38 year old boiler - is it the cause of high gas bills?
Have Foley Mechanical out every fall to maintain it. Foley can also give you a quote to replace it with a mod-con. A mod-con will use approximately 15 percent less gas than your current boiler, but it wont last 38 years.
https://heatinghelp.com/find-a-contractor/detail/foley-mechanical-inc
Personally, I'd keep what you have until it kicks the can. I would get annual professional maintenance.
What do you do for Air Conditioning? A combination Heat Pump Air Conditioner could save you operating costs on spring and fall days. I'd keep the boiler you currently have for the 20 coldest days of the year.
2 -
200 bucks to heat a 25oo sq ft home is not bad . the cost of replacement would be ions for return on investment . all would be happy to pay so little to heat a home of your size my self included . you should have your boiler serviced and looked at least once a year to avoid any safety issues and to ensure that it is working properly and that there are no safety issues including proper chimney venting ,flame roll out and or flame impingement . this can and should be done . peace and good luck and if dan foley services your area you can do no better .
peace and good luck clammyR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Specializing in steam and hydronic heating3 -
I’m a bit north of you and if you have ductwork, adding a heat pump could save you a good bit. Do it when replacing the AC and it’s more or less free. In our climate, ditching gas makes sense since electricity is pretty cheap.0
$200 per month is not a high gas bill for a drafty 2500 square foot house. In fact, it’s quite reasonable.
The best thing you can do to save energy is to tighten up the envelope of the house: caulk, weatherstripping and insulation are cheaper than fuel.
At 38 years old, your boiler is near the end of its useful life. When that time comes, a mod/con boiler may be a good option.
As mentioned, Dan Foley of Foley Mechanical in Lorton is one the best in the country.Bob Boan
You can choose to do what you want, but you cannot choose the consequences.2 -
I agree completely with the $200/month being very reasonable. The Dunkirk is a fairly efficient design. I doubt a new boiler, with repairs, parts and maintenance will see much of a savings.
There are folks here in New York in new houses with "modern, clean electric heat" paying six times your bill each month.4 -
I pay that much during a cold snap and my house is only 1600 sqft and I'm 300miles south of you. Are you sure you meant 200& not 2000?0
My 75 yr old boiler ran up $1200 during a cold snap last year. Fuel is less now and I've tuned it all up with vents and traps but still paid $400 during the last snap, for 3800sq ft.
$200 is amazing for a house that size.Bryant 245-8, 430k btu, 2-pipe steam in a 1930s 6-unit 1-story apt building in the NM mountains. 26 radiators 3800sqf
So do I. I can go through twice that in a week in cold weather...Br. Jamie, osb
This.Ironman said:$200 per month is not a high gas bill for a drafty 2500 square foot house. In fact, it’s quite reasonable.
........As mentioned, Dan Foley of Foley Mechanical in Lorton is one the best in the country.
Consulting1 -
So should i call Dan Foley lol0
Here are the numbers:Ironman said:$200 per month is not a high gas bill for a drafty 2500 square foot house. In fact, it’s quite reasonable.
A 2500 square foot house, poorly insulated, in Washington DC, will probably have a HL of approx. 25K on the design day (28F). With a 65F base temperature, the HL is 675 BTU/hr/degree F. 16216 BTU/day/degree F.
There were 789 HDD at Washington Airport in January, 2024.
The net heating requirement for January is 12,794,424 BTU and the input (75% efficient) is 17,059,232 BTU.
This is approx. 171 therms.
If the cost of gas is $1.25/therm, the January gas bill would be approx. $213.00. This does not include any hot water.
Apparently the $200. cost is exactly as predicted.1 -
I think you just found your real problem. Air leaks are the #1 cause of heat loss in older houses. Get some incense sticks and hold them around the edges of windows and doors on a windy day. See where the smoke blows. You'll be amazed at how many air leaks you find. Do some research on how to seal up air leaks in old houses. Air sealing is one of the simplest and least expensive ways to save on your heating bills.rebecca2804 said:...the house is incredibly drafty in certain places...
Efficiency is over rated. Eventually gas bills will incorporate cost of pipes instead of amount of gas going through them.0
Shouldn't the bill indicate the volume of gas and its calorific power?jumper said:Efficiency is over rated. Eventually gas bills will incorporate cost of pipes instead of amount of gas going through them.
Where I live it is the case, and we know in details what we pay for the broker, the long distance transport, the local distribution and the various taxes.
EDIT
You mean dividing the gas volume by two will not divide the bill by two.
Alaas.
Are your heating and hot water pipes insulated?
John Cockerill Exquisite Heat www.exqheat.com Precisions boiler control from indoor reset.0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
