Nest thermostat installation with common wire
Shaiba
Member Posts: 4
Hi I am here to get some help regarding installation of nest thermostat.
I installed nest thermostat but it wasn’t getting enough power and nest thermostat support suggested me to install common wire also.
My regular thermostat was installed using just 3 wires( red,white and green), although there were two extra wires folded back inside wall (blue and orange).
I decided to pull the wires from the wall so that I can use one from it to connect as common wire.
but when I pulled it it was little hard to come out and upon applying but force it came out but at the end of those extra wire there was cramp connector.
I got suspicious that these wires might be connected somewhere? I tried to use thermostat to turn on furnace it didn’t worked.
can you guys guide me where these wires could be connected . And what should I do to atleast get back the heat .
I will highly appreciate for any recommendations.
One is humidifier knob the other is ventilation0
Looks like you pulled the wires off the humidistat.
What was Red, White, and Green connected to on the old thermostat?
That cable looks thicker than 5 conductor. Are you sure there's not 3 more wires cut back flush with the sheathing?
Well, I'd certainly say you disconnected something... wonder what. I'd also suggest that the wire without the connector was pulled out of the connector on whatever, rather than pulling off the connector.
Got some interesting detective work to do there.Br. Jamie, osb
Do you have AC?
Was the green connected to old stat and where at.
Show us the old stat.
Did you shut off the power while pulling on the wire?0 -
Sorry but Crimp connectors dont work on solid wires. Not that it matters but fire cable for thermostat wiring?0
Could that be plenum rated 18-8 tstat cable?0
By bent one, I mean the one that points the same direction as the one with the connector still attached. That's a result of pulling on the attached wire.0
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
