This is what I found
joeshelmet
Member Posts: 4
Can it work ?0
Yes it can and will work and heat quite efficiently. Keep the pressure on the system low.joeshelmet said:Can it work ?
I bet that trap was made by Illinois Engineering Co. It's called an "outboard" trap because the expanding element is mounted after the valve seat. I've seen similar traps from Sterling and Broomell. They work fine, and repair parts are available if needed.EBEBRATT-Ed said:It should work it was installed many years ago when pipefitters knew what they were doing. Can't say I have seen steam traps mounted on their side though
Do the rest of your radiators have similar traps?All Steamed Up, Inc.
Consulting2 -
How can the radiator not be 1/2 filled with condensate ?0
Barnes & Jones trap0
It will have more condensate in it than usual -- but only up to the bottom rim of the trap. That won't keep it from heating.joeshelmet said:How can the radiator not be 1/2 filled with condensate ?
It has been rebuilt, then. I don't believe B&J ever made a trap like that- but they are one company that makes replacement parts. So someone has maintained that system.joeshelmet said:Barnes & Jones trap
Consulting0 -
mightn’t it cause hammer if the water is cool?Jamie Hall said:How can the radiator not be 1/2 filled with condensate ?
It will have more condensate in it than usual -- but only up to the bottom rim of the trap. That won't keep it from heating.NJ Steam Homeowner.
Webster did offer a trap with the thermostatic element horizontal, although the outlet was at the bottom of the body.
I would think mounting a conventional vertical element trap horizontal would allow for some debris build up in the body which may or may not cause problems.Dennis Pataki. Former Service Manager and Heating Pump Product Manager for Nash Engineering Company. Phone: 1-888 853 9963
The first step in solving any problem is TO IDENTIFY THE PROBLEM.0 -
mightn’t it cause hammer if the water is cool?ethicalpaul said:Jamie Hall said:
Shouldn't, because there is no steam velocity in the radiator to push the water around (the steam is condensing as fast as it can get in).Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England1
- 15.8K Strictly Steam
