Fast and lucky sawzall cutting
GW
Member Posts: 5,184
I don’t do this everyday so I rejoiced at the fact I didn’t lunch the rad. “Old pic” is a different rad but same basic thing
6
@GW , that's called "skill". Nice job.Br. Jamie, osb
Been there, done that, but cut into the threads a bit. It pays to be extra careful, even though steam pressure is very low.
Great job.0 -
If you had gotten into it, it was just the bushing...you had one more chance not to mess it up
Thanks! this was a hw boiler job. wrapping up the new boiler today0
Bleeding air, that was a bit of a funky situation. There was about 14 rides, most of them, the coin vents were perfect. Several of them, very strange.
One was dripping, making a mess, one of my guys alerted me to the fact rain was coming into the basement. I grab a new coin, go up to change it. Opened up the old bleeder, pressure is at zero. I spin the old vent off and all of a sudden I get a blast of water. I spin the new one on, my hairdo got a little wet.
More oddly, another rad won’t bleed any air. Like the screw is out but zilch. I eventually go to the boiler and jack it to 25. To back up and all of a sudden it’s bleeding. Not fast, like 50% or so. Eventually fills up and heat is flowingIt’s an old two pipe conversation, old trap bodies in place.I’m wondering if the bleeder taps just got goopy; I’ve never seen venting issues0 -
Oops, showed my inattention to detail...0
That’s cool not sure how you could tell either way. This was once a steam system. But yes I am a little more relaxed when busting into steam rads0
Two oopses. In the first photo, when I saw the pipe at the top, I assumed it was steam without knowing why. I'm only familiar with my one pipe steam system.
That being said, I just bought "The Lost Art of Steam Heating, Revised" and on pages 212 and 214 it shows the steam supply at the top and return at the bottom. So, my guess was correct, but I could not prove it, if asked, since I never paid attention to 2 pipe details.
Do the old steam radiators in this system have a water passage across the top?0
Just came from a house where 2 elderly sisters live.
Saved everything from their lifetime.....but on the positive side they never had cats!
There are about 12 BB heaters with screw slot bleeders in the 90 ells. 2 of them would pass no air or water.
I would guess plugged ports. Hoping for the best of water flow.
No floor drain, no isolation valves, feeder stuck, water supply is shut off, (both have been such for years before I first saw the place) boiler drain will probably not open, 2 zone valves.....however the pressure relief valve is tested and reseats nicely.
When it gets low on water it will not heat the BB's, phone call is made.1 -
First resort for me. Quick and almost risk free. Slow and steady wins the race. Like everything else, need to work with what you feel comfortable.Ironman said:The way you did it is the almost last resort for us. We cut the union nut off and then use a pipe wrench directly on the spud. If that fails, then we do what you did.
Nice job on getting it out clean.2 -
I agree with @Ironman cut the union and get a wrench on it and jam something into the stub so as to not collapse it. They will usually come out.
But sometimes you have to cut0 -
Fwiw, I use the Milwaukee 18v Hackzall.0
Yes it kinda has to be that way with hot water. This seems to be a 1930s era house.WMno57 said:Do the old steam radiators in this system have a water passage across the top?0 -
Bob yes believe me I tried. I don’t enjoy sticking sawzall blades inside of Radiators either.0
232,000 BTU down to 125,000. Prolly could have went to the 94000 btu but there’s just so much metal. Even this boiler was climbing pretty slowly yesterday when I had all three zones going, wasn’t even very cold outside or in the house. Main zone is Constant circulation and the other 2 zones simply spin water on regular stat calls
3 -
Wow you filed your way through a brass nip? I guess that works too. When you’re hauling freight it’s just faster to do the 60 Hz shuffle though. Keep at it1
@GW did someone already have press copper on that indirect? Nice touch with the flue labels.Serving Northern Maine HVAC & Controls. I burn wood, it smells good!0
Hi Solid we did the boiler and water heater so all that stuff is new. The old 'return header'---I 'repurposed" that, so i kinda aligned the new boiler with the old header (the header was raised up some, but in the same location). We we literally jockeying the new boiler a little front and rear, left and right to nail it. You can tell the old header isn't 'as new', and there's an 1 1/2" x 1 1/4" 90 going into the boiler. Return ball valves and the drains are new, but the c x f tees are original.1
- 50 Industry Classes
