Thanks JohnNY (Gateway)
I want to give recognition to @JohnNY and his company. Using the forum he helped me understand why my boiler was not performing properly. It starts with the near boiler piping was completely wrong. There was no header so water was going right into the mains. In addition, they came out and repiped the boiler and it runs correctly and pretty quietly.
Have him fix your pressure relief valve, too!
I don't see the relief valve in that picture.ethicalpaul said:Have him fix your pressure relief valve, too!
Because it's hiding due to being in the wrong orientationNJ Steam Homeowner.
See my sight glass boiler videos: https://bit.ly/3sZW1el5 -
Why wouldnt work like that? ( he winces as he asks).0
I assume it's because in that position it will collect a lot of gunk and be blocked from "feeling" the high pressure it is supposed to protect againstSlamDunk said:Why wouldnt work like that? ( he winces as he asks).
They were installed like that for 100 yrs, but unfortunately last 20 or so, they recd vertical and I agree with it. LESS likely to clog with splunck. I actually prefer to mount them higher. In any case? Relief valve should be tested annually & replaced every 5-7 yrs... Piece of mind. Mad Dog 🐕3
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
