Burner technicians -what’s going on in this industry?
Northuupthere
Northuupthere Member Posts: 2
edited March 2025 in Oil Heating
I’ve always taken care of my boiler tune ups myself- for decades. I’ve gotten older and my hands have arthritis so last year in January of 2024 I decided to sign up with an established well know oil company in the area for their automatic delivery and annual tune up which includes emergency burner 24/7 no heat situations which as I get older, I will admit is appealing to have somebody on call if I need emergency service.
Their first tune up in February 2024 it was a younger guy. I know they are learning and don’t have decades of knowledge. I get it. But he didn’t have the correct nozzles for my Riello. So he used a different one with a different firing rate and instead of setting the pump pressure to account for the different firing rate of the different nozzle with a pressure gauge he used his combustion analyzer as a best guess. This also resulted in him adjusting the air shutter.
He also installed the baffles into the boiler incorrectly and afterwards it generally was running loud and hard startup bang - so not like it used to.
So in April, I called them back and they sent out one of their “senior “ Technicians to put the correct nozzle in and set the pump pressure with the gauge and correct the baffles and air shutter.
I told the company I don’t want any more young guys working on my equipment.
So for this year‘s annual tuneup I requested they send the same senior technician out that came to fix the younger guys problems, but of course he retired and moved to Florida so they told me they would send another “senior” technician with 35 years experience.
Well, as it turns out he didn’t replace the pump strainer and didn’t do an efficiency test with the combustion analyzer. All he did was change the nozzle, looked inside to see if it needed to be vacuumed, and replaced the spin on filter.
What’s worse is he lied right to my face when I asked him What the combustion numbers were. He told me it’s running great 86% efficiency.
I have an extensive home security system with cameras in the basement so I saw it all with my own eyes.
I decided not to call him on his lie because I have enough stress in my life and I didn’t wanna get into an argument with the guy so I said thank you and sent him on his way.
What’s going on with the industry? I remember the days when guys cared about their work and were thorough and did a good job. Now it seems like you get a young guy that knows nothing about nothing or a senior guy that is washed up with a bad back and tired of the trade. I’ve decided to go back to will call oil deliveries and doing my tuneups myself. I do a better job.
Mad Dog_2Alan (California Radiant) ForbesLRCCBJ
«1
    ethicalpaul Member Posts: 8,376
    edited March 2025
    It sounds like you are blaming the younger guys for this issue, but they are just doing what they were trained (or not trained) to do. The fault lies in that company's management.
    At my mother's house the oil supplier's contracted maintenance consisted of something but I don't know what. I never saw a combustion report and I don't think they spent enough time to clean or check very much.
    I found another company that is HVAC but not oil delivery and I pay them to do a good cleaning and nozzle replacement.
    I'm not saying all oil companies have this problem, @EdTheHeaterMan , but this one did.
    Mad Dog_2
  • Northuupthere
    Common sense thinking should prevail though. A skilled tech should know enough to use a pressure gauge for setting pressure. Not how he was trained. They’re not mechanically inclined it seems. Old timers figured things out on their own and didn’t follow textbook teachings.
    Mad Dog_2
    EBEBRATT-Ed Member Posts: 19,891
    edited March 2025
    The end has been coming for the last 15 years at least.
    Oil burner techs have always been at the bottom of the tier.
    And I say that with regret. I started out as an oil tech 53 years ago and still have my license. I moved on to other things.
    The average age of technicians, plumbers, electricians etc is around 60 years old.
    Many of the trade schools have closed and junior highs and high schools closed their shops years ago.
    Commercials about "plumbers butt" jokes etc has demeaned the trades. The media has fostered this and the trades and trade schools are looked down on.
    I used to teach at the local union hall.
    I gave up years ago. The new techs are not interested in learning prefering to google the answers
    Mad Dog_2LRCCBJ
    Jamie Hall Member Posts: 27,009
    This is speculation, @Northuupthere, but I think you are seeing a combination of at least two things: first, a rather unfortunate combination of the average consumer (not you!) demanding the lowest possible cost for service and parts and whatever, driving companies (or some individuals) to cut corners — but that combined with many younger people not being accustomed to equipment and systems which actually need to be adjusted and tuned. Their world is almost entirely "plug and play" computer controlled wizardry which, it is correct to say, either works or doesn't work — and if it doesn't work, you throw it out and plug in a new one.
    In the automotive business, that's referred to as firing the parts cannon, and is now normal — it's rare to find a mechanic who can actually find the cause of a problem and fix it.
