What is wrong with this steam boiler piping
exqheat
exqheat Member Posts: 214
John Cockerill Exquisite Heat www.exqheat.com Precisions boiler control from indoor reset.
    109A_5 Member Posts: 4,056
    Header won't drain into the equalized properly. Header may not have the proper distance above the water line. A drop header may have been a better choice. However if you are not having any issues I would not worry about it. Is the main parallel or counter flow ?
    STEAM DOCTORMad Dog_2
    Steamhead Member Posts: 18,509
    I'd still repipe the problem at the left arrow. Water backing up there may cause banging, and corrosion may accelerate.
    Consulting
    IronmanMad Dog_2109A_5
