Threading options for 2-1/2 and 3" iron pipe?
mR_Slug
mR_Slug Member Posts: 13
Hi everyone. Had a search but not much turned up. I can find hand and electric threaders for upto 2" everywhere, But what about further up? Most hopeful thing I've found here, is that a dead man once hand-threaded an 8" main aparrently. So assuming this guy is built like a cigarette machine, 3-4" is possible by hand, though tough?
What are my options? Only need 2-1/2" and 3". Don't need to thread anything in-situ. BTW this is not for steam, it's thermosyphoned water. Need to make a main riser in an overhead system. Don't need to make 1000s of threads, this is a one off job. Before you say call a guy, I'm kinda on my own with this...
I CAN probably get by, by getting someone else to do the 3" stuff, but there's a fair bit of 2.5" threading. thanks.
JohnMansolf
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,545
    You can always pre-threaded. Some of the local supply places might be willing to thread pipe for you. But lots of the places will only do up to 2 in
    Ironman
  • delcrossv
    delcrossv Member Posts: 2,189
    edited April 2025
    mattmia2 Member Posts: 15,998
    anything is possible if you trade enough force for distance
    welding or copper. this doesn't sound like an application where you need steel.
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,464
    Cheaper to get it cut, reamed & threaded by a pre-fab shop & shipped to you or pick it up if nearby. Where are u located? I have two places in NY. Mad Dog
  • mR_Slug
    I have a welder, "MIG" without gas and flux core thing. Not the best tool for the job:-( I have another project that will require a real MIG welder next year, so I have considered it.
    You can't butt-weld the back of a pipe in-situ if its close to a wall (even with the same clearence to swing a 90, well not easyly). So I think I'd need lots of unions/flanges.
    It could work, though the space is tight.
    Copper is 3 times the price here. Iron pipe is cheap and my labor is free.
    Thanks it looks like the Ridgid 141 is the way to go. I've seen the head on hire for a week at a somewhat reasonable cost. Think the hand crank is probably ok for me. Initialy I was under the impression you had to use the power driver adding more cost.
    "anything is possible if you trade enough force for distance" very true.
    I will look into pre-threading/outsourcing. May end up doing both because I'll get a length wrong and have to re-do.
    I much prefer if I've got the tools and eBay-used-items are more my price range. But I assume the dies or die-head-cutters are going to be shot. It's a bit hard to tell in pictures, so new heads are on the list too, unless I'm very very lucky. I've got time, the project is a bit way off yet as I still need to rebuild the chimney.
    I'm in a place of quiet desperation called England, but thanks for the offer. I need BSPT instead of tapered NPT, so will have to source local. Here we have to contend with the metric system, even for standard/imperial 3" BSPT, its "DN80" now to make it confusing.
  • ScottSecor
    ScottSecor Member Posts: 1,021
    On a positive note, my 141 dies were changed about twenty years ago, only because one of my guys thought they were problematic. The tool is almost forty years old. In other words, the dies last a long time if you take care of them.
    You mentioned one of the pipes is close to a wall. This may be a problem for something like the 141. Might be easier to weld a slip on flange to the pipe and work from there. I am not familiar with MIG welders with steel pipe. My welder does pipe welding with stick welding (steel and stainless).
  • JohnMansolf
    JohnMansolf Member Posts: 15
    Not sure if this helps but maybe using schedule 20 steel with Victaulic fittings.
  • leonz
    leonz Member Posts: 1,791
    edited April 2025
    Mr. Slug,
    The Victaulic flange clamps are easy to install as long as you have the rubber gaskets lubed up with their lubricant or Vaseline. If you have to install a vertical riser you will need to secure the Victaulic pipe with their pipe securing clamps/parts as they will be very easy use.
    They also have Victaulic groove pipe to thread adapters of all sorts and threads that are easy to use.
    You would need to rent or buy a Victaulic pipe groover for the various pipe joints/elbows or have it done by the Victaulic reseller for you.
    The Victaulic people have worldwide representation and you can search their home page to see who and where they have reseller representatives in England.
    Having installed 2 inch Victaulic pipe and Victaulic clamps and hung by hand in a mine roof for long distance compressed air supply I can tell you it is very easy to work with and the installation will go much faster than what you are contemplating by using the Victaulic to pipe thread adapters.
