What is wrong with this steam boiler piping
Header won't drain into the equalized properly. Header may not have the proper distance above the water line. A drop header may have been a better choice. However if you are not having any issues I would not worry about it. Is the main parallel or counter flow ?
One Pipe System4 -
I'd still repipe the problem at the left arrow. Water backing up there may cause banging, and corrosion may accelerate.
6 -
Although, if it isn't banging, it isn't backing up, or at the very least if it is backing up, it's not causing banging. Is it banging?
I think this is a trick question:
What is wrong with this steam boiler piping?
No Text, No explanation, No other information, Just a picture.
And being the proverbial Irishman that always answers a question with a question…. My reply:
"☘️ Whit aire ya talkin' 'bout? ☘️"
So without context to the question, You need to tell me more about what is happening on the job.
I was concerned as well about the constriction created by the smaller coupling going up to the system piping?
John Cockerill Exquisite Heat www.exqheat.com Precisions boiler control from indoor reset.0 -
True that is what the larger header is supposed to be for, but if you watch my videos you will see that:
- there are very rarely any drops of water that appear even inches above the boiler.
- they are not "entrained" but rather, just get randomly splashed up there. Even on my ridiculous experiments with a 5/8" supply, I never once saw a drop that would stay entrained. They just don't.
- they fall out of the steam without any need for larger headers—they just hit the wall of the pipes and are then captured
If it's not banging then, as mentioned above leave it alone.
If it is banging you should install one of these, an eccentric coupling to drain the condensation out of the header.
2 -
I think you said that before. I'm not sure I see it. Can you provide a zoomed-in screen capture showing it or draw an arrow on the photo pointing to it?
seems this union is too narrow?
The union itself looks fine, appears to be a 2" (or 3"?) from here.
But are you saying maybe the union has a bushing in the top of it and a very small nipple, like about 1"?
The photo isn't clear enough for me to know but yeah that wouldn't be ideal. Given the tiny tiny equalizer on here I guess this wouldn't shock me.
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
