Why are energy efficiency standards so far behind the technology?
You lost me on this one as I also have a 70yr old fridge and know precisely how much (or little) energy it uses.... more that @ChrisJ 's, but it's quite a bit larger commercial built-in. Oh, and my Chambers stove is that old and is so well insulated that it can Cook With the Gas Turned Off!AJinCT said:
The best gas steam boilers I can find are about 83%, while gas mod/con hot water boilers are at 96%. Add in better zoning control, and steam looks like a real pig in comparison.
Gee, I guess my gas techs and their combustion analyzer lied when my latest readings were 87.2% and 87.4% respectively on my gas-conversion burners. And that doesn't even tell the entire story, as I have a naturally-induced vacuum of as much a 9" which speeds the heat to the rads and keeps the steam coming at lower temps. My 100 yr old metered valves let me adjust and zone the system as I like. Those efficiencies don't even tell the entire story as I can shut off one of my boilers when the pipes are heated and use half the gas to heat. Others do the same with a modulating or staged burner. Furthermore, I don't have to worry about freezing pipes and can use a massive set-back if I'm away for awhile. Please don't denigrate that of which you have no understanding.
The energy "experts" suggested I use my first floor ducting to supply a heat pump and just let the heat rise to the upper two floors, and ditch the steam! Absolutely NO understanding of what is required or what my system was capable of with a little tweaking and new boilers.
Well, I also say oil is the way most houses are heated. That's true, if I narrowly look at the areas I frequent in CT. Nationwide, oil is 6% of the market, less than wood. Of course there are pockets of steam, especially in Manhattan on ConEd's steam system.
Steam is pretty well spread all over the older areas of the US. I'd like to know what people are expected to use where oil isn't available? I finally replaced my last gas water heater after almost 30 yrs with an atmospheric. We frequently have power outages and It's nice to at least have hot water when there's no heat or light. It is super well-insulated and hardly ever comes on. It also wasn't too far behind some of the other WHs, but they all required electricity.
What about old people and those on a fixed income.... what sort of ROI will they see if they can even afford to replace what they have?
Sure, include MegaSteam. My list wasn't all-inclusive. However, I would say that making a government efficiency standard that effectively made only one product available in a certain category would probably be bad policy, unless there was enough of a market to get other companies to make similar products.
Say what!?
ChrisJ, I'm extremely skeptical. Even if you compared a smaller, older fridge to a much larger newer one with tons of bells and whistles, which is no longer a fair comparison, I'm still very skeptical.
I'm all for saving resources, but the entire package must be taken into consideration. It's this kind of thinking that has people ripping out old-growth windows for plastic replacements that will last 10-15 years and can't be fixed. New is not always better. Btw, I actually grew up in Europe and with the exception of France, the larger countries of Germany and UK are powered by coal.
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF1 -
@AJinCT , One of the problems you're having with this thread, I think, is that you ask questions about energy policy but you give everyone your perspectives on every technology they have or are passionate about, as if you're the expert. That's why you are not getting policy perspectives. Forget being a heating, refrigeration, envelope expert and stick to your specific policy questions. I'm not sure this site is the best place for that, although these guys know how to wring every ounce of energy out of the technology that they have the opportunity to install/maintain, they can't dictate to a Home owner what to install and how much to spend. Consider that most on this site are doing their best to properly Maintain what they have and that is what they can afford in the near term and even when the time comes to install new, they may not be in a position to afford the most energy effecient systems/products. Policy or otherwise. Put taxes on fuel and energy if you want, many will be cold because they are already stretched to the limit and, while we have demonstrated that we can pay $3.00 for a gallon of gas (and you can get by with a tax, today that takes it back up to $3.00) that is the tip of the iceberg. Just means there is less money for a more effecient heating system or better windows or whatever.1
I am the government energy enforcer. I will be stopping at your house tomorrow. I will be advising you to remove all fossil fuel burning equipment. From this day forward everything will be solar. If you refuse you will be placed in prison and all your belongings will be confiscated. They will be sold to help pay for all the energy you have wasted all your life.
Boy will I be in trouble with my 1950's warm air furnace running on powerpile, my 22 year old storage water heater (50 gallons). My two 5,000 BTU window air conditioners, My over 20 year old washer and dryer and my 15 year old refrigerator. I guess it has been a waste of time burning all the pellets in my pellet stove. Then of course there is the 30,000 gallon swimming pool in my backyard.