    VicEuro@victaulic.com
    United Kingdom
    Units B1 & B2
    Cockerell Close off Gunnels Wood Road
    Stevenage, Hertfordshire
    SG1 2NB
    Telephone +44 1438 310 690
    HydronicMike
    with planning you can tack the part that is against the wall in place then remove it to finish weld it and plan your in in situ welds where you have room. remember to allow for expansion too.
  • delcrossv
    Wasn't there some issue with using Victaulic with hot water posted here some time ago?
    EBEBRATT-Ed Member Posts: 19,887
    Vic is fine with HW as long as you stay under 190 or so. There are gaskets now are rated at 250. Don't believe that they will not last at that te,mp.
    @mR_Slug believe me 1 thread with the hand ratchet and you will wish you never tried that. They are extremely slow. I would bet 20 min to cut a 2 1/2 inch thread …..if you don't stop.
    We have Taylor Rental in my area (MA) that rents the Ridgid 141 and a 700 to drive it. You would also need a vise large enough to hold the pipe.
    I threaded a lot of 2 1/2-4".
    Best way is to draw a line around the pipe with a welders 'Wrap around" and use a porta band to cut the pipe. With a little practice you can cut straight.
    Don't even think about using the 4" cutter, it will kill you.
    The 141 can be driven off a 700 with the adapter or of a ridgid 300 or any other pipe machine with a drive shaft.
    The best way to drive it is with the short drive shaft close coupled to the Ridgid 300. That takes the least effort.
    But it depends on how much you have to do. Having a pipe shop or a supply house cut and thread for you is an option if you can measure well
    Vic is a better option for water but take your wallet with you and your bank account the fittings are $$$$$$
    You can order pipe that is already grooved from a supply house.
    You don't want a typical Plumbing Supply. You need a supply house that sells PVF (pipe valves and fittings)
    mattmia2ScottSecorIronmanethicalpaul
  • Mad Dog_2
    Where is this guy located? Mad Dog
  • ScottSecor
    England. I think.
  • Mad Dog_2
    Oh Forget it! Mad Dog
  • retiredguy
    retiredguy Member Posts: 1,084
    edited April 2025
    Most of the guys that gave you advice or answered your question have threaded everything from 1/8" through 4", including "Vic" fittings, as have I. Threading steel pipe up through 2" is just part of a boiler install. Threading 2.5" through 4" is not for the faint of heart, nor is it a job we all loved to do. Unless you are going to thread a lot of pipe over 2" I would recommend that you find a shop or pipe supplier to thread the few pieces you need. Don't waste your money or time buying the large threading tools. Time is money, and hand threading anything over 2" takes a lot of time, muscle and patience.
    Mad Dog_2
  • ratio
    ratio Member Posts: 4,202
    I got two milk crates full of dies, a few ratchets, a less-than-new tripod, and no fewer than two 141s for what worked out to about 10¢/lb from the local Craigslist.
    I've hand-threaded 4" in the past. Not something I'd do for money, but I would probably do it for Grandma's boiler if time wasn't critical.
    delcrossvIntplm.Mad Dog_2
  • Intplm.
    Intplm. Member Posts: 2,906
    When I was doing it, anything over two inches was welded. It was just too labor-intensive to thread a big four-inch joint just to have to pull it apart or weld it when a thread was there.
    If it's water? Use copper and pro-press or solder the joints.
    You can also look into using Victaulic or Gruvlok fittings with a roll groover.
  • Mad Dog_2
    edited April 2025
    The summer of 1987... on Rikers Island Correctional Facility in the East River, I spent 8 or 9 weeks cutting & threading 2" Galvanized pipe & Hack sawing 1 1/2" Kindorf racks and 3/8" threaded rod by hand in the blazing sun & rain... My Plumbing foreman, Joey Davis (RIP), was a real Hard-A-- that tried to break every Apprentice they gave him.
    I knew the shop had many Ridgid 300 electric threading machines, but I didn't say a peep & apparently the shop weren't complaining how long it was taking...I started that job with 16" biceps & by end of the summer they were 17 1/2"... (yes, back then, we were always comparing Arm size ..it was a status symbol....ha ha). Mad Dog
  • ratio
    The two trades I never argue with are pipe fitters and masons.
    delcrossvIntplm.
    Many complain about the labor involved in welding and it is significant. But so is threading anything larger than 2".
    If you have two guy one fitting and one welding you can move along pretty well. We did a High pressure steam job where we welded the 3" steam supply and threaded the 2 1/2" condensate .
    The reason was at that time we had 1 welder and 1 welding machine and had to get the job done.
