This is what I found
  • Ironman
    Ironman Member Posts: 7,904
    Is there a question about this?
    Bob Boan
  • joeshelmet
    joeshelmet Member Posts: 4
    Can it work ?
    EBEBRATT-Ed Member Posts: 20,236
    edited November 2022
    It should work it was installed many years ago when pipefitters knew what they were doing. Can't say I have seen steam traps mounted on their side though
    IronmanLong Beach Edjoeshelmet
    Jamie Hall Member Posts: 27,397
    Can it work ?
    Yes it can and will work and heat quite efficiently. Keep the pressure on the system low.
    joeshelmet
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,843
    Goes great with the high hat LED lighting!
    joeshelmet
    Steamhead Member Posts: 18,528
    I bet that trap was made by Illinois Engineering Co. It's called an "outboard" trap because the expanding element is mounted after the valve seat. I've seen similar traps from Sterling and Broomell. They work fine, and repair parts are available if needed.
    Do the rest of your radiators have similar traps?
    Consulting
    kcoppLong Beach Edjoeshelmet
  • joeshelmet
    How can the radiator not be 1/2 filled with condensate ?
  • joeshelmet
    Barnes & Jones trap
    It will have more condensate in it than usual -- but only up to the bottom rim of the trap. That won't keep it from heating.
    joeshelmet
    Barnes & Jones trap
    It has been rebuilt, then. I don't believe B&J ever made a trap like that- but they are one company that makes replacement parts. So someone has maintained that system.
    Consulting
    joeshelmet
    ethicalpaul Member Posts: 8,868
    mightn’t it cause hammer if the water is cool?
  • Pumpguy
    Pumpguy Member Posts: 801
    Webster did offer a trap with the thermostatic element horizontal, although the outlet was at the bottom of the body.
    I would think mounting a conventional vertical element trap horizontal would allow for some debris build up in the body which may or may not cause problems.
    Shouldn't, because there is no steam velocity in the radiator to push the water around (the steam is condensing as fast as it can get in).
    joeshelmet
