperatures.
You can get condensation on a skylight — like any window. It is much more likely on cheaper skylights (like windows again — you get what you pay for, and quality insulating double or triple pane skylights are VERY expensive).
Interesting that both Marcus Rull and John Piterson both use an underscore in their username.
I wonder if they know each other?
WMno57_didn't_fall_off_the_turnip_truck_yesterday
You might like this @WMno57, Actual footage of me falling off the "Turnip Truck" about 9 years ago.
6 -
First thing to try is a small fan. If it works she can try fans in any room where OP doesn't like condensation. Or try running baseboards @ 160° and see what happens. 50% R.H. dries up moisture if there's enough air circulation.
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
