Massachusetts steam systems, š
Knuckleheads... see it up here in NH too. Seems nobody wants to read manuals any longer...0
K well you just need to boiler the water, itās easyĀ2
Bet you find a new tee and a union under that duct tape
Piped by a hot water fitter. What's wrong with it??? Supply & return is all you need.
Nice 45 degree offset though 1.414
gotta give him credit for that
Looks like the crappy QB burner and crappier Tiger Loop
I strongly think that years ago when they closed most of the Jr high and high school trade shops that somehow the READING classes were also deleted.4 -
So do counterflow serve owners better because there's less to be messed up?0
Jumper I would think itās all the same, itās either piped and skimmed well or it isnāt. Poorly piped means wet steam and itās downhill from there.
Ā This system is not counterflow, you can see the return main(s) in the background, lower than the supply.
Also, with counterflow, I bet two dollars and a couple donuts but the sub-par boiler installer would never touch the main vents at the ends of the mains0 -
Ed thatās very generous šĀ
I bet a dollar and a dollar he took a good guess at that offset, and then nippled his way down into the boiler,
That constant-I have remembered since I was a freshman in high school. The other angles, I need to look at my cheat sheet.0 -
I think itās a giant bushing āļødelcrossv said:Bet you find a new tee and a union under that duct tape
I think itās a giant bushing āļøGW said:delcrossv said:Bet you find a new tee and a union under that duct tape
Yes, that is the way both the boilers are piped in my 100-year old, two-family home near Boston.
The tees are original--bushed down from 3.5 inches to whatever was used for the riser of the replacement boiler. And you know what? They work fine that way.0 -
Chris thatās great- if the tee is big enough and the boiler is piped to spec, good times. Nothing wrong with a bushed tee if the velocities are goodĀ
too much steam then itās best to yank the tee and get two risers of the header (a bit more work)
but thatās not the concern in this picĀ1 -
I mean that boiler replacement for counterflow system requires less expertise.GW said:
Still not sure what the difference is, maybe a little less work overall, sureĀ0
You can move the boiler to fit the offset. No math or measurement was involved...0
Matt, Ed and I were having a math moment, we are all good1
Some will use any gimmick to avoid piping it right. No equalizer, no header, used one tapping, riser too small.
But they spent money for a surge tank which could have been spent on the right fittings.
Anything to avoid reading the instructions
Piped by a hot water guy "lets stick this in there it will fix it"4 -
I hear it works just as well if you leave it in the box in the corner
There definitely is some water putsing around the system. The system speaks to meĀ0
We are doing some minis on this property, when I quoted the job there were two clunky oil steam boilers- now, this boiler showed up out of the blue. I think thereās a local HVAC company pretending to be a hydronics installerĀ
Ā
You just attract the better jobs....huh?
And out there installing heat pumps too.0 -
J can you rephrase. Donāt understandĀ0
Ahh I was starting to feel my feelings šĀ
Iām a 1980s plumber turned boiler guy turned hvac guy. Just flowing the green paved road to retirementĀ2 -
its the new vertical header.GW said:We are doing some minis on this property, when I quoted the job there were two clunky oil steam boilers- now, this boiler showed up out of the blue. I think thereās a local HVAC company pretending to be a hydronics installerĀ
Ā
did you tell them they might want to not pay whoever did that?0 -
Matt Iām too shy and non confrontational, mum is the word ā0
that we did. and got some yellow #5 goop in my hair that day too1
Yes new cast iron, Iām old school š
running trap was a head scratcher for sure š«0 -
We are getting all the mini splits done.
We are getting all the mini splits done.Not sure how I missed this detail, feast your eyes 0
