Replacement thru the wall unit needed
zepfan
Member Posts: 471
Does anyone know of a replacement unit, other then magic pak, that would make for a more direct replacement for the following Armstrong air unit, installed in 1998. Model# 10PWC242a-5a. So far I can only find Magic pak that will work, but it appears that there would be a lot of modifications to make it work. Thanks to all
Cant find that #, are we talking PTAC unit?
If yes Im looking at these very closely. Inver driven PTAC.
https://www.hotspotenergy.com/hotel-air-conditioner/PTAC-SpecSheet.pdf#:~:text=The ARAMA DC Inverter PTAC/PTHP is certified by,unit that can be installed by a home1 -
The unit is a ducted through the wall unit that is located on an exterior wall in a mechanical closet. The ductwork runs from that room to the condo. So no it is not a PTAC0
ISTR that question's been asked before…
Ah ha! Here's a few leads: https://forum.heatinghelp.com/discussion/103621/majic-pac & https://forum.heatinghelp.com/discussion/161385/replacement-unit
1 -
Magic Paks are still made by Allied Air.
National Comfort Products too though not sure if either is slide in replacement for the oldie.0
- 129 Chimneys & Flues
- 122 Geothermal