    Using a Ridgid 300 to thread 2 1/2-4" is a lot easier with the close coupled drive shaft, it goes a lot quicker than using a 700 or the long drive shaft.
    I was told that the way Victaulic & Groovelock price there fittings is they figure how much a welded job would cost and adjust there fitting prices to be a little less than that.
    Mad Dog_2Intplm.
  • mR_Slug
    Not heard of Victaulic fittings. Clever idea. I think I'd need the 250, the 190max is too close to the 180/170/160 temps from the boiler stove. But quite expensive.
    With the threader I can make all the pipes on the floor and then musscle it in. The weld option is interesting but I just think its going to require much more planning to install. Not saying a master welder would find it hard, just that I would.
    ScottSecor, Interesting about the longivity of the dies. I guess on average, in the second-hand market, im going to get one with 50% wear, (half good dies, half worn dies).
    There is one local to me but it looks a bit deralict. What you think?, going to have to get better pic of dies. It's the closest and coincedently the cheapest. Think its missing the loop-hook for the machine. https://www.ebay.co.uk/itm/302675127404
    EBEBRATT-Ed Yeah it does look very slow. In the traning videos they don't show that part very long, cut to the pipe machine quicky. 3" is the max I need to cut. I just had a look at my 'big' cutter and 2.5" is doubtful, so the 4" cutter must be huge. Thanks
    Don't think I've got anything to mount it to. You need the fine motor control of the pipe machine. You need to be able to slow it down properly. May be the used market + hope or rental for a 300.
    retiredguy, You do make a good point. As others have said too, pre-threaed may be better,
    I'm kinda interested in cutting my own, but it does look like the "fun" part of cutting a 3" thread is quickly outweighed by the "burn" part in the bicept.
    Mad Dog_2 A day or two of threading is a job, but 9 weeks in blazing sun and rain? Sounds like you had a harder time than the prisioners.
    Thing is with welding, say you make a mistake and have to cut a pipe shorter. An angel grinder with cutting disc will do the job, but how do you get a true 90, in a tight space? If I was a very experienced welder I think I'd give it a go, but With threads can unthread, recut and rethread.
    Think I read somewhere that x-pando or some special dope was recommended on > 2"? Thanks everyone.
    Mad Dog_2
    that's how my uncles and cousins did stuff. and they did better drinking all day than many supposed professionals do now.
    ethicalpaulpecmsg
    with welding what you'd do is put pieces together and make just a tack weld in a spot or 2 at each joint in place until you fit the whole thing, then you'd think about what you can finish weld in place and what you can maneuver in and out in one piece and you'd cut the tack welds where you can make your finish welds in place. then you'd take your subassemblies outside or to a work area and make the finish welds on those joints, put then back in place, and weld them together.
    you can buy weld fittings and weld to the fitting rather than mitering or bending the pipe.
    you can also buy pre threaded nipples and threaded fittings and mix and match with welded parts.
    watch someone make custom exhaust systems, it is the same idea but heavier.
  • Mad Dog_2
    Nah..Went home at night, had a Tan George Hamilton would envy & got jacked...any day on this side of the bars is always better than a great day behind em! Mad Dog
    heathead
    @mR_Slug
    I would look into renting the equipment or having a supply house cut and thread for you unless you think you will use it on another job. The cost of rental may exceed the price of buying used equipment…..it depends how long you use it.
    Most of the 141s I see on Facebook Marketplace are going for about $1000. The you need a vise and something to drive the die like a Ridgid 700.
    There is one 141 on Facebook Marketplace for $75 but it is PU only in Holliston, MA.
    Looks like it is ok.
    Where are you located??
  • ScottSecor
    @EBEBRATT-Ed I believe the original poster is from United Kingdom and needs British threads (BSP).
    @mR_Slug the unit you found on Ebay looks ok. However, I would be a little concerned that the seller does not appear to show us the end of the tool with the dies that actually cut the threads.
  • leonz
    mR. slug,
    if you contact the Victaulic reseller I listed in my last post they can give you everything you need to do the job in one order and rent an electric powered groover to you for the Victaulic pipe joints and perhaps pipe vices if you need them.
    They will sell you the Victaulic pipe clamps, Victaulic to British Standard Pipe fittings, black neoprene gaskets and gasket lubricant in one order.
  • jumper
    jumper Member Posts: 2,512
    Baker type couplings? Expensive but fast & easy.
