How do you know where to dig a well for drinking water?
Intplm.
Intplm. Member Posts: 3,030
I have heard of and have seen many ways of finding the elusive underground water source.
How have you found potable water and has it been consistently successful?
«1
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,552
    Divining rods.  Mad Dog
    MikeAmannmattmia2delcrossv
  • Intplm.
    Is that the same as what is called witching sticks?
    HVACNUT Member Posts: 7,460
  • JMWHVAC
    JMWHVAC Member Posts: 110
    Divining rods, witching sticks, ouja board, etc, etc, all the same thing. Not scientific and they say you have to believe in it for it to work. Gods creation laws work whether a person believes in them or not. As a Christian I urge any and all to not use witchcraft.
  • JMWHVAC
    Here in PA we let the drilling rig find our water. Once in a while we do get a 500' dry well. Then we move to a different spot and try again.
    Jamie Hall Member Posts: 27,392
    When I was working in Vermont I had a good friend who used divining rods. Hew swore they worked. Most of the state, though, if you poke a hole in the ground you are going to hit water -- eventually, and how much may be a question.
    A reasonably competent geologist can make some pretty good guesses at depth and yield and probable quality, though... and I wonder about said friend, as he was also a pretty competent geologist...
    I could never make them work.
    On the other hand, I've had pretty good success in years gone by. With one notable exception: we needed a well for a new high school south of Rutland. In marble. I was kind of doubtful even before we started drilling... but on the third try, after two 800 foot dry holes (! -- if you don't think that didn't cost!) we hit just enough water to supply the school. Hardness was off the charts... yield was low... but it did the job.
    MaxMercy
  • DCContrarian
    DCContrarian Member Posts: 1,462
    I like to survey the site and figure out where it would be most convenient to dig the trench back to the house. Because you know that's the one spot water isn't going to be!
    ratioEdTheHeaterManPRRIntplm.
    There's also the little matter of where can you get the rig -- those things are heavy.
    Intplm.
  • dko
    dko Member Posts: 669
    It must work with all those 5 star reviews on amazon for dowsing rods.
    :D
    PC7060
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,111
    When I had my well drilled, the driller witched it, and guaranteed that he would find water or no charge. He found water 🤠👍
    Yours, Larry
    PC7060delcrossv
    EBEBRATT-Ed Member Posts: 20,207
    They say metal coat hangers straightened out will work we did it several times out in back of our high school in science class. The hangers crossed in the same spot for several students. Was there water there we will never know?
    I hate to say this -- but unless you are very unfortunate (see my earlier comment) there will be water there. How much and how good is another question -- but it will be there. Anywhere.
    Intplm.
  • ChrisJ
    ChrisJ Member Posts: 17,399
    edited April 2024
    You contact Willie the Well-Witcher
    But beware of the high handed code.  As amended in 1912.   Although that may have been replaced by The Stupid and Ridiculous Law of 1966.
     :D
    That aside,I have no doubt holding sticks etc does absolutely nothing.
    hot_rod Member Posts: 27,489
    I’ve found copper water lines with brazing stick divining rods
    It works for some, not others. I have seen excavators use them to find buried lines
    delcrossv
  • ChrisJ
    Can you explain the science behind how they work?
    pecmsg Member Posts: 7,076
    Let the wife deicide
    there never Wrong!
    ChrisJPC7060Intplm.
  • leonz
    leonz Member Posts: 1,816
    Folks that are Dowsers use crystals and are very successful in
    finding water and they can also tell you how deep it is.
  • ChrisJ
    there never Wrong!
    That method at least has logic behind it.
    Certainly much less painful
    BrassFinger
  • Mad Dog_2
    I am a Roman Catholic, not in to Wicthie-poo, Wiccan, or any of that, but I have seen divining rods work a few times. A Big Well Drilling company upstate.  Don't ask me the science behind it. Mad Dog
  • JMWHVAC
    There is no science behind it. Rather it is the power of darkness behind it and yes, sometimes it produces supernatural results. If I experience something supernatural, I want it to be the power of God, not power from the other side. I realize some professing Christians do dowsing. I leave them to God but the Devil can come as an angel of light.
  • ChrisJ
    PC7060 said:
    We need a “huh?” button.
    Not until I get my good grief button. I've been asking for years.
    CanuckerPC7060GGrossZman
  • dko
    I can't tell if some people are being humorous, sarcastic or serious.
    Intplm.Mad Dog_2
  • MikeL_2
    MikeL_2 Member Posts: 544
     A successful Dowser I know uses a forked branch from a willow tree to locate drilling sites.
