Protective "shoes" for radiators feet
branimal
Member Posts: 281
I'm about to install pre-finished hardwood floors and I've got 3 radiators I cannot handle by myself. I've been moving them around by sliding them into place as I work. Obviously not an option when I've got new floors down.
And I usually don't have help available.
I have used carpet, placed upside down with a piece of 3/4" plywood on top of it, the width of radiator + 4" by 6" to place under two legs at each end. Makes sliding on a pre-finished wood or tile floor easy with no marks left behind. Must sweep the floor before you slide the rad. You don't want to drag a piece of sharp-edged scrap, a screw, or a nail under the carper.
If the floor is unfinished and there is more friction as a result, you want to be careful the radiator does not slip off the plywood. So I glue a 1/4" plywood on top of that with some holes for the radiator legs to set in.
Mr.Ed
P.S.
I also have purchased shoes from Steeltoeshoe.com to protect my own feet from the damaging effects of cast iron radiators... Just sayin'
4 -
They might. But as @pecmsg says, you'll be much better off with a hand truck or wheeled appliance dolly.Br. Jamie, osb
I had a small radiator that was taking up space on the floor. I purchased a wall mount unit and had my local HVAC company do the install. After seeing it done, I probably could've done it myself, but it's worth the peace of mind to have a professional do the work, especially due to the age of the pipes.
Hand truck is safest for both you and the floor.0
Carpet!!!!! Go to a carpet store and get a remnant carpet as @EdTheHeaterMan says above. Carpet with soft matting, (No burbur weave). Lay the carpet down on the floor soft side down and then lay the Rad. on the floor on its side. If you put the legs on the carpet it will have the chance of digging into the floor through the carpet so be sure to lay it on its side.
Push and pull the radiator into position with some help. Make certain that the floor is free of any debris.
If you try any other way, you take the chance of scraping the floor.
Best of luck.0
