Permits? Ya ya we’ll pull permits
Are there any craftsmen left ?
JellisSuperTechZmanSolid_Fuel_Man
  • Grallert
    Grallert Member Posts: 1,026
    they might as well have glued the yellow placard to the window.
    Canucker
    Steamhead Member Posts: 18,179
    Uhhhhhhhh, Beavis...... huh-huh huh-huh huh-huh
    I sure hope the inspector didn't pass that mess...............
    Consulting
    hot_rod Member Posts: 26,467
    looks like they even drilled the stair tread.
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,502
    The kids will have a field day. Can't imagine what will end up inside.
  • KC_Jones
    KC_Jones Member Posts: 5,902
    I just called my borough on a related topic.
    Me: Are permits required for the replacement of a steam boiler
    Borogh: No
    Me: None of them?
    Borough: No
    Some areas aren't minding the store.
    2014 Weil Mclain EG-40
  • STEVEusaPA
    Good bye, lunch...
    You have to warn people to wait 15 minutes after they eat before looking at the pictures...lol.
    Sadly, not the worse...
    EBEBRATT-Ed Member Posts: 19,405
    MA. is/was known as one of the strictest states. At one time I had about 11 licenses, let a bunch of them go.
    Now, nobody seems to give a crap. Some only get permits if they are forced into it by needing a gas meter or an electric meter for electrical work.
    And the inspectors, that's another story. Our Governor wan't to do away with licensing.
    pecmsg Member Posts: 6,740
    It looks like they even used a level to screw it up properly!
    GrallertCanucker
  • Zman
    Zman Member Posts: 7,611
    At least it will steam the wrinkle out of your clothes on the way by.
    It's hard to say what is worse, Blasting the folks on the stairs or the operable window.
    Albert Einstein
    It's a reading problem.
    We all see steam boiler posted here that are installed wrong because the installer didn't read the install manual.
    Imagine that someone that knows absolutely nothing about steam but could put pipe together could pipe a boiler better than the "professional" installers who can't read.
    This is the same thing.
    Mod cons and 90% furnaces generally have the same flue requirements.
    But every manufacturer requires something different.
    You have to be able to read
    Lazy
    mattmia2kcoppGroundUpCanucker
    mattmia2 Member Posts: 15,356
    They all seem to have the same vent diagram that someone that is no longer there drew in 1985 and no one that knows why it was that way is there anymore.
  • ratio
    ratio Member Posts: 4,172
    Well, the other guy was going to change too much, these guys did it for a lot cheaper!!!1!
  • Maybe the vents were there first and the stairs later. : )
    rick in Alaska
  • stonebutson
    stonebutson Member Posts: 24
    I thought so too - window looks oem
  • BillyO
    BillyO Member Posts: 277
    I stared and looked at pic for 3 minutes, usually after 3 seconds I can come up with something stupid to say that annoys most. Im speechless for first time
  • Ironman
    Ironman Member Posts: 7,842
    I see the problem: the right vent termination is one inch higher than the left... :D
    Bob Boan
    STEVEusaPA
  • STEVEusaPA
    That was to account for the fact the steps go up...
    IronmanCanuckerAlan (California Radiant) Forbes
  • BillyO
    gorgeous drapes
    Grallert
  • Solid_Fuel_Man
    Solid_Fuel_Man Member Posts: 2,644
    And to think they dare use PVC.
    Should have used vent ells, everyone knows that you need a vent ell for venting. Sheesh
    BillyO
    is that polybutylene water supply pipe(that is about the size of a fire hydrant)
  • Wellness
    Wellness Member Posts: 154
    @BillyO "gorgeous drapes". :) You win the Internet today.
    Grallert