And just think I have been in the heating business since I was nine and I am now 76 years old, you would think I would have smartened up by now.
Say I wonder what happened to the two DOE guys who interviewed me several years ago and ended up taking notes as I talked. It seemed with all their titles and engineering degrees they did not even know that steam systems were still up and working in many major cities in America. They learned that our present infrastructure and building design does not always adapt easily to changes and especially issues with how this new high efficiency stuff has to be vented.
If you want to start somewhere start with the existing equipment which has not had an efficiency test in 20 years. Fix the stuff that is working now and don't just throw a Mod/Con piece of equipment at a problem and think it will be more efficient.
Leave it to the government, Ha that is what is wrong with America now the government screws everything up.
I really was not going to get into this discussion but here I am, sorry for the rants of an old man. I would rather fix something than throw it away.
4 -
@AjinCT I would venture to say that if it becomes the law of the land that all heating equipment be over 90% efficient, it will be become so labeled... like magic. But when you actually test this stuff out in the field, it will be less than what the label says.
I would venture to say that "real world" efficiency is more like 89%. The 90+% numbers currently advertised on heating equipment are pure absolute unalloyed marketing wank.
Why do I say this? Because when I test my very own furnace, it's only 88.7% steady state. It is only 90+% for a few seconds during the cycle, at best.
But you have shown that if facts are presented to you that do not fit neatly into your weltanschauung, you would rather disbelieve them and denigrate the informant .All Steamed Up, Inc.
https://heatinghelp.com/find-a-contractor/detail/all-steamed-up-inc0 -
I think there is at least one answer to @AJinCT 's question as to why energy standards lag so far behind technology; that being, as has already been said, the energy ratings of equipment/systems today are, for the most part, marketing hype and these technology companies and their special interest groups (including the oil industry) do what they have to to ensure there is no legislation/standards put in place that would require them to make the changes necessary to meet those standards. In reality, the lag isn't as great as what it appears. More profit for them by not having to invest in the R&D and retooling. JMHO0
AJinCT, I'll ask this again: You are aware the Empire State Building is LEED Gold certified after a recent renovation- and it has steam heat, correct?
That's right- a LEED Gold building that has a steam heat system. This would not be possible if steam was as inefficient as you say.All Steamed Up, Inc.
Consulting0 -
I already know what his response is going to be, so thinking ahead....Steamhead said:AJinCT, I'll ask this again: You are aware the Empire State Building is LEED Gold certified after a recent renovation- and it has steam heat, correct?
Some efficiency facts for our guest that He may not know.
The average 92% AFUE efficient hot air furnace uses about 70 times more electricity than a standard 80% AfUE steam boiler.
The average new forced air heat home leaks about 10% more air when the fan is off and 50% more air when the fan is on compared to other heating systems.
92% efficient hot water boilers typically use 3 to 4 times more electricity than "cast iron clunkers" .
The typical radiant system (nearly all steam systems and many hot water systems) achieve comfort levels at air temperatures about 2 to 3 degree less than air heating systems. This alone is a 6 to9 % fuel savings.
In order to achieve high AFUE number, or high combustion efficiency numbers typically electrical use must go way up.
When you take into account overall efficiency of equipment ( both gas and electrical input) and how the system interacts with the building and occupants, the old clunker cast iron steam or hot water boiler (80%) systems use less energy than 92% AFUE hot air furnace.
Steam systems do not have to be built of large pipes. Steam minitube systems have been around for 70 years or more and use small copper supply mains. A typical home uses a 1 inch copper supply with 3/8 flexible copper lines to the vary small radiation, and 1/4 inch returns. The efficiency of these systems is exceptional with an old clunker 80% efficient boiler.
96% efficient steam boiler are becoming more and more popular. The Art Institute of Chicago recently made this upgrade and it appears that there is interest at my Alma Mater, IIT in Chicago, after I was a guest lecturer on modern steam heating for the graduate Mechanical Engineering Department.
You're dismissing of steam as inherently inefficient is based on a lack of information about the development that is going on in the industry and the reapplication of vacuum system design that is beginning to occur.
One thing to remember, steam as an inherent advantage of operating at very large delta tees, which are optimum for condensing technology In addition, there are no additional energy needs for distribution.
Much of this information above is available at the US DOE.
