Easiest way to remove 1 1/2” skim tap 4-point square plug?
Looking to install a 1 1/2” nipple with ball valve so I can start skimming this boiler.
Special 4 point socket?
I prefer not to remove the sheet metal knock out around the plug to try and get a wrench on it.
«1
    ethicalpaul Member Posts: 7,790
    I think the minimum frustration would be to remove the jacket even though it’s a pain.
  • WMno57
    WMno57 Member Posts: 1,408
    edited January 2022
    1/2 inch drive 4 or 8 point socket, with an extension to get into the hole, and a breaker bar so you can wiggle the plug back and forth to break it loose. Or a 1/2 inch drive impact wrench. Measure the distance across the flats of the square, and order up a socket. 12 point socket might work. 12 point will not be marked with the size of the square across the flats, so just try a bunch of different 12 points (including metric), until you find one that fits.
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    edited January 2022
    I'd use a 4-point ½" drive socket on a flex handle. Put a pipe hanger on one of the risers and secure it to the wall to keep the boiler from tipping, then you can stand on the flex handle until it gives.
    STEVEusaPA
  • JUGHNE
    JUGHNE Member Posts: 11,481
    I would spray it with PB Blaster or such several times and rap on it with a hammer some.
    You do not want to knock off the corners of the plug. 8 point socket fitting is critical.
    Then use a 1/2 or 3/4" impact wrench .
    The 18 volt 1/2" battery impact driver has done the job most of the time.
  • Hap_Hazzard
    edited January 2022
    I've said it a thousand times, but maybe it'll get through eventually. Penetrating oil does absolutely nothing when the threads have been sealed with a pipe joint compound. I've also found impact to be ineffective in breaking sealed joints. Sheer brute force is what it takes.
  • JUGHNE
    It seems that a large enough impact is sheer brute force.
    ethicalpaulPC7060
  • Bodycount
    Bodycount Member Posts: 43
    It’s 16 degrees here in NJ Meadowlands as I write this.
    This boiler is for my tenants.
    current train of thought is to spray the threads and rap the plug with a 3 pound baby sledge over the next few days, then attack on Tuesday.
    Then pound this 12 point 1/2” drive 32mn socket on (since apparently nobody has a 4 point) and try to muscle it.
    If not, I’m cutting the jacket open wide enough to get a straight wrench on it.
    Wish me luck.
  • Gsmith
    Gsmith Member Posts: 442
    can you skim this boiler from some other location, rather than risk breaking something important during the heart of the heating season. Even if not the ideal location, skimming at a very slow rate from SOME location might be helpful until warmer weather comes.
    Long Beach Ed
  • Bodycount
    I don’t see any other skim options.
    I cut out the knockout. Socket made has good contact.
    Monday is the warmest upcoming day.
    I’ll pop it out then.
    Thanks for the input!
    HVACNUT Member Posts: 6,944
    4 ft pipe wrench and a gorilla.
    Bodycountbucksnortkcopp
    pecmsg Member Posts: 6,379
    edited January 2022
    Wish me luck.
    Why in the world did you cut all that metal away, the panel is removable.
    Leave it alone until the weather breaks. Break something now and you're in a world of hurt!
    Bodycountbucksnort
  • Dan_NJ
    Dan_NJ Member Posts: 268
    Skimming through the sight glass is slower but it works - eventually.
    https://youtu.be/lO2oR9JhF0M
    Zolof808
  • JUGHNE
    I tried your method on an old boiler to get a 1 1/4" plug out.
    The plug is still there but with only 2 and 1/2 corners left on it. :s
    BodycountethicalpaulPC7060
  • Bodycount
    The sheet metal around the plug is scored with a few spot welds.
    An angle grinder with cutting wheel made easy work of it.
    It will fit back in when done.
  • Hap_Hazzard
    Definitely don't use an impact wrench on that socket. It will crack.
    bucksnort
  • Hap_Hazzard
    Sure, if you have one, and a 4-point impact socket. Most people don't.
  • JUGHNE
    edited January 2022
    You could buy the 4-8 point impact socket and rent an impact driver.
    Also the more points on the socket the more chances of slipping and rounding off the corners.
    bucksnort
  • Hap_Hazzard
    Or you could stand on a flex handle.
  • Bodycount
    I’m going to try and locate the appropriate socket over the next two days. If not…
    4’ Pipe Wrench.
    PC7060
  • delcrossv
    delcrossv Member Posts: 2,187
    ratio
    EBEBRATT-Ed Member Posts: 18,359
    @delcrossv they don't come nearly big enough
  • STEAM DOCTOR
    STEAM DOCTOR Member Posts: 2,414
    Somewhere in the 34 MM range works for me. Need impact socket and gun.
  • delcrossv
    ratio
  • Gordo
    Gordo Member Posts: 857
    edited January 2022
    @STEAM DOCTOR
    Where do you get your 34mm 8-point impact sockets?
  • ratio
    ratio Member Posts: 4,090
    Good Golly! I can buy a ¾" drive 6-½" 4-point 16" deep socket. In titanium.
    delcrossv
  • delcrossv
    @delcrossv
    Wow . that's impressive. I wouldn't want to buy the 6 1/2" one.
    delcrossv
    A drill bit and a sawzall is a lot cheaper.
    I would bet a 30" cheater pipe on an 18" wrench will take that out. It will bite on the plug a lot better than a huge 3' or 4' wrench
  • delcrossv
    @EBEBRATT-Ed I don't think I even want to know what you'd need Beryllium sockets for. Or what they cost.
  • ratio
    I shudder to think what "significantly more expensive" means.
    delcrossv
    mattmia2 Member Posts: 13,807
    I'm guessing the beryllium sockets involve the nuclear industry. and they are something like beryllium copper, not just beryllium. Also, poisonous.
    delcrossv
  • STEAM DOCTOR
    Gordo said:
    @STEAM DOCTOR Where do you get your 34mm 8-point impact sockets?
    I think Amazon. Not 100% sure. Got fed up with boiler plugs. Purchased Milwaukee 18v impact wrench and every impact socket, up to 50 MM. 12 point. Can remove plugs in 10 seconds or less. I can go up to 2.5" plugs. Not all plugs, of the same IPS size, have the same sized heads.
    BodycountGordo
  • Bodycount
    I measured the flats with a caliper.
    1 1/16”.
  • delcrossv
    1 1/16”.
    1-1/16" 075-1062-04S-B 3/4" drive, impact socket, 1-1/16" AF, 4-point, standard length, black finish
    Per the link above. A 3/4 drive handle can be had for about $25 . Got mine on the clearance counter at the auto parts store.
    Bodycount
  • Hap_Hazzard
    MikeAmann said:
    If you have access to one, you will want to use a sliding t-handle breaker bar so you can apply the force in equal and opposite directions. If necessary, use cheater pipes for more leverage.
    The trouble with these is you need an extension to get around the boiler controls, and with an extension you can't put your weight on the handle unless someone holds up the other end. A flex handle is just as strong and easier to use in this situation, unless you're planning to remove all the controls anyway.
  • JUGHNE
    That's good news!
    Bodycount
  • Hap_Hazzard
    tommay said:
    Just cut the square portion off with a grinder or sawzall. This will leave you with an opening you can get a sawzall blade into and just make a couple slices down to the thread.
    You've been lucky so far. They're not always hollow.
  • Hap_Hazzard
    Even better to just unscrew them. I try not to destroy hardware unless it's absolutely necessary.
