Permits? Ya ya we’ll pull permits
stonebutson
Member Posts: 24
Uhhhhhhhh, Beavis...... huh-huh huh-huh huh-huh
I sure hope the inspector didn't pass that mess...............All Steamed Up, Inc.
Consulting0 -
looks like they even drilled the stair tread.Bob "hot rod" Rohr
The kids will have a field day. Can't imagine what will end up inside.0
I just called my borough on a related topic.
Me: Are permits required for the replacement of a steam boiler
Borogh: No
Me: None of them?
Borough: No
Some areas aren't minding the store.0 -
Good bye, lunch...
You have to warn people to wait 15 minutes after they eat before looking at the pictures...lol.
Sadly, not the worse...There was an error rendering this rich post.
MA. is/was known as one of the strictest states. At one time I had about 11 licenses, let a bunch of them go.
Now, nobody seems to give a crap. Some only get permits if they are forced into it by needing a gas meter or an electric meter for electrical work.
And the inspectors, that's another story. Our Governor wan't to do away with licensing.0 -
> @stonebutson said:
> Are there any craftsmen left ?
It looks like they even used a level to screw it up properly!2 -
At least it will steam the wrinkle out of your clothes on the way by.
It's hard to say what is worse, Blasting the folks on the stairs or the operable window."If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
It's a reading problem.
We all see steam boiler posted here that are installed wrong because the installer didn't read the install manual.
Imagine that someone that knows absolutely nothing about steam but could put pipe together could pipe a boiler better than the "professional" installers who can't read.
This is the same thing.
Mod cons and 90% furnaces generally have the same flue requirements.
But every manufacturer requires something different.
You have to be able to read
Lazy4 -
They all seem to have the same vent diagram that someone that is no longer there drew in 1985 and no one that knows why it was that way is there anymore.0
Well, the other guy was going to change too much, these guys did it for a lot cheaper!!!1!0
I thought so too - window looks oem0
I stared and looked at pic for 3 minutes, usually after 3 seconds I can come up with something stupid to say that annoys most. Im speechless for first time0
That was to account for the fact the steps go up...Ironman said:I see the problem: the right vent termination is one inch higher than the left...
3 -
is that polybutylene water supply pipe(that is about the size of a fire hydrant)0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