To learn more about this professional, click here to visit their ad in Find A Contractor.3 -
Here's why the US will never get on the European standard of Condensing on all gas boilers.. There is no "trade in/scrap program" here in the US and never will be. The incentive for the consumer just isn't there.
I don't want to hear about ROI. The house you own now a days doesn't even pay an ROI for the majority of us if you add in the 30 years of taxes, maintenance, blood, sweat and tears you put into it. It's a liquid asset and so should your boiler or any piece of heating equipment.
You have to give the Hot Air industry some credit in the aspect of incentives for the consumer to purchase. Because the Hot Air Industry is more "dealer" focused unlike the hydronic industry they are more creative when it comes to the marketing of rebates and getting equipment into the consumers home.There was an error rendering this rich post.
2 -
OK. The OP's question is "Why are energy efficiency standards so far behind the technology?" It's a legitimate question with no easy answer. In fact there's no single answer. And it's complicated.
I work in the electric power industry and am a former state energy policy official. I have opinions about this topic based on my own experience and political leanings. Here are some ways I'd answer the question:
1. It's tough for government to impose stuff on consumers they may not want. It's an interesting problem: we expect politicians to do what we elect them to do (representative government) but we also expect them to 'lead', which often means telling us what's best for us.
2. It's irrational to expect that a vast majority of consumers (voters, etc.) will become self-educated and objective experts on energy policy or any other complicated subject.
3. In the energy sector consumers have historically had two primary concerns: it should be cheap and reliable. In recent years society is also much more sensitive to environmental impacts. An inside joke in my world is: cheap, clean, reliable -- pick two. Because we don't have a technology that perfectly meets all three criteria. There's (still) no free lunch.
4. A significant number of Americans think energy costs too much (due to ill-conceived government tax policy, corporate greed, or whatever).
5. A significant number of Americans think we should make fossil fuels more expensive because low prices are inhibiting the development of renewables, etc., and killing the planet.
6. Consumers in general don't want to take responsibility or make sacrifices. Another inside joke: folks show up to protest new power plants, pipelines, or whatever driving SUVs with Sierra Club stickers on the window. Or people show up in their Priuses to fight a wind farm that will ruin their view. I respect their opinions and passion but it is kind of ironic how people expect somebody else to address climate change or whatever while they live large, drive around in big cars and fly all over the place for business and pleasure. I'm not sure we really want fuel efficiency and emissions standards for airplanes. The answer to that problem, like almost every other energy problem, is to actually use less.
7. Lots of people in this country can't afford the latest and greatest technology and understandably don't want to pay for other folks (through taxes, higher electric bills, etc.) to install solar panels or insulate their homes.
I could go on and on. But when I said above that, at a high level, our energy policy is essentially "use as much as you can afford" I meant that in the context of how we don't live in a socialist economy where government gets to make all our decisions for us. A better policy, in my view, might be "only use as much as you really need." (But what if I want a big boat?)
Just my opinion but I think we're lucky to have appliance efficiency standards in the first place. Nonetheless we still have to recognize that efficiency standards in and of themselves can't overcome the impact of living in large houses, driving big cars and expecting to have unlimited hot water to take 20-minute showers everyday.
And then there's the little problem of having AFUE stickers on boilers that are essentially meaningless unless someone dials in the ODR curves, etc.
Thanks for letting me get this off my chest.1 -
There is another factor to consider -- well, several more! -- when trying to compare European practice with that in the US or Canada. I'll just hit a few.
First, there is an odd mix of very old buildings -- like very old (one place my daughter lived for a while was built in 1547, for instance) and may be difficult -- or impossible -- to put any sort of central heating in. This tends to result in either no central heat -- or very creative mini systems of one kind or another, most of which have been put in very recently. They are also rather energy inefficient in terms of envelope...
Second, there are, in many cities on the continent and southern England, many very new buildings, partly as a result of destruction during WWII. This is particularly true in Germany. They tend to be small, but were often built with more modern systems.
Third, the climate -- despite some chill conditions -- is generally warmer at the minimum and cooler for the highs. This has made the adoption of heat pumps considerably more practical.
