3ft of Water/Sewer Backup - Buying home this week?
nz
Member Posts: 125
I am in the process of purchasing a new home which has a five year old Weil-McLain 340k-600k btu natural gas hot water boiler (four zones), and two 75-gallon (can't remember manufacturer) hot water tanks of a similar age.
Due to heavy storms over the weekend, the city where the home is located received over 8 inches of water in a 12 hour period, overwhelming the local and regional storm and sewer systems. As a result, the home I am supposed to be closing on this week flooded with over three feet of combined rainwater and sewage, leaving a coating of muck everywhere. The boiler is sitting on bricks, so it is only elevated about 3-4 inches above the floor.
The current homeowner(seller) had this happen before in 2016, and kept the majority of the insurance money while only replacing the boiler and water heaters. They did not install sump pumps, backwater valves, etc. This time, the homeowner has no insurance for sewer backup, so they will have to pay for the clean up/remediation and "repair" of the flooded boiler and water heaters. As this will be out of pocket, cost will be a major factor, and whomever they hire to "repair" the flooded mechanical equipment may not have an entirely unbiased opinion as they let slip that they know the owners.
Looking for advice from the experts here:
Is it reasonable to expect that a hot water boiler and water heaters can be safely repaired and operated after being flooded with three feet of sewage? Or do they need to be replaced?
My concern is that the contractor the seller hired will say "i got them working again" but then we will begin to experience issues months or years earlier...i.e., their useful life has been severely shortened.
I have reached out to Weil-McLain for their official stance, and trying to get the manufacturer of the hot water heaters to do the same.
Even though it's a sellers' market; I would not rely on the seller to tell me what damage has been done to the boiler and how much it would cost to fix it. I'd hire my own expert and deduct those costs from the purchase price.0
@nz , Weil-McLain has specific instructions for boilers that have been flooded. Go here:
https://www.weil-mclain.com/news/servicing-flooded-boilers
I'll agree with @SlamDunk - either all new equipment, or walk away.All Steamed Up, Inc.
Consulting1 -
After buying a house and dealing with the kind of repairs the person selling it will typically make there is absolutely no way I would want any part of it.
All new and properly installed or forget it.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
2 -
You may not be able to just 'walk away' without losing your deposit at best, or far worse. Check with at least your realtor, then a real estate attorney.
They should be replaced. But if they let you, take the money and install a wall hung boiler thru you're own contractor (after a proper heat loss is performed). Then it's your contractor, your warranty, etc.
I'd also seriously consider a few sump pumps with battery back up, or better yet, a whole house generator. As this problem will happen again.
And it wouldn't surprise me if you get water in the basement more often.
I assume you have a septic tankThere was an error rendering this rich post.
Were you part of the great lakes water authority pumping station failure that flooded much of detroit and dearborn?0
Yes. Seems like some pump station somewhere "fails" every time it rains a lot around here. I'm not sure what defines a failure though, that's a very broad term...did it lose power? burn out? someone forgot to hit the on-button? water level too high?mattmia2 said:Were you part of the great lakes water authority pumping station failure that flooded much of detroit and dearborn?
This isn't the first time it has happened and certainly won't be the last time, so I will certainly make sure the appropriate water mitigation controls are put in place. (Multiple sump pumps, backwater valve, etc.)
Side note: thanks for all the feedback...I appreciate all of it!0 -
If there are finished wood framed walls those will have to be opened up and dried out and disinfected as well.
I'm sure there will be a report by the glwa about what failed after everyone has forgotten about it. Could be something clogged, some pump failed, lost power and a generator failed or was caught in flooding...0 -
If the appliances got wet they get replaced. A blessing in seeing how the last time he pocketed the money.I’d walk without a major reduction in the sale price and I’d have my contractor do the work not his.0
Hi, I believe there are backflow preventers for sewer lines. Might be good to look into
Yours, Larry0 -
No way they keep the deposit, you have every right to back out with no loss0
This is a catastrophic event to the home that they admit has happened before. This place is going to need so much more than heating equipment replacement, building materials replaced. BWV, Check valves, perk tests pumps, etc., etc.
Your realtor? Do you have one? Real estate lawyer and you have plenty to "Reconsider".0 -
RUN Forrest
RUN0 -
There are actually decent ways to deal with a sewer that can backup, no? Check valves etc?neilc said:
this,pecmsg said:RUN Forrest
RUN
don't buy a house that floods,
ya can't beat city hall, and high tidesSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
My BIL had to get a backwater valve installed after the second time he had the brown trout swimming in his basement. The price was so not-as-bad-as-espected that a number of relatives in the neighborhood ended up getting them installed as well, as a preventative (The city is working on updating the infrastructure, but that a multi-decade project). So far, no issues...
The kids really liked watching the digging as well!
well, ok, sure,ChrisJ said:
you could backwater the main drain and hope that never fails, also,
and I'm not clear if rainwater flooded directly, or by way of overwhelming the city sewer,
but it's flooded now, and 6 years ago, and climate change , , ,
I know the housing market is crazy tight right now, and I'm not shopping,
but I would walk away from a flooded prospective purchase while I can.known to beat dead horses0 -
The only really reliable way to deal with a sewer system which backs up is called "gravity". It's found in most areas...
But what if a pump station fails? And they do. They should have an overflow to prevent damage to the property which they serve. That's part of the original engineering. For that matter, they should always have dual lift pumps -- and the pumps should be properly alarmed and controlled, which they rarely are. That's also part of the original engineering. (I lost count of the number of lift stations I inspected, back in the day, which had the alarms set incorrectly...)
Both of those things can be fixed, but that's hard infrastructure maintenance, and that's a pretty tough sell these days.
And as @JUGHNE said, it's a set of problems which existed long before "climate change" became popular.Br. Jamie, osb
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
