What am I doing wrong
1121314151618»
  • Paul48
    Paul48 Member Posts: 4,469
    Is your tenant happy?
  • maybemark
    maybemark Member Posts: 1,131
    when he left this morning he said it's fine upstairs, he hasn't come home yet, and I was going to go upstairs, but i never did.
  • Paul48
    That's great Mark...Glad to hear it.
  • maybemark
    Paul, thanks for your help
  • Gordy
    Gordy Member Posts: 9,546
    Return temp?
  • maybemark
    I don't have a return gauge, so i don't know the temp
  • maybemark
    I just went downstairs again, feeling the 2 pipes, there is a definitely a difference, just just know by how much
  • Gordy
    What's the supply temp read, and delta.
  • maybemark
    isn't the supply and target the same?
    I'm sorry, but i don't know what the delta is, is it the %?
  • maybemark
    the temp coming out of the boiler is reading 97
  • maybemark
    the flame is 30%
  • maybemark
    gordy
    how can i tell you what the delta is, if i don't know what the return is?
  • Gordy
    Does your boiler not give the supply return, and delta read outs in a different screen?
  • maybemark
    if it does, i haven't seen it
  • maybemark
    I just went and looked at the whole menu
    it does not give return or delta
    on the home screen it shows supply and next to it target point
  • maybemark
    gordy, it does say it in the manual, but I don't know how to get to it
  • maybemark
    inlet 94
    outlet 97
    delta 3
    I learned something new
    Gordy
  • Gordy
    Your in the mid 90's for,efficiency
  • maybemark
    is that a question or a statement?
    it makes my house comfortable like this
  • maybemark
    I thought someone told me, because i have so much mass, water, large pipes and too many radiators this would be best like this
  • maybemark
    do these numbers seem right to you?
    the set point changes, with the outdoor sensor
    when it gets colder, it won't be in the 90's anymore, I think
  • Gordy
    Yup that is right as outdoor temp drops the target temp moves higher.
  • maybemark
    Gordy, you never answered, do you think these numbers are good?