And one last -- despite strenuous efforts on the part of far more control freak governments, the programs for retrofitting are a dismal failure. There is no reason to suppose that government mandates on the west side of the pond would be any more popular!Br. Jamie, osb
Condense that @Chester into Money. Money for fossil fuel markets. The only energy markets that do not depend on fossil fuels are wind, solar, nuclear, and hydro. Other than lubricants for components a small fraction of the energy sector. You can bet big oil has their controlling fingers in those markets also. Supply, and demand. There are lots of new extraction methods that require a barrel of oil to be at a certain level before its cost effective to do.. Very complex global market that effects huge pockets with a lot of pull.Chester said:OK. The OP's question is "Why are energy efficiency standards so far behind the technology?" It's a legitimate question with no easy answer. In fact there's no single answer. And it's complicated.
Thanks for letting me get this off my chest.0 -
The fact that the Empire State Building uses ConEd steam makes absolutely no difference whatsoever. Their steam is generated in boilers like everyone else's, so there is no difference in efficiency. Nice try.
And is that 96% mod-con actually 96%? There has been at least one instance where these efficiency numbers have been questioned. In some cases, manufacturers were quoting numbers that were almost 100%. Here is a thread on this that I was able to find quickly:
http://forum.heatinghelp.com/discussion/143588/afue-on-all-boilers-reduced-to-90
I'm sure this won't be the last time.......................All Steamed Up, Inc.
Consulting0 -
I seem to recall Jim Davis telling me many 90+ appliances run as low as 40% at times.Steamhead said:The fact that the Empire State Building uses ConEd steam makes absolutely no difference whatsoever. Their steam is generated in boilers like everyone else's, so there is no difference in efficiency. Nice try.
Suppose it's just like the 6HP shop vacs that may produce 1HP at most. Sure looks good on the sticker! Too bad it's a complete lie.
@Steamhead what would you prefer?
A snowman running @ 60% connected to a properly working steam system in a super insulated and sealed home by today's standards.
Or a 95% modcon in a drafty house with typical 1950s insulation (some places 3", some places none) and windows?
Personally, I'd take the snowman setup.
Smart...... the new house would have quality double pane windows with storms.
Not a snowman. Some of those were truly horrible. I'll go with a MegaSteam.
The envelope, of course, should be as good as one can make it. For example, as nearly as I can calculate using the Slant/Fin program, my house originally had a heat loss of 134,549 BTU per hour at a 70°F inside/0°F outside design when my great-grandfather had it built in 1924. Its present heat loss, as calculated, is 78,485- about 58% of the original loss. In my lifetime, the firing rate has been reduced from 1.65 to 0.75 GPH through a newer boiler and envelope improvements (yes, I'm still on oil). I'm still improving things as I go.
But even with a tight envelope, if there is an extended power or fuel failure, the house would eventually get down to freezing during the winter. So steam would win, since the radiators and most of the pipes drain dry when the system shuts down, drastically reducing the potential for freezing damage.All Steamed Up, Inc.
Consulting0 -
We definitely have an energy policy. It's defined and guided behind closed doors by huge multinationals (large portions of whose bottom lines depend on it) and their political minions. It may not be published, but it's quite real.AJinCT said:our energy policy is to not have an energy policy.
When oil prices cover a 5:1 range in just a few years, the likelihood of making either good public policy or good business decisions begins to approach zero.2 -
Is it? Most district steam systems I'm familiar with are entirely separate from power generation- to the extent that they are operated by entirely separate companies. The one in Baltimore was one part of BGE but has passed thru several different companies, currently owned by Veolia.AJinCT said:Steamhead, It's absolutely relevant. It is co-generated.
The AFUE testing procedure supposedly covers standby losses. And, if you minimize drafting thru a cast-iron boiler when it's off, it will hold its heat for a long time. A low-mass mod-con will cool down quickly and have to start from scratch.AJinCT said:And were those 84% boilers really 84%? And what about standby loss? The mod/cons have very little standby loss, a chunk of cast iron has significant standby loss.
What happens when you have to drain the system? Eventually any kind of antifreeze will have to be recovered for environmental reasons- I believe some European countries already regulate this. Better to not have the issue in the first place, and be able to get the heat back on with minimal repairs so you can work in a warm building fixing everything else.AJinCT said:Steamhead, Throw some Cryo-Tek in a hot water system, and get a generator. Now, no matter what, you don't have to worry about pipes freezing. Your water pipes are going to freeze too, so you have to do something to keep the building warm.
Consulting0 -
A couple of buckets? Once you add the antifreeze to the system, you would have to recover all the water in the system. That's a lot more than a couple of buckets. You really need to actually WORK with heating systems to know this,.
