Another glitch on a steam install
I was out this house today casing out air conditioning. The people just bought the home. A very nice home. I’m curious how this big old 9 section boiler wil gets its steam to the system
the header is supposed to be 3 inch, they bullheaded the 2 inch into one 2 inch connector, into the mains
yes and yes. It seems like if I goof something up, the demons and vipers are biting at my heels. But when somebody else does a goofy job, everything works out just fine.
3 -
Can't see how the equalizer is tied in. @GW
The hacks get away with it all the time. Anything over 2" black is a foreign object to them. I thought I was the only one. If I had installed it like that the boiler would have likely blown up on start up.
4 -
Looks like a reducer or bushing and tee at the end of the header to make sure no condensate or carryover goes in to the equalizer…
the header is full 2 inch, all the way to the 90 that drops to the equalizer. It’s turned 45 but it is not trapping any water.
No. That's a Burnham V-89, and the outlets are tapped 2-inch.
Consulting3 -
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