  • Gsmith
    Gsmith Member Posts: 444
    As Jamie Hall noted, in most well watered areas of the US, say eastern US, if you dig you will find water, how much yield (rate of flow) is dependent on the rock or material type. A number of hydrogeologists (geologists specializing in ground water) that I know, study aerial photos to look for fracture traces which are linear physical indications on the surface of fractures in the bedrock below. They look for places where two or more fracture traces intersect and drill there, the idea being that intersecting fractured areas in the bedrock will yield more water. This always seemed like a bit of voodoo to me, as I could never find them on the aerial photos, but when pointed out I could kinda see them.
    Mad Dog_2
    It is sort of voodoo, @Gsmith , but if one has studied enough photos (stereo pairs are far far better than single shots!) one kind of gets a feel for what you are looking for. I'm not at all sure it's a really learnable talent -- it almost seems from working with folks over the years that either you can see that sort of thing or not.
    And I can assure you that if you can find intersecting fracture zones in otherwise pretty stingy rock you can create some pretty good rock wells. Not to boast, just the truth, but I managed to find a 48 gpm/72 hour test well that way a few years back. The city water company was very happy...
    Intplm.
  • psb75
    psb75 Member Posts: 1,132
    Here's another 'proven' method: ask around in your neighborhood about other drilled wells. Or check on your state map for drilled-well statistics. Even this is not a 'guaranteed' approach. I have seen next-door neighbors with very different results. Its just...mysterious...down there. Even 8-10' down! Ask someone with a leaky basement. I live in a state that has the home of the American Society of Dowsers--Bro. Jamie knows which one that is. Some dowsers even profess to be able to DIVERT water! I sense that some folks on this thread are "less comfortable" with 'earth mysteries.' You could...just let the mystery be.
  • RTW
    RTW Member Posts: 285
    edited April 2024
    BY LARRY: When I had my well drilled, the driller witched it, and guaranteed that he would find water or no charge. He found water 🤠👍
    Yours, Larry
    BY RTW: this quote reminds me of Babe Ruth coming up to bat and pointing in the direction of where his next homerun would go, and it did in 1932 World series against the Cubs. Haha
    Mad Dog_2
  • Larry Weingarten
    edited April 2024
    Hi @RTR , I've come to believe that magic is something we simply don't understand yet. Babe must have understood ⚾️
    Yours, Larry
  • ChrisJ
    Hi @RTR , I've come to believe that magic is something we simply don't understand yet. Babe must have understood ⚾️ Yours, Larry
    She even signed her name on it. Some lady named... Ruth, Baby Ruth.
    Who is she?
  • Intplm.
    edited April 2024
    Hmm...seems like an applied form of dead reconning combined with dumb luck? Excellent responses.
    Surely science seems to have the edge here. Sticks/rods are used for show?
  • ratio
    ratio Member Posts: 4,242
    It's interesting to see this. If what I've read can be believed, the statistics of dowsing are well beyond random chance, and only dogmatic believe (note: scientism falls into this category) opposes it.
    I have not, however, been interested enough to look into it myself.
  • Dave Carpentier
    Dave Carpentier Member Posts: 640
    When I was tasked with locating underground telecom lines (using electronics) , I would occasionally work alongside other utilities. I was shocked one day to see a water guy 'witch' for a locate. He said how else are you going to located a plastic line. He was on the mark.
    When some relatives had a well witched, the gal had a few hits on the property but noted a crossing of good strengths in one spot. Turned out to be artesian at about 24ft.
    I tried witching a couple of times, I didnt get any 'signal'. Maybe I'm not conductive ? lol
    My take on it all? Whatever works for you.
    Intplm.
  • Mad Dog_2
    RTW...and Broadway Joe Namath 1969 Superbowl:  "I guarantee it!."  Mad Dog
  • ChrisJ
    If no one knows where either of my quotes came from, especially the last one I'm going to be highly disappointed.
  • PRR
    PRR Member Posts: 224
    edited April 2024
    ChrisJ said:
    Some lady named... Ruth, Baby Ruth. Who is she?
    Nothing to do with Babe ⚾️ (or did it???), and Baby Ruth died quite young. https://en.wikipedia.org/wiki/Ruth_Cleveland
    I'm not a scientist, just a plumber.
    I'll send a You Tube of me locating the water lines in my yard if you like. I don't do wells, just pipes :)
    I've never seen it work for a non believer, if that helps.
    https://www.usgs.gov/special-topics/water-science-school/science/water-dowsing
  • ChrisJ
    edited April 2024
    You already know roughly where the pipes are, so in that case I'm sure it'll work.
    https://en.wikipedia.org/wiki/Ideomotor_phenomenon
    That's a good read regardless of the topic.
    Am I a non-believer? I'd say 80%, but there's some curiosity. I have no way of knowing for sure that it doesn't work right now.
  • hcpatel78
    hcpatel78 Member Posts: 157
    edited July 2024
    Earth Magnetism! -There is a science behind that.
    Thank you,
    Hiren Patel
