Carburetor video
Zman
Member Posts: 7,611
If you have 25 minutes or so and a couple beers, this one is worth your time.
https://www.youtube.com/watch?v=toVfvRhWbj8
https://www.youtube.com/watch?v=toVfvRhWbj8 "If you can't explain it simply, you don't understand it well enough"
Albert Einstein
Albert Einstein
1
sure that's not a breathalyzer?0
25 minutes and didn't even explain the different circuits or the governor? Somewhere out there is a web site wit pictures calling out where the different circuits are in lots of common small engine carbs.0
I gave up after Mechanical Engineer.0
Zman, I am right there with you. Loved the video, and it made the theory behind a carburetor so clear in my head that I can almost explain it well to someone else. Hes a sharp guy who makes tough concepts easy. I like his laminar flow videos as well.Tom
Montpelier Vt0 -
Don't knock it too hard. You'd be amazed how many folks out there have absolutely zero idea as to how a carburetor works, or even what it's for.
Now a nice video on tuning a Quadrajet...Br. Jamie, osb
Building superintendent/caretaker, 7200 sq. ft. historic house museum with dependencies in New England3 -
I can tune one pretty fast if you need help.Jamie Hall said:Don't knock it too hard. You'd be amazed how many folks out there have absolutely zero idea as to how a carburetor works, or even what it's for. Now a nice video on tuning a Quadrajet...
Both old style and computer controlled.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