    Mad Dog_2LRCCBJttekushan_3
    pecmsg Member Posts: 6,886
    Unfortunately common sense went out the door a long time ago.
    Getting someone to show up every morning is difficult. Most of today's techs have no desire to learn or work.
    Did you call the contractor back and inform him / her of what was / wasn't done?
    Mad Dog_2
    Well as you said, he is not an old timer yet, he is a kid
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,469
    edited March 2025
    In all fairness to "the kid" (18? 19? 20? 26? Have to define kid) In Long Island and NYC Riello oil and gas guns are relatively kind rare to see. 25-30 yrs ago many of the oil men in their 50s & 60s didn't have any training on them. They are the Finest Oil Burners out there, but they are very finicky to set up and you REALLY need some factory training. Mad Dog
    techforlife
  • guzzinerd
    guzzinerd Member Posts: 412
    Trade unions have always been a liberal cornerstone. Has that changed?
    Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
    GroundUp
    hot_rod Member Posts: 27,079
    $$$ is the root of…
    In Europe most folks live a fairly lean lifestyle. They stay in the same home for generations. The homes are built to last for generations. The young people are not so attracted to the easy money lure. Their quest is not to be a reality star, influencer, manipulate money for a living without any product being developed, game the system, on and on.
    The crafts and trades are more alive and carrying on in other places in the world.
    I'm not sure how we turn the tide here? Even with some high wage offerings, many just don't want to get dirty, be labeled as a blue collar worker.
    More and more, even high ticket items are throwaway. We don't repair like we used to.
    But we need to keep spreading the message of what the trades have to offer in addition to the $$.
    Mad Dog_2jesmed1LRCCBJmikeapolis
    When I started there were no cell phones, computers, fax machines or beepers.
    You went to the job and were literally on your own. No one could help you. You stayed and figured it out or at the very least you took it as far as you could possibly go. That is how I learned to troubleshoot. If the shop needed to get ahold of you, they called the customer land line.
    No googling, no asking just you. That is how you learn.
    Computer and cell phones and tablets are great, but they have ruined some things.
    I taught at the union hall for years then gave up.
    All they want to do when they get stuck with a problem is avoid thinking and avoid using their brain.
    Google the answer, call another tech, call tech support, call the boss, their mother, sister, wife or friend.
    The last year I taught I had 2 out of 10 that were interested in learning. It isn't about money the union paid well to teach. It takes some effort to put a class together on what you will teach, make up tests and quizzes, make copies etc.
    The ones that teach do it to give back and because they like the business.
    I had enough. Did it for 6 years.
    Mad Dog_2techforlifeLRCCBJ
  • guzzinerd
    edited March 2025
    I graduated southside high school in Rockville in 1973 we had available to us
    auto mechanics, electronic, woodworking, printing, cooking, along host of others, and none of them are available to the kids today
    at least you an idea of what you and what you didn’t.
    Mad Dog_2
  • Grallert
    Grallert Member Posts: 1,075
    The oil companies can't afford to keep the good techs. They cost them money and it's not always the case that their oil sales make up the difference and training. There are few if any training centers and it's expensive to enroll. It's been a few years, but every time I removed an old clunker with a tankless and replaced it with a nice G115 and an indirect we lost a big portion of that customers oil sales. At the end of my service career I had to carry a fixed pricing book in order to try and make up the difference. I was no longer able to have the conversations with customers who were curious about their systems and potential up grades. We lost to gas and discount oil. I got bored and tired.
  • guzzinerd
    Out here in the West the FFA is still very common in public schools, teaching welding, mechanics, animal husbandry etc. My 16 year old, daughter, is welding already.
    Mad Dog_2pecmsgtechforlifeCLamb
  • Mad Dog_2
    Entering the trade in 1985, I too did not have a cell phone, no fixes et cetera. My greatest teacher of the Plumbing trade was Jimmy O' Brien (RIP asbestosis) born in Dublin early 1940s. When he was 12, he went to live with an Irish Master Plumbers Family and started an Apprenticeship program. He came to NYC at age 19 and was light years ahead of the other guys in the Apprenticeship program here.
    Jimmy had an outstanding vocabulary & intellect & came across as college educated. This is what we need Here...NOW..Mad Dog
    Grallertttekushan_3Intplm.
