Boiler losing water
@fred ...boiler install has started, copper gone etc. Any ideas on how piping could be done right without having to turn the boiler in a different direction? Carl thinks we need to turn it facing right to make it possible to pipe per slant fin requirements.
Are there reasons you don't want to turn the boiller in a different direction? As long as you leave room for service and maintenance it should be fine. If, for some reason you can't turn the boiler, it is fine to put a 90 degree elbow on the end of the header and turn the corner so that you have a "L" shaped header. Just be sure that there is some pitch in the header, back to the equalizer and follow the installation configuration, Riser(s) from boiler, riser(s) to mains, equalier at the end following the main riser(s). You can look at some photos on this site from @Chrisj or @KC_Jones . They have installed there boilers with the 90 degree headers.0
Looks good...don't forget the relief valve drip, dangerous without0
The drip was added shortly after that picture.j a said:Looks good...don't forget the relief valve drip, dangerous without
Also, in my area the inspectors insisted on copper and with a union if necessary to make it easy to replace the valve when it leaks. I'm told they flat out fail it if done in black iron.
Chris and I are mirror images of each other with respect to the 90° bend in the header.
2 -
You guys are just showing off!
Seriously, great illustrations, I'm just sad I don't have one to add...or maybe I do. Hmmmm. Two-pipe Trane vaporvacuum system; 1466 edr
Twinned, staged Slantfin TR50s piped into 4" header with Riello G400 burners; 240K lead, 200K lag Btus. Controlled by Taco Relay and Honeywell RTH6580WF1 -
The boiler is about half done. We are not trying to hurry since we don't want to fire it up in the Summer! I will post a pic soon of where he is so far...thanks for checking in
That'll work!0
YAHOO!!0
- 167 Indoor-Air Quality