The AFUE standards don't.....what?All Steamed Up, Inc.
Consulting0 -
I think he's claiming AFUE doesn't account for standby losses.
Should I post Penny again?Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
In an odd sense I sort of agree with with some of the OP's aims -- better conservation is a Good Thing.
However...
In order to get any sort of consensus or discussion going, it is absolutely necessary to abandon any claims or statements which cannot be supported, with references or one's own actual experience. Such an example being the claim "a Weil-Mclain 87% boiler burns 25%+ more oil than an 87% Energy Kinetics boiler" which, in the absence of supporting field documentation -- which is not provided -- can be seen to be a product of a male bovine.
Similarly, any appeal to some sort of "standard", such as the AFUE (or, in the auto industry, the equally ludicrous CAFE or individual vehicle mileage statements) must be to a standard which is known to be fair, inclusive, and accurate. Part of the problem, of course, is that there isn't such a critter.
It is a real shame that a potentially useful thread, taking advantage of the collective knowledge which is here assembled, has been lost. That is, however, the nature of these things; I have yet -- with one or two notable exceptions -- encountered a discussion where the convinced, with little or no experience, would listen to those who actually do know what they are doing. Unfortunately, the convinced are often those in government...Br. Jamie, osb
I have a comment when it comes to nuclear power. Any and all solid fuel boiling water reactors are unsafe and completely inefficient.
It's time we revisit the Oak Ridge liquid sodium research that Nixon shut down to funnel jobs to California. That style of reactor is 96% efficient vs 3% for solid fuel reactors. That means the waste is about 30X less and the worst of that waste has to be sequestered for 300 years not 25,000 years. If you use thorium instead of uranium the fuel can't be used to build bombs and the reactor can use the long term waste from boiling water reactors as fuel - it's the only known way to get rid of long term nuclear waste.
Also liquid fuel reactors can't melt down because they are already in liquid form. With careful engineering they can be made walk away safe and need no external power for cooling - you might recall the problem at Fukushima was caused by the loss of coolant.
3PSI gauge0 -
If we priced our energy sources using some variation of full cost accounting, we might be able to eliminate 50% of related regulations and perhaps 80% of the associated bureaucracy. The consumer might not like the resulting price, but would at least be aware of the real cost. Result: a working market, much better decisions (on both sides) and a much nicer place for our descendants to live.
Doing so would pretty much turn our entire consumer-industrial-marketing-consumption complex on its head -- but that may well be what it needs.0 -
I am beginning to see a common denominator... Energy Kinetics. Nice website. Based out of Lebanon, NJ. Anybody have experience with them?Br. Jamie, osb
I've worked on a hand full of EKs system 2000 they feed heat to an ice rink. The place had four of them. Two on top two on the bottom. They seem like really good boilers. No DHW on them tho
I think that's there whole selling point is they put btus into heating the DHW so your not wasting any heat.0 -
I didn't find steam on their website?Br. Jamie, osb
I don't believe they do steam.0
I have had in depth conversations with manufacturers in the past and I understand the the AFUE standards are done with water temperatures of 140f supply and 120f return. Standby losses are also checked thus the difference between the input efficiency and DOE output which is tested. The Net rating is just a formula not a test.
The reference to the reduction of all mod/cons to 90% was due to a formula error given out by the DOE.
The R&D of any product is very expensive. Many boilers are in R&D for a year or more before they go out for testing which account for many man hours. Next is certification for the boiler and the Installation manual which is very costly. To bring a new product to market probably costs upwards of $100K or more.
When the company sells internationally such as Weil or Burnham they will offer multi level efficient boiler models at different price points to meet all needs. The more expensive equipment like the Burnham MPO has better insulation (3") like Buderus.
This is different than a company that sells in 25% of the country and offers a couple of lines like EK.
Just eliminate chimney vented boilers use OD air for combustion, install OD reset or indoor, properly size the boiler, set up the OD reset properly, avoid a lot of micro-zones and even with cast iron you'll still save 25%-40% plus for the owner. Use a mod/con and improve on that a little bit more.
I personally don't want more mandates from the government. Better educate the homeowner. We need to get more articles in places they can read them instead of hiding all our good news in industry publications.0
- 110 Chimneys & Flues
- 981 Plumbing
- 387 Solar
- 17 Recall Announcements
