Replacement thru the wall unit needed
Does anyone know of a replacement unit, other then magic pak, that would make for a more direct replacement for the following Armstrong air unit, installed in 1998. Model# 10PWC242a-5a. So far I can only find Magic pak that will work, but it appears that there would be a lot of modifications to make it work. Thanks to all