  • Mad Dog_2
    edited March 2025
    I also encourage African Americans & Latinos & women from the poor neighborhoods & the projects to come in to our trade for many years and they are wisely getting on board and making great things happen for them in their Familes. Mad Dog
    jesmed1GGrossbburdCLamb
  • RTW
    RTW Member Posts: 276
    Interestingly, these same so called "established well know oil company in the area " quoted from post that lack the basic ability to annually service the oil burner, also claim they can install new boilers / burners with expertise - smh
    I doubt trained service in steam heat / burner maintenance is given more than an hour or two in the education curriculum these days. The industry is about dead with a few greying older guys remaining with proper knowledge that will die with them - RIP
    Regards,
    RTW
    LRCCBJ
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,034
    Hi @Northuupthere , It would take time, but maybe there is a work-around. Do you have access to a younger person who you could teach to do your boiler work? Get them started on yours. Pay them. Encourage them to learn from others. You would be handing them a career path if they wanted. 🤔
    Yours, Larry
    Mad Dog_2mattmia2GGrossdelcrossv
  • Mad Dog_2
    Larry....great idea.Mad Dog
  • Mad Dog_2
    I'm very happy today and so is the young lad I just connected with my old plumbing shop. 23, Associates degree in Business. VG suburban family, not an office guy. He starts at the bottom in the warehouse Monday. Mad Dog
    CLamb
  • Mad Dog_2
    Kids Gotta bang around in menial jobs sometimes before they see things clearly..I did..Mad Dog
    CLamb
  • guzzinerd
    The UA and the local I belong to has been trying hard to up there game in the training area. It used to be that the UA was plumbers & pipefitters only and they looked down on HVAC service and oil burner work. No longer they have embraced it.
    I am not sure they have made a lot of progress with it but they are trying.
    I have been out of touch since I retired from working and stopped teaching.
    I do have a code update class to go to this Saturday to keep my Gasfitters license. (why I keep it I don't know but I can't let it go) but I will try and find out what is happening with training
    Mad Dog_2pecmsgCLamb
  • RascalOrnery
    RascalOrnery Member Posts: 124
    Kids learn calculus but can't fry an egg. Learn Spanish and then cant speak it, watch sports and play video games on the weekend. There are young people seeing the light thankfully, just not as many as should be. For those in the northeast check out Williamson trade school in Pennsylvania. Free, over hundred percent job placement.
    mattmia2Mad Dog_2CLambMaxMercy
  • Grallert
    My life got turned around when my employer sent me and another guy to NEFI. I had absolutely no knowledge of oil burners before then. From there I immersed myself in the trade with a particular interest in steam. Then I found the Dead Mans Steam School. I still have the VCR tapes. Ha! but no VCR to play them on. I heard NEFI closed its doors a while ago.
    Mad Dog_2CLamb
    This is a generational thing also. When most of us grew up in the trades there were no cell phones, video games, computers. So the kids growing up with those toys (tools) think differently about career choices.
    It will change again. Will Al make training obsolete, just ask how to service an oil burner and the answer and a video shows up.
    Will it be correct????
    Mad Dog_2
  • SlamDunk
    SlamDunk Member Posts: 1,795
    edited March 2025
    I had a different experience. During HS, my father got me a job working for him, cleaning all the bathrooms at night in a 16 story building, taking out the trash, painting, re-lamping light fixtures, unclog toilets, cleaning the old Federal boilers. I loved it.
    But the old man insisted I go to college. He said, do you think I like working for "the man"? I am wholly dependent on him, his ability to run his business, his moods…If he says jump, we jump. We have to lick his boots. We have no education and we are limited. We can't go wherever we want. But, if you graduate from college and decide to come back to this, it is YOUR decision. At least you have a choice in the matter and a degree that let's you walk if the situation is't right. Unlike us-we're stuck here.
    It's the American dream , really. To have your kids do better than you. So, I don't slam a college education. I am better for it in so many ways and I still clean boilers and unclog toilets. 'Tis my choice.
    mattmia2bburdMad Dog_2
  • jesmed1
    jesmed1 Member Posts: 1,357
    I'll never trust AI to give service instructions on any device that could burn my house down. Even if AI does become a training tool, we'll still need pros like you who can correct the AI when it gives wrong answers. Hopefully before any damage gets done!
    CLambMad Dog_2
    mattmia2 Member Posts: 16,015
    but you would have got your asbestos from brake and clutch linings instead of furnace cement and aircell
    Mad Dog_2ttekushan_3
    if you follow the oil tech talk chatter FB it looks like dirty work still?
    who is checking the Al answers? Al?
    My nieces and nephews would drive around the earth to arrive at the house next door, if that is what google maps told them to do :)
    jesmed1Mad Dog_2LRCCBJttekushan_3
    HVACNUT Member Posts: 7,307
    You're talking about the Waze app. That thing will take you through people's kitchens.
